Question about Insignia NS-DA2G MP3 Player
Instructions How do I erase select files
    Novelist:
  • 170 Answers
There are two different solutions for erasing select files from your Insignia player:
Sync Solution - If you have been using a music service like Rhapsody, Best Buy Digital Music Service, or WMP10, you can connect the player while in Sync mode (switchable in the USB preferences on the players setup menu), open the software, find the Insignia player, open the players song list, and delete tracks that you don't desire.
File & Folder Solution - This is just like navigating your hard drive. Connect the Insignia player when in File & Folder mode, open the drive (should be on your desktop or in your device list under My Computer), and delete what you don't want the same as if it were on your computer.
Posted on May 12, 2008
SOURCE:
Hi i own a RCA digital voice recorder model# rp5030A i can not figure out how to delete recordings
Erasing selected file
You can delete a file by the following steps:
1. Select folder (A, B, C , D or )
2. Select file.
3. Press ERASE once and DELETE will blink on the screen.
4. Press and hold ERASE for 3 seconds to confirm deleting. (or press STOP to cancel erasing file)
Erasing all files in a folder
You can delete all files in a specific folder by the following steps:
1. Turn on the unit.
2. Select a folder (A, B, C , D or ).
3. In Stop mode, press FORWARD continuously until "ALL" appears on the display.
4. Press ERASE and "DELETE" will blink on the display.
5. Press and hold ERASE for about 3 seconds, all files in the selected folder will be erased completely (or press STOP to cancel erasing all files).
Tip: File numbers that come after erased one will be moved forward by one automatically.
See page 12 for more info: http://www.rcaaudiovideo.com/docs/common/RP5030/RP5030_OM.pdf
Dec 29, 2012 | RCA RP5030 Digital Voice Recorder
I need to delete a recording
2. Select file.
3. Press ERASE once and DELETE will flash on the screen.
2. Select a folder (A, B).
3. In Stop mode, press FORWARD continuously until “ALL” appears on the display.
4. Press ERASE and “DELETE” will flash on the display.
Aug 14, 2009 | RCA RP5010 Digital Voice Recorder
Erasing the memory card;
All pictures in the internal memory and/or on the memory card can be erased at once. This is accomplished through either formatting or the "all-frame erase" function. I copied the following instructions from the advanced manual, which can be downloaded here: http://www.olympusamerica.com/files/d545zadvman.pdf. Adobe reader should open that file with no problem. If it doesn't, that's another issue altogether.
1. Enter playback mode by pressing the play button.
2. Press the OK MENU button.
3. Press the right arrow button (next to the lightning bolt) to access [MODE MENU]
4. Then, press the down arrow to access the [MEMORY(CARD)] tab.
5. Select the [ALL ERASE] function.
6. Select Yes and press OK MENU.
(You'll need to use the arrow buttons to navigate the menus. Please see pg 16 of the manual for instructions on how to do so.)
Note: when the memory card is in the camera, it will erase the pictures off the card. When the card is removed, the function above will erase the internal memory.
Apr 22, 2009 | Olympus D-545 Zoom Digital Camera
I don't know how to erase the recorded data on my DS-2 recorder.
Select the file, then press erase and follow the display. If you hold down erase, you should get an erase all option. Also you can select Format in the menu.
Nov 17, 2008 | Olympus DS-2 Digital Voice Recorder
I LOST THE MANUAL. CAN'T FIGURE OUT HOW TO ERASE PERVIOUSLY RECORDINGS.
How are files erased from the VN-3100PC?
Individual selected files or the entire contents of a selected folder can be erased from the VN-3100PC.
To erase a selected file:
  1. Press the [REW]or [FF] button to select the file.
  2. Press the [ERASE] button.
  3. Press the [REW] or [FF] button to select YES.
  4. Press the [PLAY] button.
To erase the contents of a folder:
  1. Press the [REW] or [FF] button to select the folder.
  2. Press the [ERASE] button twice.
Erased files cannot be retrieved.
hope this helps! =]
thanks for using fix ya
Aug 01, 2008 | Olympus VN-3100PC Digital Voice Recorder
Erasing
Press Menu to select the folder you want to erase from. Press |>> or <<| (next or previous) to select which recording to erase. Press ERASE once. The bottom display should read DELETE. Hold down the ERASE button to confirm the erasure, and the file is erased.
Jul 07, 2008 | RCA RP5010 Digital Voice Recorder
Help dont want to lose everything
The reason it is asking you if you want to delete all is because you have not selected specific files to erase, so when you hit erase without selecting a file it assumes you mean delete all.
To erase try these steps...
To erase a selected file from Folder A, B, or C:
  1. Press the MENU/FOLDER button to select Folder A, B, or C.
  2. Press the - or + button to select the file to be erased.
  3. Press the ERASE button.
  4. Press the - or + button to select YES.
  5. Press the ENTER/INDEX button.
To erase the contents of Folder A, B, or C:
  2. Press the ERASE button twice.
  3. Press the - or + button to select YES.
  4. Press the ENTER/INDEX button.
To erase a selected file from a date subfolder in Folder S:
  1. Press the MENU/FOLDER button to select Folder S.
  2. Press the - or + button to select the date subfolder.
  3. Press the PLAY button.
  4. Press the - or + button to select the file to be erased.
  5. Press the STOP button.
  6. Press the ERASE button.Press the - or + button to select YES.
  7. Press the ENTER/INDEX button.
To erase the contents of a date subfolder in Folder S:
  2. Press the - or + button to select the date subfolder to be erased.
  3. Press the ERASE button twice.
To erase the contents of a month subfolder in Folder S:
  2. Press the ERASE button three times.
  3. Press the STOP or PLAY button to select the month subfolder to be erased.
  5. Press the - or + button to select YES.
  6. Press the ENTER/INDEX button.
To erase the contents of Folder S:
  2. Press the ERASE button four times.
May 30, 2008 | Olympus VN-480 Digital Voice Recorder
I want to delete some files!
PS. here is a link to download manuals and software for this device:
http://www.olympusamerica.com/cpg_section/cpg_support_product.asp?id=1080
Good Luck ... oh and dont forget to rate my response.
How to erase recordings on the Panasonic RR-US500
I called the Future Shop where I bought the recorder and the salesman looked at the manual online and saw that the Delete instructions do not tell you what you need to know.
To Erase or Delete recordings from this recorder, you have to select the track or file you want to erase, hit the Erase button, see that track number flashing THEN hold the Erase button down for a full second.
You can toggle until ALL comes up and then erase all your files at once if you wish.
You can also hit the Erase button first and then select the track you want recorded. The important thing to know is that you then have to see the number flashing THEN hold the Erase button down for a full second.
Mar 29, 2008 | Panasonic RR-US500
Deleting Files
1. Select folder (A/B/C/D)
2. Select file.
Aug 04, 2007 | RCA RP5015 Digital Voice Recorder
Insignia NS-DA2G MP3 Player Logo
54 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
Steve Allison
Steve Allison
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
