HITACHI- made an old Thompson GE #46GW750C in mid 80's
RED went out. There is red gel leaking from behind the Red proj. How can i fix this.
  • 50 Answers
YOU WOULD HAVE TO REPLACE THE COMPLETE RED PICTURE TUBE ASSEMBLY--THATS JUST THE START,,THERE ARE A LOT OF ADJUSTMENTS INVOLVED IN THIS JOB---ALSO THAT GEL OR FLUID,IF SPILLED ON THE CIRCUIT BOARDS WILL CAUSE EVEN MORE PROBLEMS---NEED A TECH FOR THIS ONE!!!!!!!!!
Posted on Mar 22, 2008
SOURCE:
Hitachi projection tv quit
Pls check that model number........the problem description does not match that of a 1999 crt proj tv.........I believe yours is a newer lcd projection around 4 or 5 yr old?? Lamp light flashing on any brand is indicative of the lamp not lighting . The lamp is the most likely cause,but the ballast board can cause this as well..................you should see an access door refer to owner book of the correct model and you can replace yourself...........it may cost around $200 and avaiolable at encompass parts .com Hitach distributor
Jun 06, 2010 | Hitachi 50UX57B 50" Rear Projection...
Have an old sony HDTV proj tv, and the picture went out last night. I heard sort of a "pop" then no picture
Pop sound shows that some thing went wrong inside TV and most probably any part got busted.
Let me know model number of your Sony TV and does its standby red light blinking? if yes, how many times it blinks between 3 seconds interval.
Nov 30, 2009 | Televison & Video
Hitachi Model # 43FDX11B. Will not power
Mine just developed the same problem.. did you find a solution/fix?
Jul 09, 2009 | Hitachi 43FWX20B 43" Rear Projection...
No problem but a question about three lights above rear window
That is the BACKUP SENSOR SYSTEM indicator.
its detecting objects behind the vehicle.
Feb 27, 2009 | 2007 Cadillac DTS Sedan
RED BLINKING LIGHT ON HITACHI TV CANNOT TURN ON
Check the resisters, that could be the burnt small, also you may need to replace the ICs
Jan 08, 2009 | Hitachi 53UDX10B 53" Rear Projection...
SCreen turns red then shuts off
The 46H84 has 3 CRTs instead of a lamp. Red, Green and Blue. Your red CRT is shorting out shutting down the set.Here is how you test that theory. Remove the speaker grille, there will be an access panel behind the grille remove that and you will see the CRTs red is usually on the left. hit the power momentarally to locate which tube is red. then power down and unplug the power cord. Carefully remove the tubes Circuit board. ( you may have to carefully slice the glob of silicone applied at the factory to get the circuit board off) Once you have the circuit board off the Red CRT make sure it isnt touching anything and try powering up the set. If the set stays on and the other 2 CRTs light up. That tells you the RED crt is shorted and thats whats shutting your set down. Let me know if I can assist you further.
Mar 25, 2008 | Toshiba 46H84 46" Rear Projection...
Hitachi 43fdx01b rear proj. hdtv
if you are using Y, Pb,Pr, connection to the tv from a sat or cable box check the red wire on both ends red may be disconected.
Feb 09, 2008 | Hitachi FDX Series 43FDX10B 43" Rear...
Hitachi really red picture
Wally, 2 things can cause that, 1) bad solder on red driver transistor (mounted on Red picture tube board) 2) bad red cathode in the red tube which means big bucks (new tube), may not even be available on that old of a set. Hope this helps BMW Rider
Dec 12, 2007 | Hitachi 46UX24B/25K 46" Rear Projection...
Hitachi 55VG825 rear proj television blinking light and screen doesn't light up
Refer to owners manual ! Blinking indicates the type of fault that is occuring on all your tv sets. example : power light on red - indicator light beside it green but blinks rapidly for half a second rapidly then shuts off. This refers to a faulty lamp or a lamp that is near its expiration. Read your manuals if indicators refer to easy repair sweet, but if it says call tech then bummer...
Dec 06, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Televison & Video Logo
69 people viewed this question
Top Televison & Video Experts
Ekse
