Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Always dispenses CRUSHED ice
Push button for crushed ice, little green light indicates the selection, crushed ice comes out fine.
Push button for ice CUBES, little green light indicates the selection, but
crushed ice will continue to dispense, forever.
Sorry, but this refrig is at mother-in-laws house, I didn't get the model number, but it looks like the one in the picture (side by side, metal color, nice handles, etc.)
I will eventually get the model number
Justin
    President:
  • Frigidaire Master
  • 2,651 Answers
Try removing the ice bucket, and on the back wall is a hole approx 1.5 inches square that the brass bar attached to the rear of ice container inserts into,(you may have to put hte container back in partilaly to look under and watch where it slides into) inside thatcut-out is a plunger that slides up and down activating the crushed/cubed option.you can sick you finger in the hole you should seee a plastic hoop that would catch the brasss bar.Try pushing and pulling hte hoop up and down if it does not move freely, youll need to replace the solenoid assy. if it does, then pull allthe way to the lowest positon and make sure when replacing the ice container that the bar falls with in the hoop itself
Posted on Mar 22, 2008
When I try to make ice, it always makes crushed. How do I get cubes?
The solenoid needs to be checked for free operation, you should be able to remove the ice bucket and reach into the small opening where the solenoid saddle is and easily lift it with your finger, and it should fall back down when you let go. The saddle should be down when the bucket is installed so the actuator rod slides into the saddle. If the solenoid is actually energized in both the crushed or cubed setting, you will need to look to the mechanical switch and orange flag indicator on the front of the freezer door for possible shorts. Most likely the solenoid assy is frozen, or iced up as this is a simple non electronic dispenser system. Pleazer Appliance...
Jan 16, 2015 | Frigidaire Refrigerators
WHEN I PUSH BUTTON FOR THE CRUSHED ICE IN THE DOOR I GET CRUSHED ICE BUT WHEN I SWITCH THE BUTTON TO CUBED ICE NO ICE COMES OUT BUT THE BUTTON LIGHTS UP WHEN SWITCHING FROM CRUSHED TO CUBE EVERYTHING ELSE...
You will need to check inside the ice tray for anything that may have fallen in. Sometimes the ice itself with stick into clusters and will not dispense. I would take out the tray, empty it, rinse it and re install it. Good luck!
Sep 15, 2011 | Whirlpool Refrigerators
I have a Kenmore side by side, not sure the model, but it's probably 10 years old or so. It has an ice maker with water, cube and crushed ice dispenser. The ice maker works fine, but it will not dispense...
Most of the time the bin has been removed and not put back in properly. When this happens ice blocks the drive motor. Remove the bin and turn the auger by hand make sure it will turn and is not jammed. Now with the bin out push the light button in that turns the light out and have someone push the button for ice while the door is still open the motor should turn in the back make sure thereis no ice blocking it. If it turns nothing is wrong with the motor. The clicking sound is usually the motor jammed by ice or the auger not engaged on the motor. hope this helps good luck
Aug 15, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I have model# FRS26R4AW5. The ice dispenser wil
I have a few ideas for things to try. On the bottom of the ice cube holder I believe there is a spring loaded metal rod that runs from the front of the freezer to a little indentation in the back of the freezer. Inside this indentation there is a small plastic piece that can move up and down to rotate the metal rod. Make sure this metal rod is free to rotate. Sometimes it gets stuck in one position. The position of the plastic piece inside the indent in the rear of the freezer is controlled by a solenoid which is controlled by the buttons on the front of the door for cube or crushed. Close all the doors and push the cube button. Open the freezer door and remove the entire ice cube tray. Reach to the back of the freezer and make sure the little plastic piece inside the indent will move up and down easily. You want it to be in its down position. Re-insert the ice cube tray. The metal rod should fit easily into the indent in the back of the fridge. Now close the door and see if you can get cubes. If this doesn't work I suspect the solenoid that moves the little plastic piece may need to be replaced. I hope this helps you out.
Jan 09, 2010 | Electrolux Refrigerators
GE PSS25MGMA Crushed ice only, nothing else will select on panel.
Yes , replace the main board . Part number WR55X10656 . There is only partial communication between the main board and the dispensor board . This main board , is behind the 8 " X 10 " panel , on the back of the refrig . Do not replace the dispensor board . I have never come across a bad dispensor board yet . Always a first time though .
Sep 27, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Dispenses crushed ice and will not dispense ice cubes
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid
Aug 17, 2009 | Frigidaire FRS23H7CS Side by Side...
Water, ice and crushed ice dispenser doesn't work properly
you need to replace the board in the dispenser front housing on the front of the freezer door / larry
Mar 16, 2009 | Refrigerators
Ice dispensor only dispensing crushed ice - not cubed
Make sure that your ice tray is properly instaled. There is a rod that must go into a hole. When you select ice cubes rather than crushed ice a solenoid raises which moves that rod. It then opens a flap so the cubes can bypass the crusher. Either your rod is not in the hole correctly or the solenoid has gone bad. The rod that I am speaking of runs along the underside of the ice tray. It has a spring on the rear end that holds the bypass flpa closed.
Dec 02, 2008 | GE GSH22JFT Side by Side Refrigerator
Ice and water dispenser not working but light on constantly
We had the same problem. When we removed the ice receptical the mechanism that turned the ice make was broken and it stopped the ice from being dispensed. I hope it is that simple for you!
Aug 15, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
749 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
