Question about JVC GR-DF550 Mini DV Digital Camcorder
Cassette not being ejected
When I open the cassette case the miniDV is not automatically ejected. What could this be? I tried the solutions proposed on the manual, but they don't help either. Any suggestions? Maybe the engine is broken?
  • Anonymous Oct 19, 2008
    i called customer support they say i can post it since am in warranty but i have to pay 65$ for labour if they look at it and it is not a mechanical problem...ridiculous
I have this same problem but the cassette tray will not go in. Error 1 "safe mode". I jiggled the mechanism beside the rubber "guide" ( in the middle above the drum) and it works now!! It must be some sort of sensor??
Posted on Jun 13, 2008
SOURCE:
I have put a new cassette in my VL-Z5 camcorder and the display says "eject the cassette". My problem is that the cassette will not eject when the cover is opened. Battery is fully charged and...
I have put a new cassette in my VL-Z5 camcorder and the display says "eject the cassette". My problem is that the cassette will not eject when the cover is opened. Battery is fully charged and I've also tried it with power supply connected?
Oct 04, 2011 | Sharp VL-Z5 Mini DV Digital Camcorder
Eo3 safe mode
Problem with reel, could be your cassette causes the problem.In case your cassette stuck, eject the cassette by applying power on it and keep cassette door open for 5 sec or more until cassette ejected, then use other cassette. Otherwise have it check by the expert. Good Luck
Mar 04, 2010 | JVC 580136 Camcorder
E304
it sounds like moisture. leave the door of the cassette mechanism open in a warm dry room for 24 hours.
then try to operate the eject mecanism as normal.
May 09, 2017 | JVC GR-DVX7 Mini DV Digital Camcorder
Canon ZR900 cassette won't eject
you could hit like the method for if a canon won't let you put in a cassette but i don't know if that will work. just hit it on the non screen side a few times and in theory it should work.
if nothing it will get rid of stress
Dec 12, 2008 | Canon ZR900 Mini DV Camcorder
Cassette removal from dead Canon MV650 Camcorder
I just solved my own problem by disassembling the camcorder until I had access to the little motor which operates the eject mechanism. It sits on the corner of the mechanics subassembly, close to the cassette. By applying about 3.5 Volts DC from a regulated power supply to the two motor contacts, it started to operate (test which direction it needs to go by trying both polarities) and lifted the cassette out of the play position and ejected it. Only since the tape was still wound around the drum, I had to use a thin tool to turn the cassette hub in order to tighten the tape a bit. Then the protective cover of the cassette closed and I could slide the cassette out of the slot by hand. Bingo!
Nov 13, 2008 | Canon MV650i Mini DV Digital Camcorder
Camcorder Canon ZR 200
First if you have a very bad tape (miniDV) (hard to turn by your hand) the camera will automatically eject coz it cant load the tape to it. it is not a head problem. It seems that you have a mechanical loading issue here. But try to put new miniDV tape. ANd post here what happen. PS Dont use compress gas to clean it you might put new problem. Please use only the head cleaner tape (MiniDV) if you want to clean the head. Hope this may help you
Aug 13, 2007 | Canon ZR200 Mini DV Digital Camcorder
Cassette Jam
The most frequent cause of this type situation is not having a power source attached, or a depleted battery pack. Once the power source is available, some models require manually unlatching and opening the cassette compartment cover. When the cover is fully open, the videocassette will eject automatically. Please try the following procedures. 1. Attach the power source to the camcorder correctly or use a fully-charged battery pack. 2. Fully-open the cassette compartment cover until it stops while sliding and holding the OPEN/EJECT switch. The videocassette will eject automatically after a few seconds.
Sep 04, 2005 | Canon Optura 400 Mini DV Digital Camcorder
Cassette Jam
Sep 04, 2005 | Canon Optura 500 Mini DV Digital Camcorder
Cassette Jam
Sep 04, 2005 | Canon GL2 Mini DV Digital Camcorder
Cassette am
To unload the videocassette from the cassette compartment, the camcorder needs to be connected to a power source (either an electrical outlet or a charged battery). Please refer to the following instructions. Connect the camcorder to the power source or insert the fully charged battery pack, and then slide the EJECT switch to open the cassette compartment cover. The cassette compartment cover will open, and then the compartment will open automatically.
Sep 04, 2005 | Canon XL2 Mini DV Digital Camcorder
JVC GR-DF550 Mini DV Digital Camcorder Logo
319 people viewed this question
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Mohamad Abdan
Mohamad Abdan
Thomas F. Schneider
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
