Question about SanDisk Sansa e260 MP3 Player
Sandisk carnt delete music 2 add from wmp
  • 758 Answers
You have to make sure that the device is on MSC mode...then make sure your device is plug in to the computersandisk - 1.gif..Then go to programs - accesories - windows explorer, find the SanDisk in my computer, go to media, music and delete them from there.
Either under sync pane in windows media1.gif player it will show your music when it's connected. just click the plus signs for what song you need to get rid of, right click and click delete.
Hope this helps
If you still not able to delete it let me know so I can have you try something else...
Please rate accordingly...
Thank You
Computerrep
Posted on Mar 24, 2008
Want to add different music delete the music I have
Most of the mp3 players out there are compatable with Windows Media Player on your pc. Open WMP and then connect your mp3 player to your pc. If it is compatable it will recognize it. From here you can delete any songs that show up on your mp3 player and also add to it from your library that you build in WMP. The manufacturer may also have software for it but if it does work with WMP I would stick with that. Hope this helps ...
Apr 09, 2010 | iLO (2 GB) MP3 Player
How do I load music from cd to mp3
First you must compress the CD to an Mp3 format. You can use a multitude of programs to do this. I find that it is easiest if you are new to just use Windows Media Player. You can tweak it by adjusting your preferences as far as the compression. I think it defaults to WMA format @ 128kbs. You can change this to Mp3 @ whatever kbs you want ... remember the higher the kbs the higher the quality of the recording .. you can compress up to 360kbs which is what I would recommend. Although the file will be much larger. Anyway open WMP ( Windows Media Player) ,,, and if you don't want to change any of the setting just insert the cd into your computer... It will show up in your WMP and ask you if you want to add to Library. agree and add it to your library.. from there you need to connect your Mp3 player to your computer. Add the songs by highlighting them and adding them to your sync list.... when you are done adding the music you want to the list click sync and this will add it to your mp3 player... Sometimes you will find that WMP doesn't recognize the player.. I believe you can hit F5 key and it searches for the player ... Sometimes it works sometimes you have to start over by reconnectin your player to the pc.. Mess around with it .. you can always delete the music off of your WMP and start from scratch... hope this helps
Oct 22, 2009 | SanDisk Sansa Clip MP3 Player
I cant find place to add music files to my player, SanDisk Sansa m240... I go to my computer open the files and find no music library
use windows media player... open WMP connect your player it should recognize it... use this to sync music to your sansa...you highlight the songs in WMP right click ... go to add music .. select sync .. once you get the songs into a sync list ... you just sync the sansa...
Oct 16, 2009 | SanDisk Sansa m240 MP3 Player
Album art does not transfer with music on my sandisk mp3 player
Go to the sytem Settings menu and go to this option:
Display Art in Lists
Enabling this feature displays a small image of the song album cover, audiobook
cover, and photos when scrolling through list of these items.
1. Scroll down to Display Art in Lists and select it.
2. Use thumbwheel to switch between On (enable) and Off (disable).
If changing this option to enable fials to resolve the issue, the solution is a bit painful: You will have to manually add the artwork to each single song within an album in Windows Media Player 11, delete the song that is missing the artwork off your sansa, and re-add the songs again after you are done manually ediitng the artwork.
Manually add album art (WMP 11)
1. Run WMP.
2. Click Library on the top bar.
3. Select and right-click the file(s) you wish to update and select Advanced Tag Editor.
4. Click the Picture tab, then click Add.
5. Navigate to the image you wish to use for album art then click Open.
6. Click Apply then OK.
Mar 25, 2009 | Audio Players & Recorders
Sansa E270 Blank Screen and Bad Tracks
well if you can still connect it to your computer just format the mp3 this should work after the format just go to WMP and sync your music
Formating:
1. connect mp3 to computer
2. got to "My Computer "
3. find the mp3 in the computer
4. right click on the mp3 drive
5. click on "Format"
6. click on ok
note : formating will delete all picture,songs, and videos on the device
Oct 30, 2008 | SanDisk Sansa e270 MP3 Player
Sansa e260 won't accept songs
Hi Janworks4u. Question for you... Did your mp3 work fine with WMP 10? I ask because WMP 11 is known for causing problems w/mp3 players. You can try reverting to WMP 10 to see if that fixes your problem. To do this:
click START, click on CONTROL PANEL, ADD OR REMOVE PROGRAMS (look at the top center of the Add or Remove Programs box that pops up for a little square you can click on that says "show updates." Click that box and then scroll down to WMP 11. Click to change/remove. A box will pop up confirming that you will revert to WMP 10. NOTE THIS WILL NOTE DELETE ANYTHING FROM YOUR COMPUTER! All of your music that is in WMP 11 will still be there in WMP 10!
Now you can try to load your songs back on through WMP 10 and hopefully it'll work for you. Good luck!
Sep 29, 2008 | SanDisk Sansa e260 MP3 Player
Cant remove songs
try opening it up in rhapsody or windows media player and delete the songs through there.:
  1. open either rhap or wmp
  2. the devices should be in a tab to the left (rhap) or on the top (wmp)
    1. for wmp, it might be in a tab in a tab
  3. click on the music "+"
  4. and from there delete the music
Apr 23, 2008 | SanDisk Sansa e250 MP3 Player
Carnt delete music from piece of **** to add new
You have to make sure that the device is on MSC mode...then make sure your device is plug in to the computer1.gif..Then go to programs - accesories - windows explorer, find the SanDisk in my computer, go to media, music1.gif and delete them from there.
Hope this helps
.Please rate accordingly...
Thank You
Computerrep
Mar 22, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e250
Do you know if windows media player recognized your device? if windows media player does, i would recommend you to format the device using windows media player...to format your device have it connected and open up WMP,click on the sync tab the your device will be listed on the left side..then all you have to do is right click and format the device..that should work..
Jan 03, 2008 | SanDisk Sansa e250 MP3 Player
Won't let me play my music files
Do you have a subscription with Rhapsody or Napster?
If so, you need to log in for them to update your account, which will solve it.
If not, did you use your own music from CD's? Did you use Windows Media Player to copy the music to the computer? Did you change the default settings in Windows Media Player?
If so, the default settings for WMP are to "copy protect my music", which will give you this error. You will need to change the RIP Music settings in WMP. Tools>Options> un-check the copy protect my music option.
Finally, if you have the "Rhapsody" version, there is pre-loaded music on it that if not deleted, will cause this problem. You can format the device to remove the pre-loaded music, or manually delete it from the System folder.
Please add to the question if that didnt work.
Best of Luck.
Nov 07, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
