Fisher & Paykel no spin, no rinse
Hey guys, I have a smart drive 9 washing machine model GW709NZ, top loader.
It's not draining or spinning. I have removed the bowl to get to filter beneath but nothing stuck there. I can blow through the hose and it bubbles. I noticed when I took the drum out it had water stuck inside (could this cause a balance issue?)
Power is going to the machine and it kind of tries to kick start the rotate at regular intervals say every 20 seconds but won't turn. Makes a kind of hum sound when it does this.
Help!
Rosy
    President:
  • Washing Mach... Master
  • 2,651 Answers
Hums sound proble coming from the drain pump. sounds like its trying to pump out water but cant. try tipping back andsee if you can spin the pump manually, (usuallya fan cooling blade coming outta back end of pump.wont spin if it cant drain
Posted on Mar 22, 2008
Just to expand on what aborcass stated...
Pull the cloths out and put them in a trash bag.
Bail the water out of the washer.
Pull the washer forward.
Tip back enough to see and reach underneath.
Remove any clothing that might have been caught in the fan/motor underneath.
Posted on May 07, 2008
Smart drive 085
It won't spin until all the water is drained out. The drain pump may be blocked or faulty. Fix the drain pump fault first then deal with the filling issue. They will not be related.
Jun 21, 2017 | Fisher and Paykel (IWL12)
My fisher paykel top loader smart drive 053 has started to sqeak when spinning
drive belt may be loose and squealing just like a car will suggest re placeing it at that age.
Jul 09, 2012 | Washing Machines
Machine gets stuck between rinse ans spin and sits for a while then spins but wont stop, then **** from the in the machine or hose is on the clothes???? Any suggestions? Machine is a top loader smart drive...
You could try a hot load with epsom salts....this will clean out the machine....Make sure it is with hot water. It goes slow in between rinse and spin possibly because it is slow draining...clean out the pump. Also as it FILLS make sure the water runs in properly and not just trickle in making a hissing noise. Good luck. Tony the technician.
Apr 02, 2011 | Fisher and Paykel Washing Machines
Ficher and pykel top loader smart drive 9 model mw059nz - won't spin or drain but have emptied by hand tilted back and check for all blockages, coild it be the spin motor?
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 06, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher & Paykel washer GW712 won't spin
There is an issue with your drainage area. Best to remove the pump and check for the obstruction in the line or at the impellar.(If the water is not completely drained, the pressure switch wont send a low level to the timer to allow a spin).
Sep 14, 2009 | Fisher Washing Machines
Washing machine will not spin or drain
look at my post "eco smart won't drain, smells hot". It could be something stuck in very lowest part fo drainage area. you have to remove the motor on bottom of washer to see into this area and remove blockage.
Oct 12, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher & Pykel Smart Drive 9
Spin the fan on water pump (you can acess with difficulty from bottom of washer) if it has a little sand in it, it may clear. It is possible to remove water pump if mechanically minded and see if something small eg staple or 5c coin is stuck in it if this dosn't work or you may find you need to replace water pump.
Aug 19, 2008 | Fisher and Paykel Fisher & Paykel Washer
Fisher Paykel GWL11 Top Loader Washer
Please dont put any more money into this machine,if you wait long enough it will take alot more than a penny.
May 11, 2008 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
810 people viewed this question
Top Washing Machines Experts
