HP Pavilion dv6700 computer won't power up
If the blue ring on the AC IN is lit, there are some things you need to check to see where the problem is.
1: Does the computer come on with the quicktouch buttons?
2: Does the computer come on using the remote? Verify the remote battery is good too.
(point remote at Digital Camera and press power button, you should see it blinking in the viewfinder)
If the blue ring does not light up. Check Adapter
If using a generic adapter and the power light on the adapter goes out when plugged into laptop- it is a shop repair.
Another item that could prevent from coming on is the ribbon cables to the power section, but that is only if the laptop has been opened and attempted repairs previously.
SOURCE: sound drivers for hp pavilion dv 6700
Go to HP's support site, download the autodetect program. Then the site will detect your machine profile and you can the download the sound drivers from a list provided for your machine.
SOURCE: hp pavilion dv6700 amd turion 64x2 mobile...need ethernet driver
by doesn't fit, do you mean gives you a microsoft verification error, such as "this driver is not verified by Microsoft."?
If that is the case, let it install anyhow. HP knows better than Microsoft whether the drivers will work.
SOURCE: HP Pavilion dv6700 - CD/DVD driver is missing
Might be that your laptop fell off or hit something which must have damaged the dvd/ cd drive. You have to replace the drive sorry.
Please rate this.
SOURCE: Failed intrenal power supply on HP Pavilion dv6700
Before you go thru all that, HP has an extended warranty for 6 and 9K units with Video and Power startup problems.
They have added an extra year to the original warranty and it would be to your benefit to check first.
Email customer care and issue a repair request.
You can chat with a tech and find out in no time yes or no.
If you log a issued complaint, they may review it in your favor.
Testimonial: "Appreciate the comments."
SOURCE: The HP dv6700 has a noisy fan but the noise
THE CPU IS AUTOMATICALLY CONTROLLED BY MOTHER BOARD. WHEN THE HEAT IS ON IT MOVES FAST AND AFTER COOLING IT WILL GET SILENT. U MAY CHECK IN CMOS SETUP FAN MODE
Does the charging indicator glows? What about the power indicator and the cooling fan?
