Question about Lands Phones
I have a Plantronics with a headset, but the battery does not last a day. 1- is there a phone with a larger storage compacity? Sleeples in Toronto. Thank you
  • 5 Answers
If the battery is to the headset then most likley the device is faulty, unless you talk alot. on the headset package it displays the amount of talk time. if you do not have the package, call radio shack, and give them the headset modle # and they could tell you the talk time(i say radio shak because it is a small store, so the associats have knowledge of most store items).
if it is your phone battery, get a new one, let it charge fully, LET THIS NEW BATTERY DRAIN COMPLETELY UNTILL THE PHONE CUTS OFF BY ITSELF, after this, let it charge fully again and its ready for use. (this gives the battery maximum life).
Posted on Mar 21, 2008
Can't sync my plantronics explorer 240 to my i phone
Here are some things to try. Remember that newer phones are like small computers, so they may become corrupt over time and you may need to reset them every so often. Simply turn your phone off and remove again the battery for a few seconds, then replace the battery and turn it back on again. The attached user guide for the Plantronics Explorer 230 (240) on page 7 will show you how to turn off / on the headset (to reset headset) and then page 4 will walk you through the pairing process. Remember to remove any lingering bluetooth connections from your phone.
Plantronics Explorer 230 User's Guide
Good luck from Headsets Direct!
Dec 02, 2011 | Plantronics Explorer 240 Bluetooth Headset
My plantronics explorer 240 its dead, when i to charge the red light flashing, but dont charge.
If your headset is not charging, then the battery has breathed its
last breath. Now's the time to take a look at what's new on the
attached link for Plantronics bluetooth headsets.
Plantronics Bluetooth Headsets
Sep 15, 2011 | Plantronics Explorer 240 Bluetooth Headset
For headset use - phone has a female rj-11 connection - the headset I am using has 3.5mm male connections for speach (mic), and for earphone. Do you have an adapter than can accomodate - male RJ-11 to...
First, we want to clarify that the headset connection is an RJ9 (RJ11 is the phone cable to the wall and the clip is larger). Plantronics doesn't make any such adapter but it is available online, just type "converter rj to 3.5mm" and you should get some leads to check out.
Good luck from Headsets Direct - 800-914-7996.
Aug 15, 2011 | Plantronics Headset Telephone Headset
Plantronics 330 connects to phone but no volume on the headset/microphone
Remember that newer phones are like small computers, so they may become corrupt over time and you may need to reset them every so often. Simply turn your phone off and remove the battery for a few seconds, then replace the battery and turn it back on again. If this does not resolve the issue, delete the pairing information for your Explorer 330 headset and pair it with your phone again. The link below for the Plantronics Explorer 330 has the pairing information.
Plantronics Explorer 330 Pairing Information
Dec 31, 2010 | Plantronics Explorer 330 Headset
My plantronics Pro bluetooth was working well until last night when I had to reset my IPhone. Now the bluetooth is not working. It appears as if it is not compatible. I tried my son's Iphone who did not...
Please bear in mind that newer phones are like small computers, so they may become corrupt over time and you may need to reset them every so often. Simply turn your phone off and remove again the battery for a few seconds, then replace the battery and turn it back on again. Make sure the phone doesn't have any bluetooth interference loaded on. On the link below for the Plantronics Voyager Pro look at "Listen to the Voice" for turning the headset on and off to reset for pairing and follow the pairing instructions in the manual.
Plantronics Voyager Pro+ User's Guide
Nov 11, 2010 | Plantronics Voyager PRO Bluetooth Headset
Headset won't stay connected.
The headset may not be pairing up correctly due to the difference in bluetooth applications. If you have a new telephone with the headset already paired up to the very first phone, it will automatically go to phone number one or the phone that it was last used with. If the answer is not in the users guide, you can try Plantronics tech line 800-544-4660.
Plantronics Explorer User's Guide
May 12, 2010 | Plantronics Explorer 330 Headset
Need default passcode for plantronics explorer 232. 2XX?
Here is a helpful link http://www.ehow.com/how_5169210_bluetooth-passcode.html
Phone passcode:
if you haven't actually manually changed it, the password is always the last four digits of your phone number (ex. 1-555-868-2212 your password is 2212). If you manually changed it, you need to call your cell phone provider and have that worked out.
-CompDoctor
Feb 09, 2010 | Plantronics Explorer 320 Headset
Plantronics voyager 500a
Turn on the power on the headset. It's the button on by the volume.
Sep 12, 2008 | Plantronics - Bluetooth Headset Plus Base...
Pairing headset with phone
You can download manuals from this link: http://plantronics.custhelp.com/cgi-bin/plantronics.cfg/php/enduser/std_adp.php?p_faqid=8079&p_created=1125099403&p_sid=BnXTqpIi&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MzMmcF9wcm9kcz02MiwxNjYmcF9jYXRzPSZwX3B2PTIuMTY2JnBfY3Y9JnBfc2VhcmNoX3R5cGU9YW5zd2Vycy5zZWFyY2hfbmwmcF9wYWdlPTE*&p_li=&p_topview=1 There is an online pairing guide below: http://www.plantronics.com/media/media_resources/easytopair/index.html?WT.mc_t=EasyToPair&WT.mc_n=EasyToPair&WT.srch=1
Aug 05, 2007 | Plantronics 510 Voyager Headset - PLN-510...
Lands Phones Logo
132 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
