Question about Initial DTV-322 32 in. TV/DVD Combo
Model is HDTV-320
THIS SET WILL POWER ON BUT IS LOCKED UP --NO MENU ,NO SOUND ,NO PICTURE BUT HAS SNOW-WON'T CHANGE CHANNELS-STUCK ON 63 ANALOG, TRIED UNPLUGGING FOR AC,,STILL LOCKED UP,,WAS 1 MONTH OUT OF WARRANTY..THANKS FOR ANY HELP,,RICK
  • ansel_112 Dec 25, 2008
    I purchased model 320 last year, and now I have a black line straight down on the right side. At first I thought it was dirt, but its not. Does anyone know what has caused this?
    Problem Solver:
  • 7 Answers
Call 909-974-2859, they have the parts and tech support for this TV.
Posted on Sep 28, 2008
SOURCE:
I am trying to program the RCA ColorTrak Plus TV to my satellite receiver and I get nothing but snow
You will need to get a "regular" Universal remote and program it for that particular model of TV. You will need to access the on screen setup menu for the TV and then have it scan the channels. Make sure your DTV box is on and connected with the coaxial cable. If the "TV Input" button on your DTV remote works and you can get it onto the Video Channel, You can connect your DTV receiver with the RCA Cables (Red, White and Yellow) and get your picture that way. If you access the on screen menu, you will need to scan for Analog and Digital channels as the receiver transmits in Analog. hope this helps.
Sep 24, 2012 | Televison & Video
Impossible to change channels, turn TV on, Power and Opc blinking
go into programming mode and search for channels   it will do this automatically to find all antennae and all cable channels    if this is hooked up to a receiver box then only channel 3 will be found or used    also most tvs are computerized these days and at times it will need to 'rebooted'     unplug the power and wait 10 seconds and plug it in again    this may have to be done whenever you are locked out from changing channels or using the volume controls
Nov 05, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
"snow sound on all but two channels" but perfect picture
in the menu setup there is an autoprogram that sets the channels.
is there not an issue regarding analog signals?
Sep 14, 2009 | RCA F27442 27" TV
No sound on analog channels
I came across this problem yesterday. Digital channels sound... Analog no sound. press the tv button on your remote to change it from DTV/TV
go to any channel you want. press the menu button then go along to Sound setup. In there you will see quite a bit. I went down to an option in there.. it was sound input or something similar. this was set to BG I changed this to 'I' and the sound came straight back on. Hope this helps you out.
Little Dish Fitter
Sep 02, 2009 | LG DR787T DVD Recorder
No Picture and No Sound on all Analog Channels
Ur tv shouldn't set in cable mode, if u don't have pay cable,or satalite,extra..Should set in air channels.Buy a digital antena or out side roof antena u get all the channels airs.
Aug 19, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Stuck on a video mode
Some TV's disable inputs if there is no signal. I suggest confirming cables are connected properly, and accessing the system menu, and perform an autoscan for channels
Apr 27, 2009 | Initial HDTV-320 32 in. LCD TV
Audio with digital channels, no audio with analog channels
I was getting a constant mono setting for all channels with no option to set it to stereo. I called Sharp, and they said that in order to receive stereo sound, you cannot use a standard coaxial cable. You need an S-Video or HDMI cable. This not only resolves the mono audio issue but also resolves the analog (vs. stereo) issue. Hope this helps!!
Feb 10, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Can't get cable stations
you have to go into the menu and set for cable then scan for active stations.
Mar 15, 2008 | Televison & Video
Help - 15 mth old 42" edtv "plasma" black screen" have power and sound
First thing to check is if the back lighting has just failed... Power the set on and looking across the screen can you see a shadow of a picture happening? You might even use a flashlight to shine directly at the screen while you look at it from an angle.
Bill
Dec 10, 2007 | Dell W4201C 42 in. Plasma HDTV
ILO LCD Color HDTV does not change channels / volumn...just turns on/off
It's unlikely that a setting you changed in the user menu would have locked out both the remote and the panel.
It sounds to me like the micro has gone bad. One other option, is a stuck or damaged button assembly. Corrosion on the button board can lock the micro.
Nov 22, 2007 | iLO 3200 32 in. LCD Television
Initial DTV-322 32 in. TV/DVD Combo Logo
110 people viewed this question
Top Initial Televison & Video Experts
David Hoff
Are you an Initial Televison and Video Expert? Answer questions, earn points and help others
