Question about Fuji FinePix A500 Digital Camera
My FinePix A510
The long range shots are blurry and before it was great to shoot long distance. Whats wrong with ut? What extended lens do I use on this camera
  • deveev Mar 29, 2008
    There is a fucus error message
    Genius:
  • 1,691 Answers
First check that the camera setup is not in the macro mode, or in a fixed focus mode of some type.
If there is an actual defect, it is possible that the focus helicoid in the lens has some abstruction or defect near to the end of its focus range. It is also possible that there is a fault with the focus sensing for the near to infinity point.
This is something you cannot fix yourself.
Jerry G.
Posted on Apr 13, 2008
SOURCE:
JZ300 Autofocus not working
Beyond sand getting in, the lens may have been damaged from the impact if it fell on the lens while extended. It may need to be serviced by a technician.
Apr 13, 2014 | FUJIFILM FinePix JZ300 Digital Camera
Got no picture all blurry
No picture or one that is all blurry? If blurry,
Clean the lens and make sure it is not loose or damaged. The camera cannot produce blurry pictures at distances greater than around 0.3m ish as it has a fixed focus lens. If it really is blurred either you are too close to the lens, the lens to sensor distance is wrong (mechanical damage) or the lens is dirty.
I hope that helps
Jan 26, 2011 | Microsoft VX800 Webcam
Digital Rebel XT / EOS 350D Digital Camera with EF-S 18-55mm Lens: my rebel xti won't shoot a macro shot. There's pl...
There is a minimal focusing distance for all lenses. If you move closer to the subject than that distance then the camera won't focus on it. Check you lens manual for minimal focusing distance. It is 11 inches for Canon EF-S 18-55mm f/3.5-5.6 USM, for example.
May 16, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Why is my fuji finepix j100 camera giving blurry photos , even looking through the lens the images are blurred and when the picture is taken its the same
SOUNDS LIKE A FOCUSING PROBLEM
HAVE YOU SET IT TO MACRO SETTING AND NOT SWITCHED BACK.
DISTANCE VIEWING ETC., WOULD BE THIS WAY
Feb 15, 2010 | Fuji Finepix J100 Digital Camera
My finepix f480 says !ZOOM ERROR on power up and switches off. Any suggestions as to whats wrong?
Does the lens retract and extend fully? Because of the design of the lens It is possible that the internal lens has jammed or is damaged. click on my profile and email me and I may be able to help
Jun 04, 2009 | Fuji FinePix F480 Digital Camera
Ixus 750 Blurred photos shot at a distance greater than a meter.
Check to see that the camera is not in "macro" mode, which would only allow focusing at a close range, but not allow focusing at beyond about 2 meters (look for the "flower" symbol to tell you that macro is activated). Could also be an out of adjustment lens, due to impact or force. Also check to make sure it's not as simple as a dirty lens. Digital cameras are more succeptable to blurry pictures from a smudged lens than film cameras were. Of course, that wouldn't explain why close shots are OK but distant ones aren't. Probably the first two suggestions.
Oct 06, 2008 | Canon PowerShot SD550 / IXUS 750 Digital...
Cyber-Shot Dsc-W70
Hi
You probably have a faulty lens unit. You can make sure of this by checking that the spaces between the two rings that extend forward at switch on has the same distance between each other.
If it is not the case, your lens is damaged and needs to be replaced.
It normally costs about 1/3 the price of the camera, so it should still be worth replacing.
Bear in mind though that only Sony Service Centres can help you as the y need to setup the new lens adjustments with Sony specific software.
Hope this helps.
Mar 09, 2008 | Sony Cyber-Shot DSC-F717 Digital Camera
Canon digital camera power shot A510
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Feb 08, 2008 | Canon PowerShot A510 Digital Camera
Action pics with a long lens
What you are experiencing is not blur, its camera shake. You are shooting in low light so the shutter speed is being reduced by the camera's automatic features. Also the longer the lens (the farther you zoom), the higher the shutter speed you need. Even for non moving objects or when panning the shutter speed should be at least one stop above the focal length. ie - 300mm lens = 500 or 1000 shutter AT LEAST! (and don't forget, if its a film lens on your rebel, thats actually 300mm x 1.6 =480mm, so 1000 shutter or higher min.) Moving objects require even faster shutters. Solutions: Get faster (also called brighter) lenses which can be pricey. In low light use higher iso settings in the camera menu. Shoot in either manual or Tv mode and choose the higher shutter speeds while using the light meter to decide aperture. Use wider angle lenses or back off the zoom and move closer. Stabilizers built into the lens can steady the shot by two to four times as well.
Sep 14, 2007 | Canon Rebel XT / EOS 350D Digital Camera
S2 Pro User Questions-Focus Issue
With the camera you have, noise isn't much of an issue when pushing the ISO to 400, 800 or even 1600. Try setting at ISO 400 and change it to manual mode or shutter priority and then choose a faster shutter speed. Take some test shots. If it's still blurred, increase the shutter speed and ISO to 800 and try again.
Sep 04, 2005 | Fuji FinePix S2 Pro Digital Camera
Fuji FinePix A500 Digital Camera Logo
78 people viewed this question
Top Fuji Cameras Experts
Ekse
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
