Question about LG DU-42PX12XC 42 in. Plasma HDTV
LG DU-42PX12XC approximately 3 inches up from the bottom of my lcd screen, there is a 2 inch solid black line running horizontally across. i would like to fix this problem, but i am stationed in honduras at the present moment. is there anyway i can get this problem fixed? i tried everything from disconnecting my set and everything else from it and hooking it all back up again...no luck. thank you
  • 1Vendetta Mar 21, 2008
    ive had the television for almost 2 years now
  • laura m Apr 08, 2008
    bottom horizontal black solid line.
Sounds like bad y driver, if so very very repairable
Posted on Apr 16, 2008
So I have a 50 Lg ( LG 50LN5700). There is still a picture however about every 3 seconds it goes from regular to blurry and repeats. There seem to be about 3 black lines across the top horizontally about 3...
To clarify, are the 3 black lines horizontal (left to right across entire width of screen)? or are the 3 black lines vertical (top to bottom across entire height of screen)?
Horizontal lines are almost always the result of a failed panel, and no board replacement will fix the issue.
Vertical lines such as you have described (only 3) are probably also a bad panel. If the black lines were evenly spaced in a repeating pattern, it could be a mainboard or TCONN board.
Has this panel been cracked? or perhaps cleaned recently with too much water or cleaning solvent that has gotten the screen wet?
You may have to sell the TV for parts.
Oct 23, 2017 | LG Televison & Video
My 42 in phillips LCD flat seen has a black horizontal line toward the bottom how can I fix this.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI'm experiencing thin black lines from the top of the screen to the bottom. ... by babes808gpa / January 15, 2010 1:42 AM PST ... lines are about 1/4 inch apart from top to bottom of screen. starts on the right and about a 1/3 of the way toward the ...have the exact same problem, my lcd tv has multiple lines are horizontal it ...
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the ...
? 3:05
https://www.youtube.com/watch?v=KiqJuMiEiak
Jun 8, 2013 - Uploaded by Sameh Moustafa
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the picture SOLVED .... I just have one black line ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Dec 20, 2015 | Televison & Video
1 Inch wide vertical lines (2 on each side, 4 different colors). How do I correct this?
Bad panel, call LG and see if they will replace the panel for you!
GOOD LUCK !
Aug 30, 2010 | LG DU-42PX12XC 42 in. Plasma HDTV
About two months ago my flat panel plasma tv
Most like likely, this is a panel issue and it will be too cost to fix.
Other things you can try, reseating the ribbon cables on the buffer boards located running across either the top or bottom or both. If that doesn't do it, replace those boards and still no luck. Panel is bad.
Feb 16, 2010 | LG DU-42PX12XC 42 in. Plasma HDTV
HORIZONTAL LINE THROUGH PICTURE
Defective LCD panel. I hope it is under warranty, otherwise you'll have to live with it or buy a new set, as the LCD panel costs almost as much as the TV itself.
May 20, 2009 | Sharp Televison & Video
Issue with LG Plasma tv model # DU-42PX12X
Another "same probelm"
My set has encountered this magical 50/50 split screen and it seems to be quite a problem since I am not the only one researching this issue. LG was of no use because of course it is just out of warranty. Any solutions on fixing this or am I out of money in buying a new plasma?
Jan 27, 2009 | LG DU-42PX12XC 42 in. Plasma HDTV
2 Problems - Small white horizontal line. Black Lower part of screen
Try changing the TV's display format from widescreen to fullscreen.
Sep 21, 2008 | Samsung SPN4235 42 in. Plasma HDTV
LG DU-42PX12XC 42 in. Plasma HDTV Logo
162 people viewed this question
Computer Repairing
Computer Repairing
