I have a 8 month old Toshiba tv. When I either push the power button on the set, or the power button on the remote, the set turns on, then off again. If I hold the remote power buttton down, the set comes on but goes off the moment I release the button.
  • gingerartist Mar 22, 2008
    I was hoping there was somthing I could do to fix this problem. it would be very difficult for me to return the set.
    Genius:
  • 1,153 Answers
8 Months call Manufacturer and let them know,or just take back to store. You should have a 1 year Warranty.
Posted on Mar 21, 2008
Ge 24912 universal remote code for toshiba
Note: most remotes allow you to find the code by manually turning the TV (or other device) on first, then press the appropriate button (cable, DVD, surround, etc) then setting the the remote in the "program" mode, then keep pushing the "off/power" button until the TV (or other device) turns off, at that point the code is set.
Feb 23, 2014 | GE 24912 3 Device Universal Remote...
My tv has a red button on the front that flashes and no picture comes on when we try to turn it on with the remote
The Toshiba sets were well known for bad capacitors in the power supply. I recommend getting it assessed.
Mar 19, 2012 | Toshiba 32AX60 32" TV
Toshiba 26AV600T When turn off by remote control ( stand by lamp still illuminate) I can not turn on by remote ( ON/OFF in the same button ) Q: TV set OR remote is bad. Thank you /// Thongsuk. My Mail:...
Tries the tv manual control power button pushes a couple of times on/off,if tv it turn on and off with no problems.Yes.Than the tv remote have problems.Try Remotes.com to buy the original remote.
Jul 13, 2011 | Toshiba 26AV502U 26 in. LCD HDTV
I have an old remote that works for a VCR and I did have it working for the TV but one day someone was playing with buttons and it stopped working. I was wondering how to program my Toshiba vc 260 remote...
Try the following procedure:
1. Make sure there are working batteries in the Toshiba remote control.
2. Turn on your television set, DVD player or other device that you want to control with the Toshiba remote.
3. Find the "Recall" or "Setup" button on the Toshiba remote control. After you find it, press and hold down that button until the lights on the remote control turn on and remain lit.
4. Point the Toshiba remote at the device you turned on in Step 2 and press the button on the remote for that device.
5. Begin pressing the "Power" button on the Toshiba remote. Continue doing this until you have turned the device off using the Toshiba remote. Once it shuts off, press "Enter" on the Toshiba remote. The remote will then be programmed.
Feb 28, 2011 | Toshiba Vc-260 Remote Control
Hello, My tv is not responding to the remote. Cannot change channels or do anything with TV because of this. TV is a month old
solution 1: try pushing the buttons on the tv, manually, and if that doesnt work, call someone to look at it, like a handyman or geeksquad
solution 2: change the batteries in the remote
Jan 30, 2011 | Toshiba MR120 Remote Control
My remote control is a model CT-90233. Several of
your remote is old and needs to be cleaned and rebuttoned(you can do this yourself) open up the battery panel and look for small screws to take of the case. you need to dust it out with compressed air. and reline the buttons. when you push down on the power button it probbaly is not making complete contact with the button, take a small thing and poke the power button without the buttons on. see if that works. if it turns on right away with direct pressure to the power switch then you just need to make sure your buttons are making complete contact. if that dont work then your circuit is screwed. you need a new remote or a new tv.
Feb 16, 2010 | Toshiba 32A30 32" TV
My tenplus year old Toshiba 32" TV is stuck in standby mode
You have an old tv so the best problems are bad capacitors and bad grounds. Have someone pull the board and search for high voltage caps [160volts or 250 volts] with 1 to 4.7 microfarads. Should be two or maybe three and check all grounds. If the 4 amp fuse is good than the above will save your TV.
Sep 24, 2009 | Toshiba 32A33 32" TV
TV locked with blue screen
Try resetting the TV to factory settings thusly:
Turn on the TV. While holding down the RESET button on the remote
control, press the POWER button on the TV. (The TV will turn itself off, then
back on again.) Release the RESET button.
Owner's manual available here:
http://www.docs.sony.com/reflib/docget.asp?manualid=9635&template_id=1&region_id=1&DL=
Mar 02, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Toshiba 46H84 turning off by itself AND all BLUE screen with Black Dot in Center
Try to replug everything in the TV. Before you turn it on. make sure all plugs in the TV to the wall is plug in tight. When you turn your TV on hold the power button down to see if it resets
Feb 28, 2017 | Toshiba 46H84 46" Rear Projection...
How to use Toshiba 32D46 32" TV with Comcast 3 in 1 Universal Remote Control
Most univ. remotes have a search mode if code entry won't work-
Do you have the comcast instructions ? Something like.....
1) Tv power on
2) Push set-up or program on remote
3)Touch tv button on remote
4) Point remote at TV and push power off. Repeat until TV turns off.............then
5)Push enter to save....
Hope I helped you........T.
Nov 07, 2007 | Toshiba 32D46 32" TV
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
