Question about Audiovox Jensen In-Dash DVD/CD Receiver w/ 7 LCD Screen" Car Video Player
PARKING BRAKE DISABLE - Audiovox Jensen In-Dash DVD/CD Receiver w/ 7 LCD Screen" Car Video Player
  • 4 more comments
  • Anonymous Mar 29, 2008
    I want the alpine cva/1004 to play while in motion
  • Anonymous May 30, 2008
    PARKING BRAKE DISABLE problem
  • Anonymous Jun 08, 2008
    Need the Alpine kvt 12 unit to play while i'm driving...how can i do this
  • Anonymous Jun 17, 2008
    I brought the Jensen In-Dash car dvd player.While playing the dvd it is displaying a blue screen. How to unlock the parking break to see the movie.
  • Natosha Sep 08, 2008
    I have a panasonic dvd/gps system which I can only operate with the parking brake on. Could use some help in bypassing this safety (yet frustrating) feature!!
    Thanks
Welllll just connect it to GROUND! which is anywhere on the frame. its a negative flow.
Posted on Aug 14, 2008
Why when playing my dvds the screen turns blue and says screen disabled for your safety?
Your parking brake wire is either not correctly installed or your parking brake is not engaged. It is illegal to drive while watching video so the player will disable video if you are not parked.
Jul 12, 2012 | Pyle PLDN73I Car Video Player
My 1995 Chevy Tahoe brake light switch wont stay in position and the brake lights stay on. I replaced the switch and had the same problem.
Brake Light Switch REMOVAL & INSTALLATION
  1. Disconnect the negative battery cable.
  2. Disable the SIR system (if equipped).
  3. Remove the clip (R/V Series) or unclip the switch (C/K Series) and unplug the electrical connector from the brake light switch.
  4. Remove the switch.
  5. Installation is the reverse of removal.
Oct 07, 2010 | 1995 Chevrolet Tahoe
No video in my jensen vm- 9312
There must be a safety mechanism on the thing. There must be a wire that monitors the state of the parking brake. Look in the manual and see if you need to ground it or connect it to power in order to disable it.
Dec 21, 2009 | Jensen Car Audio & Video
Can i disable the headlights on in the daytime on my 2000 suzuki gran vitara, i am going through headlight bulbs very often and they are 20 dollars a pop.
They only activate when the car is in gear and the parking brake is disengaged. find the grounding wire off the parking brake lever and break the ground when brake is disengaged, you may also lose you parking brake warning light. Not sure if it's on a seperate circuit or not.
Oct 14, 2009 | 2000 Suzuki Grand Vitara
Parking brake disable model jensen 9511ts
on the jensens, there is a way to disable the parking brake without having to put a switch on the parking brake wire. the catch is that you will need the remote control to get into the service menu. follow these steps
1.turn the radio on and select the setup menu.
2. while in the setup menu, use the remote and press 5-4-3-2-1-0, this should access another service menu.
3. from there, you will see a brake override option.
4. and your done.. hope this helps
if for any reason yours doesnt offer this option. you can always put a switch on the ebrake wire of the screen.
1. use a 2 wire toggle and wire one side the ground and the other to the parking brake wire on the jensen. then do the pattern on the switch instead of using your ebrake.
Aug 28, 2009 | Jensen Car Audio & Video
How to disable the parking brake sensor on lx470
simply hook it to a togle switch. Hook one end of the switch to ground, hook the other end to the jensen, then you can flip the switch off and on to make the jesen think you are using the parking brake
Aug 16, 2009 | Jensen VM9510 Car DVD Player
PARKING BRAKE DISABLE my jensen in dash doesnt want to play dvds its displays a blue screen saying something about the breaks
yes its saying in toorder to play dvd's u must engage parking brake which means the wire is suppose to be hooked up to the parking brake....BUT i know the trick to make it work where u can play dvd's and drive
May 31, 2009 | Audiovox Jensen In-Dash DVD/CD Receiver w/...
Is there a way I can watch a DVD movie on my Pioneer AVIC-Z2 screen without having to put on my parking brake?
Yes, there is a way to watch a movie without the parking brake engaged. The parking brake safety mechanism is there for a reason, and I do not suggest that you disable this sytem so that you can watch movies while driving. With that said, the simplest way to bypass the parking brake system is to take the parking brake wire from the head unit, run a wire to a chassis ground point, and then put a toggle switch inline so that you can flip it on and off. This will simulate the engaging/disengaging of a parking brake.
Again, I do not condone or recommend watching movies while driving. There are enough distracted people driving on the roads.
May 18, 2009 | Pioneer AVIC-Z2 Car DVD Player
Anyone disable the Parking Brake?
Yes, I did it to mine, Just ground it and it will always be *Parking Brake mode* and you can .... You know. :)
Dec 22, 2007 | Panasonic Strada CN-NVD905U GPS Receiver
Uv8
well if you already have it hooked up it is fine you can leave it that way. if not ground the parking brake out 3 times on for a second off for a second then hold it to the ground it should show the screen. put the code in and it is permanent once you go into your menu and turn it off
Nov 27, 2007 | Jensen VM9510 Car DVD Player
Audiovox Jensen In-Dash DVD/CD Receiver w/ 7 LCD Screen" Car Video Player Logo
465 people viewed this question
Top Audiovox Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Are you an Audiovox Car Audio and Video Expert? Answer questions, earn points and help others
