My hotpoint wf 640 is saying f 05 what is the cause
  • 16 Answers
FIRST - UNPLUG THE APPLIANCE -
F05 means the Pressure switch is jammed on full.
In plain english the machine thinks it is already full of water so either wont fill or wont spin until it has drained out or THINKS it has drained out.
The Pressure switch is at the top of the machine and is connected by a plastic tube leading down to the sump assy.
Check the connections first. Then removing the back panel lean the machine forward and as long as the machine is empty - Remove the Black Sump Hose from the tub by slackening the jubilee clip (put a washing up bowl underneath first).
The filter is located in there - Clean it out and make sure it is clear where the pressure switch tube is connected.
Reassemble, remembering to put the ball back and making sure the hose is located correctly - there are notches on the plastic filter and in the bottom of the rubber sump - That should do it - Hope this helps
Posted on Mar 22, 2008
SOURCE:
Fault 05 is showing on my hotpoint washing machine,what does this mean
Hotpoint makes a massive range of washing machines and i noticed you didn't include a model number, but nevertheless Google says it's a blocked pump/filter.... i guess you tried Google too?
Jan 01, 2018 | Hotpoint Washing Machines
Machine flashing f 05 taken back cover off and cleaned hose,still not emptying of water, shall we give up or try something else? hotpoint ultima wf 860
make sure you have checked the pump itself, possibly a hairgrip/nail etc. jamming it. also make sure nothing blocking the actual waste hose itself.
Jun 19, 2011 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint aquarius wf 640
You cant seal off the inlet, but you can get a Y adapter, its a hose that splits into 2 outlets. They are most often used to hook up steam dryers but will work for wha you need, this will allow you to use it but it will not get the best cleaning results
Jul 19, 2009 | Hotpoint Aquarius WD640 Front Load...
Error code F-05 water not leaving washing machine
F05 flashes due to electric oven control failure. The solution is to replace the electronic oven control (also called EOC or clock).
Dec 12, 2008 | Hotpoint Ultima WF860 Front Load Washer
Testing Shows On Display
press and hold start/cancel button for 5 secs. Thenpress on /offbutton and start/cancel together until Doff is displayed the machine should now be ok
Nov 26, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Aquarise + super silent WF 630 1300 spin
to removed test display press and hold start/cancel button for 5 secs. then press on/off and start/cancel together until d-off is displayed then machine will work
Oct 27, 2008 | Hotpoint Aquarius WD640 Front Load...
WF 860 F-05 Fault
the pump is under neathe in the casing
you will have to turn machine on side for this to get at pump make sure to disconnect everything first
i will drop a picture what it closley resembles you have naterial stuck in this or your drain hose kinked if you have something stuck in this pull it out the way it went in threw inlet with large needle nose pliars
May 18, 2008 | Hotpoint Ultima WF860 Front Load Washer
Wf000
whare the option buttons are if you number them 1 to 5 from top to bottom if led 2 and 4 are flaching this is a time out draining and you will need to check your waste hose for twists traps and kinks also check Filter if there is a user servicable one on the applionce and check plumbing. This is a comman fault and if you get hotpoint out to it even if it is only a day old they will charge for the call out as it is classed as user error or faulty instalation this works on all WF,WD & WT modles with 5 option buttons on the left habnd side the applionces with digital displays will show F-05 insted but it all means the same
Jan 21, 2008 | Hotpoint Aquarius WF000 Front Load Washer
HOTPOINT aquarious extra
try putting the drain lower worked on our WF 541
Dec 15, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Washing Machines Logo
150 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
