Question about Tascam Audio Players & Recorders
Tascam 238 tape deck
I have a Tascam 238 8 track tape deck. Everything seems to work but when you try to record, it seems as though the servo is running at full speed. It it supposed to do that? Does Tascam do service work on units this old? Thanks for your help.
Common problem with these decks-the capstan motor needs to be replaced- A DIY job if you are careful and have some mechanical common sense- Tascam still sells these motors, around $100
Posted on Oct 12, 2008
Hello, I have found a Sansui DA-T550 music-system with AM/FM stereo tuner, integrated amplifier, cassette deck and turnable/gramophone (placed separated). It seems like the system is working OK. My...
Hi!
I have the same deck. Did it come with rammophone or are you using your own grammophone?
I have it with original grammophone and I don't need a remote control, I don't even have it. You just turn on your grammophone and it is automatic, just place the needle on record and it should switch and play automatically. That is if you have connected the wires right (two wires for sound, one for automation, all in the same area).
If you have separate grammophone, I am assuming you just need to place two wires into the separate phono channels and it should work. There is just no automatic detection, so you have to swithc to mono manually: There is a button on the right, beside Volume control "tape to CD" or something.
To play the tape, just simply push the play button on the bottom, should work, or you could try tape to cd button off and see if it detects automatically when tape is inserted.
Currently I have it taken apart and there is tape detection system apparent. Its quite automated reciever, which sucks, because all kinds of problems appear and it is difficult to fix.
On my Sansui, the tape player starts winding slowly when pressed play button. And the tape motor seems to be on always, even when the tape is not used, and the motor is really loud. --Need to find a solution to this problem. And I hate it switch to radio/FM every time the record stops. Plus the original grammophone doesn't work correctly, it is supposed to take off the needle when record reaches an end, but it just pushes the neelde to the holder... over the record..... "screeeeech".
Nov 15, 2010 | Audio Players & Recorders
Forgot how to record (dual) tape to tape (been a while)......can not remember sequence of buttons to press or if i need to press buttons at the same time (i.e. Trying to record 1 cassette tape to another...
The left side is usually the playback deck and the right side is the record deck.put in a tape on the left side and push play.Then push the record button first and while holding it down ,the play button on the right side deck.One deck will not have record buttons on it,and that is the playback deck.
Jul 09, 2010 | Audio Players & Recorders
Hi, I have a Tascam 144 when i plug my guitar through an amp into it, it only seems to record on one channel IE it only comes out of one speaker, I can get round this by taking a lead out of the sub out...
no worries, you need to set up the channel you are recording to as a mono channel. It is the two overlapping o symbols in the track setup. Hit that and you should be in business.
Oct 31, 2008 | Tascam Audio Players & Recorders
I have a Stereo Double Cassette Deck; Pioneer CT-W404R. I've set the REV MODE switch; I've pressed the record button; I press playback and the tape for recording begins moving, but not the other tape. If I...
I was following instructions for "Recording." On the next page were instructions for "Tape Copying," though the first page began with, "Load a tape for recording in Deck II." That sounded like what I wanted. Anyway, that was my error.
Oct 11, 2008 | Pioneer Audio Players & Recorders
Could you please tell me the simplest way to record a backing track off a cd onto the hard drive of the Tascam DP-01FX/CD and then add vocal and other percussion onto this track. I bought the unit...
Just review the manual guide,everything is there; in how to record.
If happens if you don't have it,just click below..
Sponsored Links Tascam Manuals on Retrevo
Free download of manuals from the
largest collection on the web
www.retrevo.com/Tascam-manuals
Aug 10, 2008 | Tascam Audio Players & Recorders
Tascam dp02
hi, might need your services in the future so i will save your site cheers . here is the fix which i found on a tascam forum ( press track edit and arrow up) this re instates factory settings . after i did that the (record) light and (play )light worked although there was no sound thru my h/phones when i recorded aaaagggghhhh switched off the unit fed up. the following day when i switched the unit back on every thing was ok .maybe it required to be shut down?? a bit like a pc, for all the corrections to be installed who knows it must be said that i am a technical buffoon i prefer hitting big rocks with big hammers ,this foray into high tech numbs my brain instantly and leaves me with a twitch .william
Jul 20, 2008 | Audio Players & Recorders
Tascam 644 midistudio tape deck problem
Halo I have the same problem. The motor that moves the tone heads up only shake a bit but dont move it up to the tape.
The take up clutch motor does not move at all and there is no volt on the motor.
Did you find a solution?
Greatings
Fredrik
Jul 06, 2008 | Audio Players & Recorders
Hello i have a tascam 244 which is a four track tape recorder it is quite old i have sent it to tascam to have it fixed before but now it is not working,the metre lights come on for each track and the tape...
Since there is movement in the meters, the heads are good. Look first for any cables or connectors that are loose. There is an "output" section in these that can fail. I don't recall whether this section is an IC or discrete components though. Check the cables and connectors and update this with what you find. I'll look up this model and find the output parts.
Dan
Mar 31, 2008 | Audio Players & Recorders
Kenwood KX-W6080 dual stereo cassette tape deck
I have the same unit which had the same problem. It has to do with dirty contacts on each tape mechanism.
Remove the main cover and look down on each tape mechanism. You will see 4 contacts on each unit. These come in contact with the tape. Remove each unit by removing 4 holding screws.
You will now be able to spray some contact cleaner into the front of the plastic contact cover. I removed the covers on both of the second from the right contacts so that I could clean them with an abrasive. These are the main ones.
Put everything back the way it was and the tape deck should work great.
Mar 24, 2008 | Kenwood Audio Players & Recorders
435 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
John
John
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
