Question about Brother IntelliFAX 4750 Plain Paper Laser Fax
My machine alway off when ever i put it on
When iput on machine ,it off back and the toner light is on
    Genius:
  • 2,120 Answers
Add toner.
Posted on Oct 26, 2008
My bizhub c25 waste toner was full so replaced and will not now reset.
The C25 stores toner in a waste toner container. On the front of that container there is rectangular clear window that fits into a sensor when installed into machine. The sensor passes a beam of light through that window. When the bottle is full there is toner inside that clear plastic window which stops the light from making it through the window and the machine will tell you the waste toner is full. Just dumping the container out will not clear that window and by putting it back in the machine you will get the same toner full message. If you are going to try to reuse that container you will have remove the black plastic cover that is glued to the container above the clear plastic. Then use something like a Qtip to clean all the toner off of that clear window(much easier and faster to just replace in with a new container). if you still get the waste toner full message after you install it then remove it and wipe off the sensor that the clear window sits in. This will clear the message and you can continue your copy job.
Apr 02, 2014 | Konica Minolta Office Equipment & Supplies
Clp-325w red light always on
Check toner and open front cover remove toner turn off printer and put it back toner and turn it on printer..
Feb 18, 2013 | Samsung CLP-325W Wireless Laser Printer
Toshiba 166 showing toner light after replacing new cartridge
do this first remove the toner from the machine second input the 08 695 0 then close the machine then put the toner back
May 17, 2012 | Office Equipment & Supplies
Copier turns on and doesn't stop running. Can't print or reset. It seams stuck in warmup.
This almost always means the toner cartridge is empty. This is especially true if you can hear sort of a thump noise about every 5 seconds or so. When these toner cartridges run out the machine will still try to add toner. If it does not get it, it will eventually shut down and turn on the red toner light which looks like a stack of 6 dots. Just turn the machine on and let it run. After a few minutes it will shut down and turn on the toner light. If not reply back.
Good Luck and Thank You for using Fixya.
Oct 17, 2010 | Sharp AL-1642CS Copier
Put in new toner into KonicaMinoltaBizhub200,says exchange toner
Machine is still saying to exchange toner because toner is not feeding into the machine. to supply the toner always do this, 1-insert the new toner bottle in the toner section and close the cover. 2-Press "Utility/Counter" Button. 3-click on "USER CHOICE" or "USER SETTING" 4-click on "Toner Supply" 5-Toner bottle will start moving and hence the error message will not appear again.
Oct 27, 2009 | Minolta bizhub 200 All-In-One Printer
Dcp 7020 and 7040 toner life end message premature, need override
When the Toner Life End LED flips on, requires you to replace the cartridge, even when there's still toner left in the cartridge. The machine detects end of life by shining a light through from one side to the other.
To circumvent the detection mechanism, remove the cartridge and put a piece of masking tape over or jam a little bit of paper into the clear opening/circle on the right side of the toner cartridge, and then pop the cartridge back in. Eventually, you'll start seeing streaks, and then you'll know that the cartridge is truly empty.
Jan 17, 2009 | Brother DCP-7020 All-In-One Laser Printer
The add toner light stays on with a new toner cartridge
Yes, the machine will only make single copies if the toner light is on. Was the toner cart genuine Copystar? Or perhaps Kyocera cart? The machine is made by Kyocera and marketed under both name brands, however, the toner carts are different for both machines. I have seen many times that aftermarket carts will not always work properly.
Jan 06, 2009 | Copystar CS-1510 Copier
Canon Copier Model C122F - error light flashing
A common mistake is that people think that the waste toner needs to be emptied and instead the toner needs to be replaced --- and vice versa. Check to make sure that the toner bottle is not empty. Also, if you made copies that took ( used ) more toner then the machine was able to replenish, the machine has not had a chance to catch up. Place a white sheet of paper on the platen glass and make blank white copies. You may only be able to get 1-2 copies at first but as the device catches up with the toner replenish you should be able to make more. The blank copies you make -- do NOT put that paper right back into the machine. Lay it flat and let it cool, this will help prevent unwanted jamming due to heat build up in the paper. IF you have good amount of new toner in the machine, gently tap the front line ( or rear line) that feeds the used toner into the waste bottle. Sometimes the waste toner will clog and back up into the machine giving false 'waste toner full' message.
Jan 04, 2009 | Canon Office Equipment & Supplies
After replacing the toner cartaridge, the error light comes on. In the little box, it says toner is not set. Insert toner. I have readjusted it several times. It seems to be set solidly. The problem...
You have to:
1. take paper out.
2. remove the toner
3. place the toner back
4. printer will "initialize" itself.
5. put the paper back.
Totally crazy!!!
Jun 30, 2008 | Office Equipment & Supplies
Cyan Toner always prints faded.
It is the developer. All colours should be changed at the same time. This can be accessed via the right hand side of the machine, when you remove the cover. (where the output tray is)
Feb 06, 2008 | Xerox DocuColor 12 Color Copier
Brother IntelliFAX 4750 Plain Paper Laser Fax Logo
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
