Question about Kenmore Elite 45986 Front Load Washer
Front gasket ripped
The gasket between the drum and the machine has a rip in it. Which cause water to run out on the floor. I am tepmted to fix this myself however I do not know what caused this. The tech is coming out tomorrow to "diagnose the problem even though I already told them the problem. what could have caused this and how much should I expect to pay to have this fixed. Can I do it myself???
  • 949 Answers
Typically the tear comes from something getting caught on the rubber boot or bellows as it is called on this machine. Or if a pen is left in a pocket it can cause a hole.
The bellows for your model is part number 8182119 and typically runs about $80.00
Here is a link to parts break down showing the bellows # 5 on this diagram. It is not hard to replace but you have to be fairly mechanically inclined. It is held on by a spring clamp in front and a large screw clamp to the tub.
http://www.searspartsdirect.com/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fK0503012-00002.png
Posted on Apr 20, 2010
SOURCE:
I have a kenmore elite front loader washing machine and the problem is that the rubber gasket ripped causing water leak
Nothing to do there but replace it. Call sears service with your model#, serial# and date of purchase to order one.
Nov 29, 2010 | Kenmore Elite 45986 Front Load Washer
My ge front load washer has a substantial leak when it is running. it is leaking from the bottom of the unit. It is not the drain hose or a clog in the drain. But it leaks like crazy PLEASE HELP
Check the door gasket for rips. Also there is a gasket between the two halves of the the outer drum, check that for leaks. Look at the pump housing and the hose that connects the pump to the drum for leaks.
Aug 27, 2010 | GE WSXH208A Front Load Washer
Electrolux EWF1074 front loader ripped rubber
i would get the rubber bellow replaced asap as water will be running onto components causing short circuits
May 18, 2010 | Electrolux Washing Machines
My Maytag Neptune MAH5500B has water leak problem. The water leaking out from the washer to the floor is clean and clear. So, I do not think it is drainage problem. I opened the back panel and did not...
Is the boot completely secure and not ripped or torn? The boot is the grey seal-like area that covers the drum. If it is torn at all, the water from whatever cycle, depending on when the water seeps through will end up on the floor.
Apr 11, 2010 | Maytag Neptune MAH5500B Front Load Washer
Hotpoint FEW12 washing machine chews up clothes
If you check the door sal and there is any play in it then it needs replacing. Mine had two saggy indent bits and needed changing..no more ripped clothes
Apr 10, 2009 | Hotpoint First Edition FEW12 Front Load...
GE frontloader door gasket ripped
We had the same problem, I printed off the solution posted by john_in_erie. His repair directions were VERY acurate, however we find a few helpful additions to the repairs - 1st in step #6, the spring loaded wire, is in the front of the gasket under seal (we were looking on top of machine). Also in step #8, you need a short phillips screwdriver or a 7 mm socket with a 1/4" ratchet because of the position of the screw to get around the edge of the tub.
Thank you so much John, we could have not done it without your very accurate installation instructions.
Lori & Mitch Headen
Dec 30, 2008 | GE WSXH208A Front Load Washer
KHWS01PWH0 Front Loading Automatic Washer Leaking
out the bottom of door?? no through the bottom panel???. check the rubber door seal for rips or tears pull it back and look around entire circumference. smalll rip in very front of seal where door should close against will cause leak for sure
Mar 07, 2008 | KitchenAid KHWS02RMT 3.7 Cu. Ft. Ensemble...
Frigidaire Front Loader Ripping Clothes
Frigidaire washer sucks. I'm tired of this useless machine ripping my clothes. You need to change your bellows(boot) kits around the door on front load. I have changed this kit twice now and each time, I spent $200 in repair fees. I wished I never bought this washer. Will never recommend to anyone i know.
Dec 20, 2007 | Frigidaire ATF6000ES Front Load Washer
Replacing gasket is fairly simple - need 2 people. UNPLUG FIRST - 1. Remove the plastic cover on top of machine that is mounted to back of control panel. 2. remove dispenser - push down on tab at back and it will slide all the way out. 3. Remove lower front cover by removing 3 screws holding it on bottom. 4. Remove 3 screws holding top panel on back of machine and slide cover back approximately 1 inch and lift off. 5. Remove the 3 screws that hold the control panel on - note these are different type of screw so keep track of which screw goes where - one of the screws is next to dispenser opening. Once this is done you can reach in to machine and disengage locking tab on right side under "washer temp" - have someone hold this part aside if you do not want to disconnect the cables. 6. Remove spring loaded wire securing door seal to front cover. 7. Remove the the 4 screws holding the front cover on. This item is a bit heavy so be careful. Disconnect the three door latch wire harness and place this aside. 8. On the right side of the gasket you will find the clamp screw that holds the seal to the drum - loosen this screw almost all the way and remove this wire clamp. carefully remove the two tube connections and remove the gasket completely. Take note how these were installed before removing. Now you can carefully clean the gasket seats on the drown and door and replace the gasket and reverse the steps to put the machine together. While you have the covers off it would make sense to remove and clean the pump strainer mounted on the lower cross support - this can be messy with lots of water coming out so go slowly and have plenty of towels and a shallow pan to catch the water with. HOPE this helps.
Nov 09, 2007 | GE Energy Star WCVH6260F Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
163 people viewed this question
fordexpert
Kristen Denison
Kristen Denison
Level 1 Expert
Jim Chinnery
Jim Chinnery
Level 1 Expert
