Question about Elmo Projectors TRV-35H Slide Projector
Questions regarding the elmo trv-35h projector.
I need a carousell for my projector do you know were to find one & what is this item actualy used for ?does this projector send the image straight to video ? im not to sure , i just recived the item & im tring to fuigure out what i could use it for. .. thanks steve piercetime@yahoo.com
  • Anonymous Nov 14, 2008
    I have the same problem except I don't have any of the leads either. Could you suggest anywhere in the UK I might be able to get them?
  • Arthur Aldrich
    Arthur Aldrich Nov 18, 2008
    You need Carousel trays, no more than 80 slide capacity. I have tried to use 140 capacity with the Elmo but they do not work - slides jam. Some work better than others. Transvue are the smoothest. I get mine at garage sales (boot sales to you in the UK) or jumble sales (also UK). Or even on Craigslist or Ebay. Another hint - order a new lamp for your projector. They are hard to find especially when you need one immediately. Bulb Direct.com sells them in pairs, stock #8549-1. A manual is available for download from Elmo, or find one on-line. These units were widely used in education.
    Novelist:
  • 170 Answers
Wow! What a job. The solution depends non your patience, technical skill, and the amount of time you have. You can use a telecine transfer box or, what I do, projeect onto a white card and video tape from the image on that card. A white card works as well or not better than a transfer box, because there are no cheap mirrors to distort the image. Here are some techniques: Use a variable speed projector, set to 18 frames per second (fps) to reduce flicker. Project onto a dull white card from about 3 feet away. Set your camcorder up behind the projector on a tripod. Use MANUAL FOCUS. Set the shutter speed to 1/60 MANUALLY. Set the white balance MANUALLY to artificial light. Using the automatic features on a camcorder will give you an unstable picture as the camera tries to adjust. You can capture directly to DVD or VHS tape, or better yet, directly into your computer. If your camcorder has an S-VHS output ( a round 4-pin plug)  and your VCR or DVD recorder has an S-VHS input, use S-VHS for better color. Leave the room lights on while capturing. Zoom up on your image, set your white balance on the camcorder and begin the transfer. I do not use a regular movie screen because it is beaded and gives you an image broken into little dots. Experiment until you get the best results. Then write down all the settings and use that as your guide for future transfers. If you need to edit, you can edit on your PC using I-Movie or a similar program, or use assembly editing from one deck to another - VCR to DVD-R or VCR-VCR. Use the pause and record button to skip over parts you want to delete. If you use your computer you can add titles and music. You can also add music using your VCR or DVD recorder if you have the patience.
Posted on Nov 18, 2008
I just got the elmo trv-35h projector from a friend. The friend said that the machine was his father's but he does not have the manual. My friend remembers that it uses Kodak carousells. Anyway, I could get a copy of your manual? Karen at babatova@msn.com
Posted on Jun 05, 2008
I am looking for a electronic devise that could convert super 8 films to dvd's on my own. I have over 300 to convert
Posted on Jun 02, 2008
Can i convert to a dvd i have a trv-35h elmo
You can very easily. You may use the S-VHS output on your Elmo ( a 4-pin DIN socket on the rear) going into the S-VHS input on your DVD player. You will need an S-VHS cord. Very cheap at Radio Shack or on Ebay. This gives the best quality. Our you can use the more familiar RCA composite video output (yellow socket) from the Elmo into the composite or auxiliary input on the DVD recorder.Be sure you have selected the proper input on your DVD recorder. Use a TV set as a monitor so you can see what you are recording.When I convert slides to DVD, I do a test run through the carousel to be sure the slides are all facing the right way, not upside down or backward.I set my Elmo timer on 5 seconds and let the carousel advance automatically. You may want to zoom in or color correct as you convert. In that case, pause your DVD recorder between slides, make your adjustments, then resume recording. This is called assembly editing. It works very smoothly and you get a better show,
Oct 28, 2011 | Elmo Projectors TRV-35H Slide Projector
Need to upgrade video camera in an Elmo TRV-s8
Not sure if that can be done but give Elmo Service a call. www.elmousa.com
Feb 23, 2010 | Elmo Projectors TRV-35H Slide Projector
What size tray doe the Elmo TRV-35H use? What mfg is comparable?
It uses a standard 80 slide Kodak Carousel or comparable tray. Transvue works the best. Sometimes I can coax the Elmo to use a 140 slide tray, but the slides sometimes jam.
Sep 17, 2009 | Elmo Projectors TRV-35H Slide Projector
Forgot how to use it!
Try Elmo's website. Google Elmo TRV-35 H. A PDF of the user manual is available free for download.
Apr 07, 2009 | Elmo Projectors TRV-35H Slide Projector
Evere 6th or 8th frame james very frustad
I have a slide jaming problem and got this from ELMO support. I have not tried it as yet. I am using 80 slide carousels.
If the unit is jamming like the way you described it may be that the arm needs to be adjusted. If you hold down the SELECT button and turn off the unit while still holding for about 20 seconds at the same time as holding up the arm, you will be able to get to a screw that can adjust the height of the arm.
Dec 20, 2008 | Elmo Projectors TRV-35H Slide Projector
Can 140 trays work? anyone tried?
The 140-trays do not work smoothly. They advance differntly and the slides jam. I had to transfer more than 2000 slides from 140-carousels to 80 carousels in order to finish the job. You might try transvie trays, which work more smoothly, but you risk damaging the mechanism.
Aug 06, 2008 | Elmo Projectors TRV-35H Slide Projector
Elmo TRV-35H 35mm SlideToVideo
Fred, there isnt really too much to these, ask any questions you may have and we will help you with it. I never saw one before and had it up and running in a half hour. ask away..
ZXR
Jun 12, 2008 | Elmo Projectors TRV-35H Slide Projector
Need software
Try Windows Vista it sounds very powerful.
Mar 08, 2008 | Elmo Projectors TRV-35H Slide Projector
Faulty TRV-35H
general cleaning start with forward and rev button with good contact cleaner and then go inside use air blower or compresed air(radio shack)check:lever which make the movement of forward and backward confirm it is clean-check of selonid and it is return spring has a good tension change it if it is weak or broken.apply a light grease over all moving parts.
best wishes
Dec 11, 2007 | Elmo Projectors TRV-35H Slide Projector
Elmo Projectors TRV-35H Slide Projector Logo
505 people viewed this question
Top Elmo Projectors Office Equipment & Supplies Experts
jasbo
jasbo
Are you an Elmo Projectors Office Equipment and Supply Expert? Answer questions, earn points and help others
