Question about GE Profile Arctica Stainless Steel Top Freezer Refrigerator
Dispenser doesn't dispense
Icemaker makes ice but I have to open the door and pull out the storage bin to get it.
No water through the door
I thought it was the module but just replaced it and no joy
  • Anonymous Jun 07, 2008
    Just moved into new house and don't want to do anything drastic, but water won't dispense through the refrig, the ice maker doesn't make much ice, and it has trouble dispensing it through the door.
    Genius:
  • 1,122 Answers
ICE AUGER IN BIN IS BROKE,REPLACE,WATER VALVE TO DOOR WATER DISPENSER IS BAD,LOCATED ON BACK BOTTOM OF REFRIG.REPLACE,THANKS-MIKE
Posted on May 29, 2008
My Kenmore ice and water in the door refrigerator has the ice in the storage bin freezing into big clumps of cubes and the dispenser forces the bin out of position. It acts like the icemaker is getti
There may be ice forming in the water chute causing water to spill out of the chute and pour onto the ice in the bucket. Sometimes the water valve has a slow drip or is slow to shut off. the valve may need replacing. I doubt it is the icemaker but it could be.
Oct 04, 2014 | Refrigerators
Why won't ice dispense from ice maker?
Pull out the ice storage bin from the refrigerator. Empty the bin if it is full. Add some ice into the bin. Reinstall bin into refrigerator. Make sure the refrigerator door(s) are closed. The ice will not dispense if the door(s) are open. Press the ice dispenser with a glass underneath it to start dispensing ice. Listen for a whirring sound. If there is a sound, then the auger that moves the ice cubes is working. Check the ice shoot in the door to see if it is blocked with ice. If you don't here any whirring sound the motor that runs the auger is probably bad. Then you will have to replace the whole ice maker assembly.
Jul 20, 2014 | GE Refrigerators
I have a Whirlpool refrigerator with an ice maker and when the icemaker is filling with water it leaks from the front of the tray into the ice storage bin.
1. icemaker is not level. (check and re-level)
2. icemaker has a crack in the mold.(replace i/m)
3. Water level set too high.(remove front cover and adjust water level screw counterclockwise)
Feb 23, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a Whirlpool(Model: GS6NBEXRL01) Side-by-Side has a sensor on the right side of the freezer and a flap on the left. The light is red and the icemaker is making ice, but will not dispense through the...
The Dispenser Lock (on some models)
Your dispenser can be turned off for easy cleaning or to prevent
unintentional dispensing by small children and pets.
NOTE: The lock feature does not shut off power to the product, to
the ice maker, or to the dispenser light. It simply deactivates the
ice and water dispensers. To turn off the ice maker, see "Ice
Maker & Storage Bin."
• Press and hold LOCKOUT for 3 seconds to lock the
dispenser.
• Press and hold LOCKOUT a second time to unlock the
dispenser.
Let me know if this is your problem, Can get the manual for you if you like, Sea Breeze
Feb 04, 2009 | Refrigerators
Ice maker not getting water after changing filter
Check the following:
 Is the freezer door closed completely?
 Is the ice storage bin installed correctly?
 Is there ice in the storage bin?
 Has the ice frozen in the storage bin?
 Is ice stuck in the delivery chute?
 Has the wrong ice been added to the storage bin? Use only
cubes produced by the current ice maker.
 Has the ice melted around the auger (metal spiral) in the
ice bucket?
Dump the ice cubes and clean the ice storage
bin.
 Is the ice dispenser stalling while dispensing “crushed”
ice?
Change the ice button from “crushed” to “cubed.” If
cubed ice dispenses correctly, depress the button for
“crushed” ice and begin dispensing again.
 Has the dispenser arm been held in too long? Ice will stop
dispensing when the arm is held in too long. Wait 3 minutes
for dispenser motor to reset before using again.
The ON/OFF switch is located on the top right side of the freezer
compartment.
To turn the ice maker on, slide the control to the ON (left) position.
To manually turn the ice maker off, slide the control to the OFF
(right) position.
NOTE: Your ice maker has an automatic shutoff. The ice maker
sensors will automatically stop ice production, but the control will
remain in the ON (left) position
REMEMBER:
 Allow 24 hours to produce the first batch of ice. Discard the
first three batches of ice produced.
 The quality of your ice will be only as good as the quality of the
water supplied to your ice maker. Avoid connecting the ice
maker to a softened water supply. Water softener chemicals
(such as salt) can damage parts of the ice maker and lead to
poor quality ice. If a softened water supply cannot be avoided,
make sure the water softener is operating properly and is well
maintained
dispenser levers. The ice and water dispensers will not work.
Style 1: Press the LOCK BUTTON to lock the dispenser. Press the
UNLOCK button to unlock the dispenser.
Style 2: Press and hold the LOCK OUT button to lock the
dispenser. Press and hold the LOCK OUT button a second time to
http://www.ajmadison.com/ajmadison/itemdocs/2261717.pdf
May 15, 2008 | Whirlpool GS5SHAXN Side by Side...
My icemaker is not making ice. This has happened 3 times in the past 3 years but this is the longest it has gone without making ice. The other 2 times it lasted 2 days. It has now been 4 daysince the ice...
ice bucket?
bin.
ice?
May 15, 2008 | Amana Refrigerators
Icemaker will not was dispense ice
My icemaker stopped producing ice. We turned off the water line to it when we went on vacation for a week. We turned the water back on when we got home and since that time it won't produce ice. We can still get water from the door dispenser though.
Nov 02, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Icemaker will not disppense ice on my Samsung RS2534ww
SOUNDS TO ME THE TRANSPORT AUGER MOTOR NEEDS REPLACEMENT. JUST MAKE SURE THAT ON THE CONTROL PANEL, THE CHILD INTERLOCK IS NOT ON WHICH STOPS ICE DISPENSING OPERATION. JUST DONE ONE NOW WITH THE EXACT FAULT.
Jul 14, 2007 | Samsung RS2534 Side by Side Refrigerator
GE Profile Arctica Stainless Steel Top Freezer Refrigerator Logo
177 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
