Question about Vizio P2 42 in. HD-Ready Plasma Television
Y sustainer board failure. Cost of part? Availability of part?
As above. Cause of problem suggested by your expert: Sarah29 and confirmed by Vizio tech., who says long delay in obtaining part (???). I hope Sarah can provide info re this. Thanks.
Namreh
    Sergeant:
  • 395 Answers
The part number is 6871QYH053B you can get it at www.vancebaldwin.com for $194.36 with a core of $76.65 they have 24 of them in stock
Posted on Mar 23, 2008
My 50in P50HDTV10A 50 in. HDTV Plasma Television soundscomes on but no pic please help
I'm not an expert with plasma's but I repaired a 42" version of your set. It was a faulty Y sustain board. I would start with checking the fuses on the Y sustain (should be on the left side of the set under the steel cross member) and on the Z sustain( right side of the set).
Sep 06, 2012 | Vizio P50HDTV10A 50 in. Plasma HDTV
Vizio closed captions are with red background! Dish TV or Vizio problem?? Also red pixel lines/flashes!
It is a TV problem and could be the sustain boards or the mainboard.
Most likely it is the Y sustain board but it is recomended to replace Y and Z sustain boards if one is damaged.
Jul 12, 2009 | V, Inc. Vizio P50HD Plasma Television
HDTV was ruuning & then popped. Then nothing
This is a common problem on these plasma TV's. The problem resides inthe high voltage boards known as the X and Y Sustain boards.. You canpurchase them here for a very reasonable price:
http://www.discount-merchant.com/Y-SUSTAIN-FOR-42-PLASMA-TV-PN-6871QYH036A-p/sku9510.htm
The above link is to a Y-SUS board. The X-Sus board is often the 2nd cause of failure and can be found here:
http://www.discount-merchant.com/X-SUSTAIN-6871QZH041B-6870QZE017D-6871QZH052D-p/sku9509.htm
Totest which board is failing, you need to check voltage input to theYSUS board first... Input should be 120V from Power supply, outputshould be above 250V.. Do this test with XSUS disconnected. IF 250+Vexists, then XSUS is damaged. If not, then the YSUS is the faulty part.
Jul 05, 2009 | Zenith Z42PX2D Television
Vizio P50HDM No Picture/No Sound
this is most likely the sustainer board(s) problem. Replacing the sustainer boards should correct this problem for you. you can get the parts at vancebaldwin.com
May 29, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
replace the sustainer boards should correct this problem. New sustainer boards may cause red and green pixilation. If this happen, replace control board and TV is as good as new.
Apr 05, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Vizio Replacing Sustainer Boards
I would start by replacing the fans as they are cheaper and easier to replace. Plasma tv's have a fail safe not to turn on if the fans dont work. If you bought at costco a couple of years ago you are in luck, take it back for a full refund.
Jan 15, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Bush pdp42tv006 4amp fuse blown . not the main fuse.checked for shorts .any help? thanks
pls check the main power supply<regulator> hang the loads going to secondary supply,
Apr 29, 2008 | Televison & Video
Goodmans pdp42tv006 plasma,comes on for 15 secs then shuts down power led blinks red constantly until power is switched off,when power restored does as above many thanks if you could shed some light on it,...
Bullis,
This is a common problem on these plasma TV's. The problem resides in the high voltage boards known as the X and Y Sustain boards.. You can purchase them here for a very reasonable price:
To test which board is failing, you need to check voltage input to the YSUS board first... Input should be 120V from Power supply, output should be above 250V.. Do this test with XSUS disconnected. IF 250+V exists, then XSUS is damaged. If not, then the YSUS is the faulty part.
Mar 21, 2008 | Televison & Video
Vizio P2 42 in. HD-Ready Plasma Television Logo
222 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
