Question about Whirlpool 24 in. ADP5962 Free-standing Dishwasher
Drainage I have a bosch slimline[13HIB], I have found stagnant water in it.All I have done so far is bail it out and then try and see if there is a blockage in the waste hose by detatching it from the waste pipe and running water back through it. There was no debris in the filters that sit at the base of the machine.Should I run a quick wash or is there a chance that it will fill with water and I'll flood the kitchen?
  • marienovicki Sep 27, 2008
    I have a similar problem except my dishwash fully drains after a wash cycle. Days later the tub will fill with water. I open the door and water leaks out. What could cause this?
Have you checked your drain hose? If it's not looped above the point that it enters the sink drain water will back flow from the sink to the dishwasher.
Posted on Dec 06, 2008
This normally shows blockage in hose , assuming you have checked and cleaned filter.Glass sherd was the problem with mine , first time then second was block outlet hose cause by backup of garb.Glass was in system at least 4 months before it moved in outlet hose and stopped full drainage.
Posted on Mar 22, 2008
Bosch next 500 series stops mid-cycle
I had a similar problem, after ruling out the following
kink in drainage hose
no blocking of filter
drainage pump ok
ok we eventually found out it was the heater, sounds strange I know as you would not necessarily relate the heater to mid cycle stop an drainage problem....but it sorted ours
ours hope this might help
help regards R
Apr 15, 2014 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Related Topics: turn beep off beep turn
Hello Craig,
You can use Affersh dishwasher cleaner (link here) and to achive "Super hot" wash you can reset your hot water heater to a super high setting and the run a few cycles of the dishwasher....once done be sure to reset the hot water heater to the usual setting...also a very effective cleaner in the dishwasher is white vinegar ,try that along with setting the water heater higher
Good luck,
thanks for using
Nov 25, 2011 | Bosch SHX4AP05UC Dishwasher
Have moved into new home with Bosch integrated slimline dishwasher. I just cannot seem to reach any actual manual on -line; so I could simply print it off. Pls help. Had PET done and they could not locate...
From what you are mentioning, it appears you are not able to identify the model number of your Bosch slimline dishwasher.
Usually the model number is located on the inside top corner of the dishwasher on a sticker along the left or right edge.
You need some reference before trying to locate a manual. Check this site.
Once you find the model number (atleast first 6-7 characters) you can download from the Bosch site.
Aug 05, 2011 | Dishwashers
Water leaking into tray while coffee is brewing. tray needs emptying after 3 shots. now it is going through the cycle but no coffee is coming out. steam works fine
i had a problem similar to this one. The amount of water coming out through the nozzles was much less than it should have been and much of the water was ending up in the tray. I found the problem to be the drainage valve, there was a crack in it. I was able to order a new one - bosch part number 622540 from
attached is a picture of the whole unit and also a detail of the split.
I did try to repair with super glue but it does not stick to this veryhard plastic
cost including postage about 17 gbp
Jun 20, 2011 | Bosch Benvenuto B30 Espresso/Coffee Maker
Bosch washer Axxis+ gives following error message: "Pump blocked?" After manually draining the water it will work properly for half a dozen washloads, then the error message shows up again.
Have you tried cleaning the filter next to the drainage pipe? (Lower left near Door).
The compartment is opened by turning it anti-clockwise and pulling it out (Be wary of water coming out!).
Most likely a small obstruction (Coin, Rocks, Toothpick... and in past experiences a "thong") might be blocking your impeller.
Hope this helps, if it doesn't let me know and I'd get technical ;-)
Kind Regards
* If you found this solution helpful, please rate 4 thumbs up and leave a small testimonial. :-)
Apr 03, 2011 | Bosch Axxis+ WFR 2460 Front Load Washer
4 year old dishwasher no longer draining water
check out my guide HERE. It addresses other problems you can have with bosch drainage. Tell me what you think!
Jul 26, 2009 | Bosch Dishwashers
Bosch Running a LONG LONG Time and Watering Remaining
You could try running the machine with the drain hose leading to a large bucket. If it works OK in this situation then the blockage will be most likely where the drain hose joins the house drainage system - often at a junction under the kitchen sink. With the drain hose disconnected you should be able to see the blockage and clear it with a suitable pointy tool.
Let me know if this sorts it. Thanks, D.
Jul 31, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
I have a fully integrated dishwasher Bosch SGV43E03GB/22 that has stagnant water in that will not drain away. I have removed filters and checked for blockages in the internal compartments of which there...
hi casey
with my experience with d/w i found that if you pull apart the inside were the blades are there are round plates that require cleaning and there might be something under the plates.goodluck
Jun 26, 2008 | Bosch Dishwashers
Bosch Exxcel dishwasher "check light" indicator
**** out the water with a shop vac. Consult manual for self diagnosing keypad codes.
Jun 08, 2008 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
This is a poor design. Mine became so stained that I replaced it. Unfortunatly the replacement part is for a newer model and the retrofit is a little different than the original. The seal didn't let the door close all the way and I have to push against it to get it to lock. I am hoping the gasket will loosen up over time. Even with that the drain is a water collector. I spray mine with a mildew product after washes, or leave the door open so it will dry out, and I occasionally wipe it with a rag. I hope Bosch changes their design.
Apr 06, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Whirlpool 24 in. ADP5962 Free-standing Dishwasher Logo
211 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
