WASHER problem!!!! 27inch washer/dryer user just stopped washer today even not come out water dryer is under control. what's the problem.. almost new machine..
  • dotncgirl Dec 06, 2008
    Maytag washer/dryer combo...model # LS7804. Washer won't turn on after closing lid and pulling out the knob. Spin cycle did work prior to repairman replacing inlet valve. Now even the spin cycle won't start. Nothing...no sound on any cycle, water level or temp. Dryer is fine.
  • 185 Answers
Whats the make and model
Posted on Mar 26, 2008
I JUST INSTALLED A MAYTAG STACKABLE WASHER AND DRYER AND WHEN I TURNED THE WATER SUPPLY ON THE WATER STARTED TO FILL UP IN THE WASHER IMMEDIATLY AND IT WONT STOP UNTIL I TURN OFF THE WATER SUPPLY TO THE...
Unplug the washer, if the issue continues, you have a faulty inlet water valve. What happens is particulate matter gets in and the valve jambs. If you have a new unit, the repair should be for free.
The only case where I could see water going in, is if it was requested, by user input....But front loaders use tons less water......
Feb 12, 2011 | Maytag LSE7806A Top Load Stacked...
Dryer was flooded when we had a sewer back up.
water can damage alot of the parts on the washer and dryer the motor would have been completly under water on both units and the control on the dryer would have gottin wet as a repair man anything can be fixed but to what cost
Jun 02, 2010 | Kenmore 72982 Gas Dryer
Whirpool Duet Washer Model GHW9150PW1 Control Locked
I had the same exact problem, the answer is in the User's Manual for this model Dryer, also here: The Users Manual reads: "TO UNLOCK": Press and hold the END OF CYCLE button for 3 seconds to turn this feature off. I did this and it worked perfectly the first time! My first load is drying now after months of being without the dryer (too busy to investigate!). Good luck.
Oct 26, 2009 | Whirlpool Washing Machines
How do you remove top of new washer so dryer will sit on top?
There should be 2 screws at the rear of the top section. Remove those screws and pull the top backward and it should come off.
May 19, 2009 | Frigidaire ATF6000ES Front Load Washer
Brand new(bought today) whirlpool duet sport turned on the water
Call the store and tell them what the problem is. There are ogligated to fix it or replace it for you. good luck.
Feb 01, 2009 | Washing Machines
Hotpoint washer will not stop filing with water
It would appear you have a faulty water inlet valve.
Try turning the water off to the washer. if it stops filling, then that is your problem
Replace valve or valves as required.
Please leave feedback
Dec 06, 2008 | Frigidaire FEX831CS Top Load Stacked...
Smeg WD1 12C, error code 10
I have a smeg wd1 12c washer dryer showing error code e01 any idea how to fix it?
Gilly
Nov 06, 2008 | Smeg WDI12 Front Load Washer / Dryer
Hot water
new washer valve on washers are designed to be "energy saving" most are 70/30..on warm 70 percent cold and 30 percent hot also new temp controls will reduce temp to a "safe level" by adding cold even on hot setting the on/off of water flow is being controlled by thermal sensor in water line on valve output ..in other words it's normal
Jun 09, 2008 | Crosley CAWC529JQ Top Load Washer
Maytag Washer/Dryer stackable
well i am having about the same problem, but mine won't even fill, the dryer works but the washer won't fill or turn on at all. my husband had it all apart, too the control assembly to parts place and they said that hardly ever goes bad so it is still sitting unusable with no answer or money to spend on it in site.
Jan 15, 2008 | Maytag LSE7806A Top Load Stacked...
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
