Cars & Trucks Logo
Posted on Apr 20, 2010
Check engine light flashing runs rough not firing on all cylinder2000 lincoln navigator with large triton engine Hooked up diagnnostic and it said 1. system too lean bank #2 2. Unable to bleed up fuel tank vacuum 3. system too lean bank # 1 4. cylinde # 3 missfire detected 5. cylinder # 4 missfire detected 6. cyclinder # 2 missfire detectd I installed a new mass More 2000 lincoln navigator with large triton engine Hooked up diagnnostic and it said 1. system too lean bank #2 2. Unable to bleed up fuel tank vacuum 3. system too lean bank # 1 4. cylinde # 3 missfire detected 5. cylinder # 4 missfire detected 6. cyclinder # 2 missfire detectd I installed a new mass air flow sensor but did not correct problem Can some one please help me with this problem George email address [email protected] See less
  • Anonymous Mar 13, 2014
    ford lincon engine missfire detected on start up
  • Anonymous Mar 29, 2014
    navigator
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 12, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1066
Points
This could be a bad cam sensor that hasnt gone yet. It would explain why you are running to lean.
98boxster
Level 1:
  • Contributor 20 Answers
  • Posted on Apr 20, 2010
98boxster
Contributor
Level 1:
Answers
20
Questions
0
Helped
13863
Points
47
You may try your rotor button and distributor cap. and spark plug wires. try your map sensor also they tend to cause a lot of misfiring if they go bad.hope this helps.
2005 Lincoln ls runs in idle but rough and when pushing gas pedle rpm drop.
Do you have a check engine light flashing when it runs rough?
Was driving the 2010 Nav at interstate speeds, heard loud pop and check engine light started flashing, engine running rough, lost power. Changed plugs, checked cat. converter, any ideas?
Have the codes read before putting any other parts on. Flashing check engine is a critical warning that something serious is wrong. You could spend thousands throwing parts at it and never fix it.
How to factory reset the main motherboard computer on a Lincoln Navigator 2000
If you have a check engine light lit , there is a DTC - diagnostic trouble code set in the PCM / ECM -OBD 2 engine management system computer . If you don't fix the problem the light will not go out , you need to have a scan tool hooked up to check codes an go from there !
2helpful
2answers
Rough idle, acceleration and check engine light went from being on to flashing on and off
Use a ODB-2 meter to read the problem code. That will give you a clue on what to look for next.
Engine running extemely rough as if on 4 cylinders. Transmission is shifttinf rough from drive to reverse and back again.
The trans is shifting rough due to the engine issue. Is CEL light on? DTC codes?
Check Engine Light flashing or solid on?
My check engine light is flashing, the car runs rough until I get up to about 30mph and it is running through gas like crazy
Sounds like you have cylinder misfire. Any of the large auto parts stores can run an OBDII check and tell you which cylinder is misfiring (not firing). The engine is running with one cylinder out causing the rough idle. The faster the car goes the less perceptible the misfire is. That is why at 30mph the car seems to run smooth.
2helpful
take of the fuel filter and blow it out. i had the same problem with a 2008 ford f150 5.4 v8.
98 Lincoln Navigator Check Eng light on
fuel pump is going out causing the truck to run lean and miss
Need help w/1998 Navigator
Coil Pack or coil packs are bad there is 1 for each spark plug
Top Lincoln Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Lincoln Expert? Answer questions, earn points and help others
