Question about JVC KD-NX5000 Car Video Player
Say how r u doing
Well i boute the jvc kd-nx500 but cant hook up the gps system i dont know where the speedometter wire is on my car can u helpme
You'll need a manual for the car and/or the electrical diagrams to determine the correct wire to use.
I spliced it in right behind the instrument cluster on my BMW. Same with the parking brake wire.
Posted on May 02, 2008
Steering wheel controls
JVC radio doesn't work directly with car's steering wheel control. You need an adapter. Metraonlie.com offers pretty reliable ones.
Aug 25, 2013 | JVC KD-G230 CD Player
Where do you connect the memory wire on a jvc kd g110 car stero.....what color is the memory wire ?? what does hook red wire to acc fuse mean??? what wire does the red wire on the radio connect to on...
The yellow wire is most likely the memory wire as it needs to be connected to a constant 12 volt source.
"Hook red wire to to acc fuse" means you need to hook into the fuse block under an Accessory Fuse. (ie: something that can't be turned on unless the car is running or the key is in the "Accessory" position)
The red wire is explained above. It does not connect to the harness.
Just remember that the yellow wire needs to be hooked to a constant 12 volts and the red needs to be hooked to a circuit that is only active when the car is running or switched to the "ACC" position.
Mar 02, 2011 | JVC KD-G110 CD Player
My manual is gone and i dont know where to connect this brown wire, blue wire. orange wire. red wire. yellow wire black wire. may you give me the details where to connect these wires pls,,
Here is a link to the manual that will ID all the wires for you and what they do.
If your not 100% sure of what to hook up or how to hook it up, visit a quality car audio store in your area and have them do it for you.
http://resources.jvc.com/Resources/00/00/94/GET0247-002A.pdf
Feb 04, 2011 | JVC Arsenal KD-AR760 CD Player
Ooood ao on display screen
you probably already solved your problem by now, or you probably have a different stereo, but in case you haven't let me tell you what I just did. you just have to reset you system, to do that you take off the front part and stick a pen in the reset hole. The reset hole is in the lower right corner.
Oct 02, 2008 | JVC KD-S640 CD Player
Promblem wiring to my car
GO TO WWW.CRUTCHFIELD.COM AND THEY WILL SELL YOU AN ADAPTER SO YOU DON'T HAVE TO CUT ANY WIRES ON YOUR CAR
Jun 19, 2008 | JVC KD-SC800 CD Player
Help with installation for car audio jvc model no. kd s585
HOW TO HOOK UP A JVC CAR CD PLAYER TO A 1993 COUGAR
Jan 12, 2008 | JVC KD-S580 CD Player
Install in 2000 Neon?
Hi Siriusearl,
If the original connector and wires are not messed up and your doing a direct replacement of your Factory Radio, your in good shape. Go to Best buy and get you and adpater to go from 2000 neon. If you have the one that direct couples and leaves wires to terminate to the JVC, then you will have to hook up by standard hookup colors. And it should be color to color from JVC to the Adapter cable. If your still have trouble, leave another comment here and I will get an alert to check in on you.
Nov 13, 2007 | JVC KD-S570 CD Player
JVC KD-NX5000 Car Video Player Logo
113 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
