Jaguar s type
I need to find out how to remove the door paneling on my passenger side door to adjust my window that came off track?
    Champion:
  • 210 Answers
Call a import specialist in the area near you.
Posted on Mar 23, 2008
Passenger door window not on track
There are no tracks on windows
On the verticle sides you have window guides
Inside the door is a window regulator & motor assy
that puts the glass up or down
Have to remove inner door panel to see what needs
replacing
Do not just put it back together it won't work a day
Some have cables some have a sizzor type mech
Nov 19, 2012 | 2000 Dodge Caravan
How to remove inside door panel, passenger side, to look at window track
Screws in the door pull under the rubber matt - then poppers all around the door edge. when panel is loose look carefully behind and disconnect elec plugs for windows and speakers. Then carefully work the door panel over and past the door release handle - this is tight and can be awkward take your time. The window mech. often breaks as it is plastic !! order a new mech but keep your motor as this is a separate item to buy! the lifter is released by a plastic pin to the glass mount - you have to push it out - again awkward - take care with this
hope this helps - good luck !
May 22, 2011 | 2001 Jaguar S-Type
2000 jaguar s-type driver window will not roll up or down. How do I remove the door panel to put the window back on its track?
On the inside trim, you can remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge. Pull back the weather seal and you'll be able to see the motor, regulator, guide rails
Sep 10, 2009 | Jaguar S-Type Cars & Trucks
Driver window on 2000 s type jaguar off track
You will have to remove the screws to door panel, remove window and lock controls. Then gently pry the plastic studs out of the door and lift the panel up and off. You will now have access to track and window
Sep 10, 2009 | 2000 Jaguar S-Type
2005 Lincoln ls front passenger window won't go up. it will move 1/4 inch up when switched, but no more. What is the most probable problem?
Window is jamming in track and needs adjusting Door panel needs to be removed and tracks adjusted Not a biggie
Jul 09, 2009 | 2005 Lincoln LS
My power window came off track
There are 2 screws just above the door handle you need to remove. Remove the plastic trim around door handle. Then starting at bottom of door panel pull out to disengage the push pin clips and work your way up both sides of panel. Then lift up on door panel to disengage the weatherstip on top of panel.
Feb 10, 2009 | 1998 Ford Explorer
Door window on 2000 jaguar s type
take off inner door panel, lower track and put the window back in. If parts on track are broken buy new ones. Use urathain to reinstall window.
Jul 28, 2008 | 2000 Jaguar S-Type
S type
remove door panel adjust window so you can see the mounts the window is attched to remove screw's/ bolt's lower window lift up at angle and pull out slowly don't hit glass on edges will break .
Jul 10, 2008 | 2000 Jaguar S-Type
Jaguar rear window removal
I followed the instructions given by your expert Richard.His instrutions were clear and precise,and I had the problem solved in 5 minutes.best regards A.Taylor
Jul 02, 2008 | 2000 Jaguar S-Type
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
