Question about Whirlpool Duet GHW9150P Front Load Washer
Washer won't start
My washer will not start. i have a front load whirlpool. when you push hold to start it just makes small clicks and the water doesn't run. it is showing fdl on the washer display. please help.
  • jen lee Mar 22, 2008
    I have the same problem. My clothes smell of mildew and people have commented on my sons clothing stinking. As I speak my washer is setting with water standing in it. I am so mad the washer is only 21/2 years only. What can I do? Please help!!!
  • Anonymous Mar 24, 2008
    I have the same problem over and over, had it worked on and they put 2 new switches in it so far, and still does the same thing! Very annoying.
    Problem Solver:
  • 19 Answers
  • Whirlpool Master
  • 2,651 Answers
Small click sounds are the result of the door trying to lock and not be able to F DL is a door latch fault, which most of the time is occuring from either a faulty connection to the door latch(wire loose), or a faulty CCC(central control unit). locatd under main top mounted to rear of cabinet. as far as the smell issue, usauallly a result of over use of detergents. you MUST use an HE detergent (HE detergent is speciffically designed for use in front loading machines) and very little of (manufacture calls for 2-3 tablespoons), theres a new product on the market WWW.AFRESH.COM to help cleanout your machine.
Posted on Mar 24, 2008
Whirlpool top loading washer, LXR9245EQ2, quit agitating, spinning and makes a clacking noise, pump looks like it's still holding the water in the tub though and won't pump out?
There are two clips that hold the pump to the motor, remove it and inspect, turn pump axle in either direction. If not replace the pump. However if you remove it you may find a sock or something in which case you can remove item and put back into service. If jammed you need to replace with a new pump. Good luck, masta tech
P.s.if water remains in tub it has something blocking it, be ready to capture any water in tub when removing hose clamps. If it a small amount you may be able to just lean it backward to hold water.
Aug 21, 2011 | Whirlpool LSR5132PQ Top Load Washer
Hi I have a whirlpool front load washer model number ghw9100lw my problem is that i am getting a f05 code i have changed the temp sensor and i am getting the same code i have unplugged the washer now when...
Check and replace
- Flowmeter.
- Water inlet valve
Make sure to unplug power cord before you replace the part and also make to clean drain tube and filter every year.
Jun 29, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Will not start flashs dl then f
Make sure you hold the start button for about 5 sec. Then Take the front bottom cover off ( 3 screws- real easy) when facing the front look at bottom right and there is a little metal switch make sure that the swith is making contact or push it back and hold it and push the start button again for 5 sec. it worked for me, hope it helps.
Aug 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer door won't secure
Replace the wax motor and door lock mechanism.
Jul 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front load washer LHW0050PQ often will not start
Unplug the washer for 10 min. This will reboot the circiut board. Select one cycle. Selecting too many cyles in a short period or pushing too many buttons in a short period can overwelm the little brain in the board.
Apr 30, 2009 | Whirlpool LHW0050PQ Front Load Washer
Whirlpool Duet Sport not running it makes clicks and it grinds
A common problem with noises from washing machines has been the under wire that may come out of small clothes. In the washer they can get stuck in one of the inner basket holes and make a scrapping noise, they can actually make there way into the pump and jam the pump, or make a terrible noise when the pump is running. Grab a flash light and have a peek inside the washer for this. Front load washers seem very common to this happen! If the tiny cloth is showing signs of fraying, may be best not to wash it in the washing machine, replace the cloth.=======
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Dec 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Front Load Washer
small_11_21.jpg For a detailed Washing Machine illustration, click below.
redarrow.gif Top Load Maytag Style
redarrow.gif Top Load Whirlpool Style
redarrow.gif Top Load GE Style
redarrow.gif Front Load Maytag Style
redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Some problems that can occur with your top-loading washing machine are:
There's an error code on the digital display
It doesn't work at all
It won't drain
It doesn't spin
It doesn't agitate
It's noisy
It leaks
It's off balance
There's no hot water
There's no cold water
It's slow to fill
There's no water at all
The clothes are wet after spinning
The cycle doesn't advance
There's no delicate or regular spin or agitate
It's overfilling
It's underfilling
The water temperature is incorrect
Hope this may help;
Aug 10, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
98 people viewed this question
Dan Webster
Dan Webster
Sal De
