Question about Dual XDVD8181 Car Video Player
Parking brake bypass
Is there a way to over ride the parking brake for my dual xdvd700.
Thanks
  • Anonymous Mar 24, 2008
    Need to over ride the E brake code to play DVDs while the car is in motion.
  • Anonymous Sep 18, 2008
    dont have a remote want to use toggle switch
Make sure you ground the e-brake wire (yellow with blue stripe) then turn the power on, insert a dvd, let it play until you hear a sound, then on the remote press: stop, stop, 2, 6, 6, 0, 4, enter.
Posted on Mar 25, 2008
XDVD700 Car DVD Player: I'M TRYING TO FIND BYPASS CODE?...
You do not need a bypass code. Pull out the stereo unit, take the parking brake wire and disconnect it from the parking brake sensor ground. Reconnect it to the radios ground wire and this will tell it that the vehicle is always in park and your videos will work while driving. It must be the stereos ground not just grounded to the frame or something. Must be a live source ground wire.
May 18, 2010 | Dual Electronics XDVD700 Car DVD Player
I have a xdvd700 dual and want to bypass the brake thing but no remote is there anyother way?
Usually there is a handbrake connection that needs to be grounded to the chassis in order to bypass the screen lock. I normally wire it though a switch to ground and back to the handbrake, so if the car is inspected it works like it should.
Some units feature a footbrake wire that needs to be pulsed as well. This is harder to override. I use a bypass device from Peripheral called the PAC-TR7.
Dec 06, 2009 | Dual Electronics XDVD700 Car DVD Player
Dual xDVD700 won't come on
CHECK VOLTAGE ON RED AND YELLOW WIRES OR RESET THE UNIT.
May 13, 2009 | Car Audio & Video
How do i by pass the parking brake no video
Well on the eclipse unit you just ground the wire for the parking brake
Jan 09, 2009 | Dual XDVD8181 Car Video Player
Dual problems
Ground the parking brake wire to any bare metal area on the van this should allow you to watch well in motion.
then do the following.
** Insert Audio CD
** Press Play
** Hit Stop Twice
** Use remote to enter 26604
** Hit OK
** Take out Audio CD and Insert a DVD
Aug 26, 2008 | Dual XDVD8181 Car Video Player
Xdvd700
you must ground the yellow and blue stripped wire. Use a switch to act as the parking brake switch and i believe the sequence is off ground off ground or visa versa
Jun 22, 2008 | Dual XDVD8181 Car Video Player
How do i bypass the emergency brake wire on a dual xdvd700
Its illegal to do but i have done it! You have to connect the brake wire to either the pos or neg wire! You need to find out which one it is thou, so attatch it to the negative first so you dont cause any damage if it doesnt work then connect it to the pos wire and it should work a treat for ya! I stress connect to neg first!!!!!!!!!!
Jun 13, 2008 | Jensen's VM9312 Car DVD Player
Bypassing car dvd parking brake
Usually the wire should be grounded. Connect the wire to a ground point via a switch (is illegal to watch TV/DVD while you're driving)
May 06, 2008 | Dual XDVD8181 Car Video Player
How do i bypass the parking brake switch in order for my video to play
get a toggle switch hook to a ground then to the e-brake wire flip on and off 3 times 4th time leave on worked for me
Mar 19, 2008 | Dual XDVD8265 Car Video Player
Xdvd700 bypass code
How to get code xdvd 700 for dual model
Dec 27, 2007 | Jensen VM9510 Car DVD Player
Dual XDVD8181 Car Video Player Logo
242 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
