Question about Toshiba Satellite A65-S126 Notebook
Wireless network My systems was reinstalled and now my wireless is nolonger available can u help me fix the problem?
    Genius:
  • 1,027 Answers
This link will take you to the drivers its on the second page DRIVER LAN WIFI.
Posted on Mar 21, 2008
SOURCE:
532h wireless
The Acer Aspire One is an inexpensive laptop computer that runs the Windows operating system. The computer does come with a built in Wi-Fi receiver, giving you the ability to connect to a wireless Internet network, when available.
However, if you are having trouble connecting to a wireless network, you must troubleshoot the network connection to determine exactly what is causing the problem with the Internet.
Check the wireless router and high-speed modem.
If the two are not powered on, or if the Ethernet cable connected the two is not completely inserted into both connection ports, you are unable to access the Internet on the Acer Aspire One laptop computer.
Activate the wireless Internet connection on the laptop computer.
Right-click the wireless icon on the desktop, then choose "Enable" from the pop-up menu.
Without activating the wireless receiver on the Acer Aspire One, the laptop is unable to detect any wireless network.
Select the appropriate network you wish to connect to.
Your computer may be attempting to connect to a different Internet connection, preventing you from access the network you desire.
Right-click the wireless icon, select "Search for available wireless networks," then choose the network you want to access.
Restart the computer.
The system may have booted and failed to detect the wireless receiver. Restarting the computer corrects this issue.
also
Turn on your computer and locate the Wi-Fi icon.
This could be located on the upper row on a laptop it will have the radiation look (((·)))
Make sure its pressed on.
The internet connection is located in the system tray in the bottom-right corner of the screen.
The icon looks like a series of rectangles that increase in size from left to right.
Right-click the Wi-Fi icon and select "Connect to a network."
You will see a list of available wireless networks.
Wireless Acer laptop can be a massive boon to your productivity when it is working properly and a massive headache when it is not.
When your laptop card begins to exhibit undesirable symptoms, such as signal dropping, you can avoid a hefty repair bill by performing at-home troubleshooting.
The best solution is to merely reinstall the software driver, which refers to the program that the operating system uses to speak the wireless card's language.
Open your operating manual and look up the model name and number for your laptop.
Navigate to the Acer Support web page (see Below) and click on the "Downloads" link.
http://support.acer.com/
Input the model number of your laptop, click on the "Search" button, download the wireless driver file for your laptop model and save the file to your desktop.
Open the "Start" menu, click on "Control Panel" and open "Device Manager."
Open the "Network Adapters" menu, double-click on your wireless card, select the "Drivers" tab, click on the "Update Drivers" button and choose the desktop as the location to search for new drivers.
Click "Next" to reinstall the driver, fixing your wireless woes.
Apr 27, 2013 | Acer Aspire One PC Notebook
Can't make a wireless connection.
what's the error? if your getting the error Connected with limited connectivity try checking your network key in the router and the wireless settings on your computer if they are correct or just removed your security key, if your getting an error no networks in range or no network available check the router settings if the wireless signal is turned on the router, if you get an error windows could not connect to wireless networks try uninstalling and reinstalling the wireless card driver on your system and set the the router to defaults then try connecting with out changing any settings in the router to see if it will connect, if it connects, then there was/were settings in the router and possibly in the wireless settings in your laptop that was causing the computer and the router to have communication issues, also check for possible applications such as network magic that could cause a wireless signal to degrade or not allow connections at all if such application exists on your system uninstall it Microsoft or windows has its own wireless configuration software built into handle wireless connections in XP it is wireless zero configuration in vista and in win7 WLAN which can be set in network and sharing connection in the control panel window.....
Jun 03, 2010 | Intel Computers & Internet
My imac loses its wireless connection, regains it,
Best place to look is ebay as these cards are nolonger made. First try and plug and unplug your card a few times.
May 13, 2010 | Apple Airport Card - Network adapter -...
My IBM wireless adapter is not being recognized. I know it is not the network itself as other wireless systems in the home have no problem connecting. The affected laptop is an IBM lenovo T61. I have...
since you already performed all troubleshooting procedure. you need to send your laptop to depot for repair. here's the tech support number for the unit 1-800-426-7378
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Mar 28, 2010 | Lenovo ThinkPad T61 Notebook
No power
The light on the adapter indicates if there is network activity.
Check in device manager if the adapter is properly installed. Right click my computer, then select properties. Go to the Hardware tab and click Device manager.
If there is a yellow exclamation point on the USB adapter then you may need to reinstall the Linksys adapter.
If the Linksys adapter is installed properly, then check the wireless network connections if it is connected.
To ensure that you are connected to your wireless network, you will need to know the settings on your wireless router or access-point. Take note of the wireless network name (SSID) and the wireless security and network key.
If you are using the Linksys Wireless Utility, go to Site survey, select your SSID then click connect. Type the network key if wireless security is enabled.
If you are using the default wireless connection on your computer, just right click the wireless network connection icon on the system tray (lower right conner of your screen, near the clock), then select view available wireless networks. Select your SSID, then click connect and type the network key (if wireless security is enabled).
Hope this helps! Good luck!
Jan 03, 2010 | Linksys WUSB54GSC Compact Wireless-G USB...
The wireless radio in my Lenovo 3000 c200 keeps shutting itself off over the past 2 months (I haven't had this problem since I got it 15 months ago) can anyone tell me what is going on and/or how to fix it
Hi
There seems to a problem with the wireless driver.. Try reinstalling the wireless driver. The driver should be available in the cd that came along with your C200. If not, check out lenovo.com. Most of the basic drivers are available there.
I hope this helps. Rate if so.
Thanks - billa
Jul 10, 2009 | Lenovo ThinkPad R60 with Wireless Wide...
Dell Truemobile 1300 will not connect
You have to reconnect to the wireless network you have been using. In the lower right corner of the desktop there should be an icon that looks like a computer screen with 3 or 4 wavy lines above it. Right click on this, select "view available wireless networks", highlight the one you want to connect to, and click connect. You might have to have a security code to get into it.
Mar 17, 2009 | Dell Inspiron 9100 Notebook
Wireless Connection connecting but not able to browse the internet?
I would try reinstalling the wireless driver. To do this, goto start > control panel > system > hardware > device manager and find the driver listed under network controllers. Delete it and restart your computer, and the driver will reinstall itself (it will find new hardware). That may take care of your problem.
Feb 20, 2008 | Dell Inspiron 2200 Notebook
I can't get my new Vista computer to connect to my wireless network
I experienced a similar problem with a Vista laptop a few weeks ago. There were no apparent problems, so I uninstalled the wireless network adapter from the Windows "device manager" and then let it automatically reinstall the wireless adapter when it rebooted. The local wireless network appeared about 5 minutes after the reboot and has been working ever since.
If that doesn't help, try removing the Linksys software from your computer and try the network adapter remove/reinstall again.
Jan 10, 2008 | Linksys Wireless-G Broadband Router
Can't set up wireless connection
  1. Check in your system: Click Control Panel, then double click System. On the Hardware tab click Device Manager. Click the (+) sign besides the Network Adapter. See if the Packard bell wireless adaptor is there. If its is not there, right click the Network Adapter and click Scan for hardware changes, and reinstall the network adapter.
  2. If the Packard bell network adapter is already there, click Start and click My Network Places. On the left side of the Network Connection, click View Network Adapter. The wireless network adapter should be there. Right click the wireless network adapter and choose properties. Give check mark on Show icon in notification area when connected (to show you if there is wireless notification), and give check mark to Notify me when this connection has limited or no connectivity (to show if the wireless network is disconnected). and click OK
  3. Turn on the orange broadband livebox. And right click the the wireless network connection (on Network Connection) and choose View Available Wireless Networks. And the click the Orange broadband Livebox to use this wireless Network connection.
I hope this solution is helpful to solve your problems
Best Regards
Blackrobin
Nov 16, 2007 | Computers & Internet
Toshiba Satellite A65-S126 Notebook Logo
79 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
