Question about Toshiba Satellite A60 Notebook
Keyboard issues... my "s" key will not work, it's the only one. tried reinstalling the keyboard driver... no help.
    President:
  • 2,351 Answers
With the keyboard upplugged from the PC.
You can use a flat tip screw driver & gently pry the s key up working your way around the key untill it pops off. clean the surface with a lightly soapy (not dripping) rag. Pop the key back on after it's dry. If the s key still does not function I suggest you get another keyboard. You can also try this. Click the link.
http://www.microsoft.com/enable/training/windowsxp/oskturnonuse.aspx
Have a great weekend!
Mike
Posted on Mar 21, 2008
  • Mike Peluso
    Mike Peluso Mar 22, 2008
    Sorry I missed the part ( You have a Notebook ). The virtual keyboard will work for you but you'll have to have it serviced. ( the notebooks keyboards circuit layout will have to be replaced. Suggest you use a pro to replace the part.
4 Suggested Answers
SOURCE:
  • 6 Answers
SOURCE: Keyboard Problems
try pressing the num lk key
Posted on Mar 23, 2008
  • 21 Answers
SOURCE: ctrl key doesn't work
this problem is not uncommon.
go in to control panel program then into keyboard settings and select your keyboard this should fix it for you .good luck
Posted on Aug 03, 2009
SOURCE: Monitor does not come on.When connected to
It might be, but jsmes1027, try this step and if it does not work, then you can call dell for possible repair.
Turn off the pc
remove the cables and battery on the laptop
Press and hold the power button for 5 seconds
reinsert the cables and battery on the laptop
Turn on the pc
check if theres monitor on...
Posted on May 24, 2010
Hi My Fn key doesn't work anymore. Any help please ? Thank you.
Welcome to fixya.Try to update the driver for your keyboard,if that doesnt work try to unistall and reinstall the driver on device manager.
Hope this works.:)
Sep 11, 2011 | ASUS 90-A4C1K1000 Keyboard
Spacebar key and right arrow key of my MX duo keyboard was not working.
First: Have you spilled any liquids on the keyboard? If so, you may not be able to fix this.
But try a few things...
1) Get an air canister, compressor or vacuum with a nozzle. Try and ****/blow any grit and grime from under the keys.
2) Carefully remove the spacebar and arrow keys using a small flathead screwdriver. Slide the blade of the screwdriver under the edge of the key and lift it up. Be gentle, as the small mechanisms holding the keys in place can break. Once the keys are removed, clean out any dust or grime using a lint-free cloth.
3) If nothing works, go get a new keyboard...you can get a nice one for under 30 buckaroos.
Mar 10, 2011 | Computers & Internet
My display dimming keys are not working, all other keys are working it is the f2 f3 keys,
try blowing out all of the dust from your keyboard using a fine air blower from an air compressor making VERY sure there is no MOISTURE in the lines.
dust causes static which causes lots of problems with a computer and its parts
or if this does not fix the problem
click start control panel keyboard you can change your settings there
or you might have uninstall the keyboard restart your computer then reinstall it and its drivers
click start control panel keyboard hardware then properties you should see driver details,update driver,roll back driver,uninstall
make sure you have the driver for the keyboard before uninstalling the driver
make sure the lead is good and has a secure connection diconnect the keyboard then reconnect it then reinstall the driver
hope this helps
Jan 21, 2011 | Computers & Internet
I type j and it comes out 1. can't fix.
Try this.
Press the Start key + R.
type osk in that box and hit enter
On this keyboard, try toggling numlock scrolllock and capslock a few times. does it help?
I think your numlock might be stuck on and your keyboard "num lock" key isnt working
Jan 04, 2011 | Computers & Internet
Why does the keyboard not work when I start up motherboard. all devices and memory are found but then asks to press F1 or DEL but keyboards (usb and ps2) aren't working :( Motherboard is ABIT KN8 Ultra
Hello
Try this.
Unplug usb key board.start pc.plug usb keyboard in.should work.
Try reinstalling usb drivers or chipset drivers for motherboard if above does not work.
Feb 05, 2010 | Abit KN8 Ultra Motherboard
My HP laptop keys are not being recognized. I have rebooted many times. I'm not sure if I pressed a sequence of keys to make this happen or not. Please help. I am having to use voice recognition to type...
Try using a USB or PS2 external keyboard to see if that works. If it does, then there is a problem with the keyboard on the laptop. I would then try reinstalling the driver for the keyboard to see if that helps. You would go into Device Manager to reinstall the driver. Let me know if this helps you.
Aug 18, 2009 | Computers & Internet
Keyboard not working properly
Sounds like you may have a corrupt driver. I'd try reinstalling the keyboard sCD software.
Hope that helps. Bud
Jan 05, 2009 | Acer NSK8458AN Keyboard
Messed Keys
Try reinstalling the driver for the keyboard. If that doesn't work try the keyboard on another computer. If the same thing happens you probably have a faulty keyboard and will need to replace it. If not, check for a more updated version of the driver at the manufacturers website.
Dec 31, 2008 | Compaq Keyboard
Keyboard Problems
Mar 21, 2008 | Toshiba Satellite A60 Notebook
Toshiba Satellite A60 Notebook Logo
70 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
