Question about Mitsubishi VS-5043 50" Rear Projection Television
Words at the bottom of the screen
The words aat the bottom of the screen are below the picture. what can I do?
  • lazybones13 Mar 22, 2008
    the picture iis too high and too low
  • 871 Answers
You can try adjusting that using the picture adjustment. vertical and horizontal convergence is another thing so dont try to touch those.
to follow up, when did this started happening? have you or anybody touched anyti\hing on that tv?
Posted on Mar 22, 2008
  • 4,889 Answers
See if you have a button called ARC on your tv remote.. you will have different modes called Wide, Zoom, normal etc., Just put it in normal mode!
Need to get into control panel to change settins
Click on the triple bar, below the X in the upper right corner of your screen...... a drop-down menu will appear........click on the word "settings" near the bottom of the drop-down menu........if you can't find the settings you're looking for.........scroll down to the bottom of the screen until you see the words "advanced settings" (in blue).......click on the words "advanced settings" and additional options will appear below.....continue scrolling down until you find the settings that you want.
Apr 03, 2014 | Acer C7 Chromebook
How can I take a screenshot on a Dell XPS 10?
Hello Helen,
Windows 8 and Windows 8 RT use what is called the "Snipping Tool" to take screenshots. The "Snipping Tool" was introduced in Windows 7. AAt the link below is information on how to take a screen shot using this feature. If you have any further questions you can email me at my email address listed below.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
email jesse_leonard@dell.com
Using the Snipping Tool to Capture Screen Shots
Apr 13, 2013 | Dell XPS Computers & Internet
Picture seems to big for TV.cant read bottom words on screen and words are cut off on side also. Cant see scrores on any sports or read peoples names on bottom of the screen
Using the menu or settings button on your remote, access the TV's menu and find the area for picture settings and zoom. You're likely set to a zoom mode, so cycle through the options until you find the zoom setting that sizes to your TV best. (On most widescreens, the best picture is often on the setting 'panarama.'
Mar 12, 2011 | Vizio L37 Television
The words "Digital Noise Filter
The words "Digital Noise Filter Off" and "digital Noise Filter On" appear on the top left and right and side of the screen and the words " Auto Visulisation" appear on the bottom of the screen all the time when watching normal T.V.(series 5 lcd) and if we make changes regarding in setting in picture option in mode.then after 20-30 min againg it displays same message
Feb 01, 2011 | Samsung LE40R74BDX 40 in. LCD Television
Can't see words on the bottom of the screen
Go to menu and hit the adjust screen. That should do it.
sawrepairman
Jul 23, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
How to fix when out of focus?
These sets have several common problems which are listed below.
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find the fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 03, 2010 | Panasonic PT-51DX80 51" Rear Projection...
My toshiba projection tv just started having problems. at the bottom of the screen the colors are not alignedand words and pictures are duplicated at tbe bottom of the screen
Try adjusting the convergence. If it won't move see below- (or hitting Magic Focus for some Hitachi’s)
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Oct 22, 2009 | Televison & Video
2004 dodge grand caravan. check eng light.. rotated key on and off 3 times seen code 0073 where mileage would of been then dotted lines then the word done...??
Trouble Code: P0073
Ambient Temperature Sensor Circuit High Input
Possible Causes:
AAT Sensor signal shorted to VREF (5v) or battery voltage
AAT Sensor signal circuit or Sensor ground circuit is open
AAT Sensor is damaged (it may be open)
PCM has failed
Aug 27, 2009 | 2004 Dodge Grand Caravan
Fuzzy pics
Go into your camera. At the bottom of the screen, on the right side, the word options shows. Press the blue dot below it and set the effects for whatever you want.
May 22, 2009 | Motorola Mobility W375 Cellular Phone
Picture too big for screen
GO TO MENU VIDEO SETTINGS AND RESET TO FULL FORMAT SETTING , GO TO JVC.COM AND DOWNLOAD THE OWNERS MANUAL GUIDE ,
May 16, 2008 | Televison & Video
Televison & Video Logo
48 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
