Question about Roper FGP305 Gas Kitchen Range
Light pilot o n gas range for roper stove FGP305KW1
How do you light the pilot for gas range not the over broiler?
6ya staff
SOURCE:
Anonymous
SOURCE: Gaffers and Sattler vintage stove oven pilot 1956 W54 series similar problem
My mother had the same problem with her Gaffers-Sattler range. No one could figure out what was wrong with it. Her local new appliance repair people said to contact J.E.S. Enterprises, Inc at www.theoldapplianceclub.net. Whew; thank God for that tip. They knew exactly what the problem was and repaired the unit for her. The stove is running again like a workhorse! Here is their number - 805-643-3532.
Bob Allen
Posted on Nov 24, 2008
Anonymous
  • 7 Answers
SOURCE: How to lite a pilot lite on a frigidaire "Gallery" gas stove?
wet sparkers, let them dry out good
Posted on Jan 30, 2009
Sea Breeze
John Tripp
  • 4656 Answers
SOURCE: GE XL44 gas: Stove works fine. Oven heater lite on but gas wont
Click on link below and go to page 46 on the Adobe PDF of your model and there are some trouble shooting tips. Thanks, Let me know if this helps, Sea Breeze
http://products.geappliances.com/ProdContent/Dispatcher?REQUEST=SKUOBJECTS&DOCUMENT=Installation%20Instructions&SKU=RGB745BEAAD
Posted on Feb 08, 2009
Anonymous
SOURCE: Roper Gas Range
F1 Error
My Roper gas range is sounding an alarm call with number F1 flashing. Can anyone reveal what the code means before I call service? Thanks!!
Posted on Jul 28, 2009
wbwill
William Babbitt
  • 68 Answers
SOURCE: how to light pilot for oven in 1950's roper delux
If it is an insta-light, I just rebuilt a Roper that age, the instructions are to turn off oven heat control, wait two minutes, locate red button which you have done, apply match to pilot, depress red button for 5 seconds and that should keep pilot light on, the instruction manual states to hold match for 60 seconds prior to pushing button, then hold for 5 seconds, either way, you don't want to flood the area with raw gas, and yet still apply enough heat long enough to lock in pilot, has the gas line been loose? Make sure it is purged of air, again, don't flood area with raw gas, it is pretty typical pilot procedure, the worst part is finding the red button, usually behind a burner cover. So try holding the button a bit longer with your match on it, some take a while, worst is the control has gone bad, but there are replacement valves for this vintage, I did check,
Posted on Dec 17, 2009
Broiler pilot light works. Why won't stove top pilot light?
The pilot orifice may have gotten contaminated during cleaning or something may have affected the gas supply line.
Dec 27, 2015 | Roper FGP210 Gas Kitchen Range
Was preheating oven, while cooking on stove stop. heard a puff sound open up oven thought it was on but it never heated up. the electric light comes on but does not ignite. the broiler does the same. ...
Gas ovens are fitted with at least one safety device and it could be it has failed.
The safety device is bypassed while the pilot light is lit. The pilot light heats a thermocouple bulb which switches the gas on to the burner. As long as the pilot light continues to heat the bulb gas will continue to flow - until the thermocouple fails, they aren't long-lasting...
Feb 03, 2018 | Hotpoint 30" Self-Cleaning Freestanding...
My oven won't pre-heat. It seems the pilot light is out, but the stove top works. What's wrong?
EITHER LIGHT THE PILOT THROUGH THE BROILER DOOR OR IF YOU HAVE A WALL PLUG FROM UNIT THEN THE IGNITOR IS PROBABLY BAD.
Mar 10, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
How do you start the oven on a Hardwick propane range?
The bottom part of the stove in the front has a drawer you pull out which has a broiler tray located there. You should be able to fold the door down and use a flash light to look inside . You will find a pilot light set-up there.
The stove I have has the pilot gas on all the time, so as soon as you turn on the gas to the range, the pilot gas is open to atmosphere.
I just light a match and reach in to where the gas piping can be seen and the pilot flame will light.
There is only a small amount of gas coming from the pilot orifice, so there isn't any danger lighting it when the gas is first turned on at the tank.
In fact you may have to wait a few minutes for it to light at first because the propane line maybe full of air. I usually light the top burners of the stove first and by that time the pilot gas for the oven is ok to light.
Jan 05, 2010 | Kitchen Ranges
Broiler doesn't lite, no gas going to pilot
Most cases Broiler ignitor is out, after you turn on the Broiler, check the voltage on Broiler ignitor 2 wires, if you have approx. 110v, then change the ignitor, but you don't have 110v, then check Broiler safety valve and oven thermostat, but 90% of the time is the Broiler ignitor. Have fun.
Jun 29, 2009 | Dynasty DGRSC 48-6G Gas Kitchen Range
Problems with Brown Stove Works TM110-3 Gas Kitchen Range
http://www.brownstoveworksinc.com/pdf/gas_manual.pdf
there you go, the complete manual to operate your stove. look on page 16 to read about the pilot in the oven and how to proceed.
May 20, 2009 | Brown Stove Works TM110-3 Gas Kitchen...
Bob Allen
May 07, 2008 | Garland H283 Gas Kitchen Range
Roper gas oven won't work
replace the thermal coupling on the pilot make sure it is in the flame of the pilot it looks like a copper wire or tube if its bad it wont open the gas valve after the pilot heats it up
Mar 02, 2008 | Ovens
Lighting a pilot light in a 30 year old roper gas range
Lift the top lid and look for a cylinder or something similar with tubing going into it there should be a button of some sort on the side. if you are lucky the button will have a red cap on it. press the button in and light the pilot inside the oven. hold the button for a minute or so until the pilot stays on. kind of like lighting a water heater.
Oct 31, 2007 | Ovens
Roper FGP305 Gas Kitchen Range Logo
306 people viewed this question
Top Roper Kitchen Ranges Experts
Bruce Denton
ray gallant
ray gallant
Jerry Albright
Level 1 Expert
Are you a Roper Kitchen Range Expert? Answer questions, earn points and help others
