Toshiba TV won't stay on
When I turn on the tv, the red light goes on, then off immediately. If I use the reomote the same thing happens, but if I hold the power button down, the tv will go on and stay on unitl I release the button. Then, off it goes.
  • takiayanne Aug 07, 2008
    when I turn my tv on it won't stay on. It goes right back off.
5 Suggested Answers
budmrtn
  • 11361 Answers
SOURCE: viewsonic n3752w will not power up.
You may have bad main logic board, http://www.shopjimmy.com/catalogsearch/result/?q=n3752
The back light is working for sure, you may want to check if the Power supply on signal goes to 5v when you push the power button.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Posted on Jun 30, 2010
  • 16 Answers
SOURCE: TV won't turn on.
The problem is the digital main board if you can get ashop to order it for you its easy to replace yourself four screws and three or four plug in connectors.
Posted on Oct 25, 2008
  • 157 Answers
SOURCE: Akai LCT3285TA Television won't turn on
the problem is in the power supply(they know about it good luck fighting them)but there is good news.you can remove the power supply and replace electrolytic caps,EC18,EC19,EC20 all of them are 1000mf at16 volt use 1000mf at25 volt.you can also go to shopjimmy.com enter model number you will see power supply part number MLT169B
it will be cheaper for you to replace the caps,the board cost about $80.00 from them
Posted on Sep 24, 2009
Testimonial: "Dale Hunter's response was completely accurate. I replaced the three capacitors that he identified. And it has been working fine since 2009. Now I have the black screen problem. Help me Dale."
  • 8457 Answers
SOURCE: My Panasonic TH-42PZ700U 42in. TV doesn't turn on
Power supply board have dead capacitors.U know how to solders?Buy these capacitors to replaced them to have power back.Or u can buy a whole power supply board for the replacement at these websites Shopjimmy.com,Ebay.com for refurbish power suppply board.
Posted on Mar 04, 2010
toolkits
  • 1099 Answers
SOURCE: LG 32" Plasma TV power-on problem
Your power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
hope this helps...
Posted on Jul 02, 2010
PN50B550T2FXZA won't power up
The continous red light merely means power is getting to your TV. From your description, it is likely the internal power supply has failed
Dec 31, 2012 | Samsung Televison & Video
I have a 3year old Sharp TV. It won't turn on like it should. I turn it on and the red light goes out and it stays out. Then it comes on again. I turn it on and the red light goes out. If I am luc
Power supply or something in the set not allowing supply to come up, not likely to be a do it yourself repair---consider having a tech or a shop look at the set.
Aug 31, 2012 | Sharp LC42SB45U 42 in. LCD TV
TV won't turn on. red light blinks twice and nothing happens
This is an error code of some fault inside. Kindly call in a qualified service technician.
Jul 25, 2012 | Magnavox 32MF301B LCD TV
I have a 20" flat
bad luck :(, problems is with the motherboard power circuit no option you need a repair sorry
Jan 31, 2011 | Philips Televison & Video
Tv won't turn on. red power light is out
red light is on, but when the tv is turned on, it immediately shut down and goes back to the red light setting. It is like it blows a fuse or something to that effect.Post Solution
Mar 02, 2010 | LG 50PC3D 50 in. Plasma Television
Status light stays red no tv no power light
TV requires service. but try to reset it by pressing system reset
Apr 17, 2009 | Mitsubishi LT-52244 TV
TV won't turn on Sylvania LC320SL8 - 32'' LCD HDTV
will turn on tv with remote. stays on green for about 1 second and goes back to red.
Nov 11, 2008 | Televison & Video
TV won't turn on.
Jun 30, 2008 | Sylvania LC320SS8 32 in. LCD Television
Televison & Video Logo
385 people viewed this question
Top Televison & Video Experts
Electro Med Services...
