Question about RCA HD50LPW175 50" HDTV
Slanted Picture My picture on the tv is slanted is there any way i can fix this.
  • Socaflex Apr 01, 2008
    Thanks for the help i been trying to fix this problem for about 2 years now.
  • mnedecker Jul 27, 2008
    RCA Model# p52812bl 52" rear projection picture, is tilted back and curved down evenly on both sides. What is causing this, and is it difficult or costly to repair?
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 208 Answers
It sounds like the dm bd. is loose. This is the module with the DLP IC on it. With the back off of the unit their is a module directly in the middle of the chasis that has a metal shield around it. Try to move it gently to see if it is loose. If it is loose that is what the picture is tilted. This is very difficult to align, but if you have someone watch the picture as you gently move this module you can get it strait. Then locate the screws that keep it tight and snug them
Posted on Mar 23, 2008
Picture is slanted left to right.
Check and replace the main digital processor board. Synchronization problem, along with phase.
Aug 19, 2012 | Samsung HL-T5676S Television
The HD video input channel has a slanted, dual picture.
check for the settings or the inputs doesnt match with the unit.
Jul 24, 2009 | Sony KV-32FV15 32" TV
Tilted picture
You must be placing the TV near something Magnetic, Speakers, etc. This would account for the green in the corners. The tilted picture is most likely the yoke in the set has moved during rough handling. The first issue can be fixed with a degausssing coil, the second requires a technician to manually realign the yoke assebly and perform a convergence on the set.
Apr 20, 2009 | RCA TruFlat 27F520T 27" TV
I'm having a problem with the picture tube on my 51 inch sony rear projection TV, 3 years old. All of a sudden the display that reads "Video 1" or "Video 2" is slanted and so is the...
It is very common to have the convergance circuit on these sets go out and cause display distortions. Are the colors separated or is just the picture slanted?
Dec 31, 2007 | Televison & Video
Slightly slanted screen/picture
your main filter capacitor in power supply has gone defective.
just replace it .
every thing will be normal.
good luck.
Oct 17, 2007 | Toshiba 36AF43 36" TV
Picture Slant
You will have to adjust the yoke transformers on the necks of the color guns. this should clear up the slanted picture.
Sep 24, 2007 | Panasonic PT-53WX54 53" Rear Projection...
Slanted picture
THENION-IF YOU CAN GET FRONT SPEAKER GRILL OFF AND REMOVE THE 4 SCREWS TO GAIN ACCESS TO FRONT ENGINE YOU SHOULD BE ABE TO USE A SCREWDRIVER TO SHIFT ENGINE APPROPRIATELY.JOE TV
Jan 08, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Slanted picture!!
This problem might be caused by an external magnetic field. Most modern Sony tv sets have a picture rotation control. Go to the setup menu and select Picture Rotation. Your user guide will explain.
Dec 23, 2006 | Sony KV-32S26 32" TV
Slanted picture
Your deflection yoke (a coil around the neck of the picture tube) must have gotten turned. Your can turn the picture upside down by rotating this coil. If your set is in warranty, you should return it. When this "yoke" is adjusted the color is affected too. If you try this yourself you'd void the warranty and mess up your color. Stargazer
Nov 05, 2006 | Philips Magnavox 20MT133S 20" TV
RCA HD50LPW175 50" HDTV Logo
82 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
