DVD Drives I have two (2) DVD drives... when I boot up, neither load. In the device manager, they have an exclamation mark on them... check the properties, the comment is the drivers did not load, ran an update on drivers and still the same. Deleted them, ask the computer to find new hardware, nothing happened... went to "regedit", searched for "lowerfilters", deleted everything that came up in the boxes, nothing happeded... HELP!!
  • 4,889 Answers
FIrst of all does the unit power up? What happens when you press the eject/load button? Does the LED infront of it blink? Please answer these questions so that we can zero in on the exact cause...
Posted on Mar 22, 2008
SOURCE:
DVD will not read any type of disk.
If there is an EXCLAMATION Mark for the DVD, the device could just be failing on you.
Mar 05, 2014 | OEM Systems Dell Xps 15 L502x L501x Blu...
Won't Boot Windows 7 disc
It could be a problem with the cd/dvd drive
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver You might have to physically unplug the leads for this cd/dvd computer then plug them back in restart your this should activate the found new hardware wizard. If this does not fix the problem it might be a registry problem "you only need to do the following" if you cant see your disk drive in windows explorer Close all open programs Click on Start, Run, and type regedit and press Enter Click on the plus signs (+) next to the following folders HKEY_LOCAL_MACHINE SYSTEM CurrentControlSet Control Class {4D36E965-E325-11CE-BFC1-08002BE10318} This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column. Upper Filters Lower Filters Upper Filters.bak Lower Filters.bak If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. if this fails to fix the problem
It could be a problem with the lens you could use a liquid type lens cleaner place 2-3 drops on top of a cd/dvd then run it
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or the F2 key Press and hold that key during the boot up process to enter BIOS the using arrow key scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system (note after you have loaded the operating system you should go back and change the first boot device to your failsafe or optimized defaults) after windows has loaded your computer will automatically restart it might restart 2 times one to finish the installation the next will be because the operating system is loaded and will boot from your cd during the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart otherwise it will keep booting from the cd /dvd drive Hope this helps.
Jan 04, 2013 | Western Digital (WD5000YS) 500 GB SATA...
Need drivers for cdrom
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver if you physically unplug your cd/dvd then plug them back in restart your computer the found new hardware wizard should activate if you dont have motherboard disk you will need to download the drivers http://download.cnet.com/dvdram-en-20071009085435-zip/3000-2110_4-172943.html http://download.cnet.com/dvdram-en-20070907111350-zip/3000-2110_4-170034.html http://download.cnet.com/dvdram-win2k-5025-en/3000-2110_4-172950.html http://download.cnet.com/adaptec-udf-reader-driver/3000-2100_4-10021086.html Adaptec's UDF Reader enables MultiRead CD-ROM drives to read UDF-formatted CD-R and CD-RW discs (such as those written with DirectCD) under Windows 95/98/98SE/NT 4.0/2000. Hope this helps.
Dec 28, 2012 | Gateway GT5678 Desktop PC
My dvd rom is not working becouse an error in driver HPDVDRAM GS30
Optical drives are more forgiving.
Make sure it has power (ejects). Check Device Manager in Safe Mode by pressing F8 during boot. Right click My Computer > Manage. Select Device Manager > View > Show Hidden Devices. Now delete all DVD/CD-ROMs and reboot. Windows will say "New Hardware Found" and install.
Dec 12, 2012 | HEWLETT-PACKARD HP ENVY 15 Series Notebook...
Dell latitude c800 is not booting
wont boot or wont boot from cd rom ? its posted in cd rom questions
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Sep 07, 2012 | Dell Computers & Internet
Windows wont load
or if you mean you are having problems with the cd rom
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
hope this helps
Aug 24, 2012 | Dell LATITUDE D400 D500 D505 D600 D800...
In process of upgrading xp to vista, emachingW2040- following on instructions computer crashed during partion. screen frozen in bios. cant boot up. no cd to boot. help
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
hope this helps
Aug 12, 2011 | E-Machines emachines (emachinees) CD-ROM...
Not detecting windows xp booting cd vista booting dvd detected but showing size 0 canot creat patition what io
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
hope this helps
Jun 29, 2011 | Fujitsu (MHT2040BH-50PK) (mht2040bh50pk)...
Hello, my name is nike. i have a problem with my hdd. when i turn on my pc it's always "primary master system disk fail" can you help me with my problem. and when i press f1 it's always...
make sure all leads that are attached to your cd/dvd have secure connections and are not faulty or just replace them they are probably old and faulty ?
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Master/Slave designation is determined by jumpers on IDE drives. Most drives have adequate markings on them to identify these jumper positions. If not marked clearly, you will need the manufacturer's data to determine that designation.
If you are curious about a working system just power-up in set-up mode (usually by depressing (f1-or-f2) during boot-up sequence, your system-bios will display this information for you.
Apr 20, 2011 | Samsung (SP0411N) 40 GB Hard Drive
Dvd driver shows yellow excclamation mark error code 41computer novice any simple suggestions would be appreciated
"Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)"
Because of this error, the drive did not show up in My Computer and the customer was unable to burn CDs or read any CDs.
I uninstalled the drive from Device Manager, rebooted the computer, and the problem remained, so obviously it appeared to be a registry issue that I would have to solve. If you are receiving this Code 39 error and your CD or DVD drive is missing and has a yellow exclamation mark in Device Manager, I hope this information is useful.
To solve this Code 39 error, follow these instructions:
NOTE: After removing these registry keys and rebooting, it may be necessary to reinstall any CD or DVD recording applications.
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
* HKEY_LOCAL_MACHINE
* SYSTEM
* CurrentControlSet
* Control
* Class
* {4D36E965-E325-11CE-BFC1-08002BE10318}
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
* UpperFilters
* LowerFilters
* UpperFilters.bak
* LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the Registry Editor
7) Reboot
your computer
8) Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone
Regards,
Pp
Dec 02, 2009 | Computers & Internet
Open Questions:
Computers & Internet Logo
87 people viewed this question
Ekse
Alun Cox
