Goodmans pdp42tv006 plasma,comes on for 15 secs then shuts down power led blinks red constantly until power is switched off,when power restored does as above many thanks if you could shed some light on it, bullis@btinternet.com
    Scholar:
  • 34 Answers
Bullis,
This is a common problem on these plasma TV's. The problem resides in the high voltage boards known as the X and Y Sustain boards.. You can purchase them here for a very reasonable price:
http://www.discount-merchant.com/Y-SUSTAIN-FOR-42-PLASMA-TV-PN-6871QYH036A-p/sku9510.htm
The above link is to a Y-SUS board. The X-Sus board is often the 2nd cause of failure and can be found here:
http://www.discount-merchant.com/X-SUSTAIN-6871QZH041B-6870QZE017D-6871QZH052D-p/sku9509.htm
To test which board is failing, you need to check voltage input to the YSUS board first... Input should be 120V from Power supply, output should be above 250V.. Do this test with XSUS disconnected. IF 250+V exists, then XSUS is damaged. If not, then the YSUS is the faulty part.
Posted on Oct 16, 2009
How do i fix/repair 6 blinks sony bravia LCD KLV-46Z450A & shutting down problem?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
May 20, 2015 | Sony Televison & Video
Tv is coming on for brief period and shutting down also constant flashing of green led light on front of tv
I have a plasma that does the same thing. I don't know but have been told it is probably the power supply.
Jan 11, 2013 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Power in house was shut off today, when restored, the timer led light by the power switch has been blinking constantly and the power to the TV will not come on...
Thats a common issue for that model which is caused by weak DM capacitors. When the power is down the caps discharge then they cannot recharge when power is restored and the led blinks non stop. Thw WS48511 - WS65511 DM repair kit from www.tvrepairworld.com has the caps and the repair instructions which usually solve that issue.
Aug 04, 2011 | Mitsubishi WS-55511 55" Rear Projection...
My goodman furnace is blinking led 4 times i replaced both the primary and auxilliary limit switches still blinking!!!! the unit kicks on for 30-60 sec. then shuts down but fan still blows continiously...
check the flame senser connection it tight to the board and that it is clean or try looking at the fault codes again they are online you could check the air fliters are clean
Oct 22, 2010 | Goodman GMS90703BXA Heater
My hitachi plasma tv model: p55t551 every time i
turn tv on the red power light comes on then goes off again
Jun 27, 2010 | Televison & Video
42PF7220A/37 Blinking red led (7 times)
sounds like your tv in shut down mode why lamp needs 2 be replaced nominal cost 120 200$
Jul 25, 2009 | Philips 42PF7220A 42 in. Plasma Television
Power light blinking 2 times
2 blinks means the unit is having problem with 12 volt supply.
while power on you can check 12DC on power supply before shutdown.if the voltage is constant before shut down I would recommend to replace D board.
Sep 16, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Philips 42pf7321d/37 blinking power board question
The probleis with one of the maina boards and trouble shooting would have to be done to see which board is bad.
Aug 17, 2008 | Philips 42PF9630A 42 in. Plasma Television
Philips 42 in. Plasma shut down
did u cheak the input cables does it do it on dvd input as well as others ?
Feb 01, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Relays click. That's about it
try unhooking the wires coming off the power board you should be able to unhook every thing except the switch wire and se plug if the green lights stay on and the red don't come on then you have something loading down your power supply if it still shuts down you need a new power supply
Nov 20, 2007 | SVA-USA HD4208TIIIBU 42 in. HD-Ready...
Televison & Video Logo
172 people viewed this question
Top Televison & Video Experts
