Question about Giottos (VT806) Tripod
Giottos VT 806 tripod
Ive attached my canon S5IS camera onto the tripod but when connected the camera falls back and forth. How do I tighten it so it doesnt fall?
  • 48 Answers
The long pan handle tightens and loosens front to back moves. Are you using it? If you are in the USA and need help call us at 800 735-4373
Posted on Oct 21, 2011
How to remove the head of a Giottos camera tripod
Most tripods have a 1/4" thread attached to the centre column, which then screws into the base of the head (some may have a 3/8" thread, but the principle is the same).
Grasp the head firmly in one hand, the shaft firmly in the other, and rotate the head counter clockwise to remove the old head. If it has been in situ for some time, it may be stiff to rotate.
Once you have removed the old head, lubricate the threads on the centre column, then attach the new head, rotating this one clockwise.
If the old head will not unscrew under firm manual pressure, remove the centre column and place in a vice, packing it with wooden battens to protect it. Then attempt to unscrew the head, using a mole grip or similar if necessary.
Sep 12, 2016 | Giottos Photography
I live in Spain.I have a Giotto tripod VT-806 and have lost the top camera mount and screw. Do you know where I can get one.
Take your tripod to a Giotto dealer, or go to www.giottos.com/ and order a replacement quick-mount camera plate. While you're at it, buy a spare!
Aug 27, 2016 | Giottos (VT806) Tripod
I have a giottos MTL 8360B tripod and I have lost one of the bolts/screws that clamps the centre column. Does anyone know how/where to order replacement parts? Thanks
Best to contact closest Giottos support or distribution centre in your country. Check this site. maybe first try your local camera shop.
GIOTTOS IND INC
Look like it may be a very old model as it is not showing up in the current product lists.
Sep 12, 2014 | Photography
Mg8240b
-If you need to order repair parts for your Giottos MG8240b tripod..., (vs accessories such as camera plates)..., I would suggest that you use the following link to contact the Giottos distributor in your country. They should be able to supply you with parts diagrams, this will allow you to provide them with the info to get your tripod up and running again.
GIOTTOS IND INC
-Hope this helps.
Peter
Aug 25, 2014 | Giottos Photography
Legs Locks Loose
Ross
-It is possible that you are overloading the tripod, thus causing this problem (check specs on tripod model)
HOWEVER IF YOU AREN'T....Giotto uses (2) different leg lock designs..., quick release (normally adjusted by a socket wrench) or rotary (screw locks)!
- If tripod uses screw locks, sometimes foreign material gets into the mechanism and either damages it or prohibits from tightening!!!!!
Note: rotary locks are easy to maintain & if you need parts..., they are user replaceable and usually inexpensive! (contact Giottos distributor in the country you live in)!!!
BUT FIRST!!!! (often problem is caused by dirty lock mechanism)
-carefully unscrew the leg lock (that is slipping) until it separates from the leg higher leg section & carefully pull out the lower tube (at the top of the lower tube will be 'shims' that are part of the lock mechanism).
-Look closely at existing 'shims' do they show signs of cracking, of a build up of dirt, etc. (if damaged they will need to be replaced)
-if shims are undamaged..., use rubbing alcohol & a clean cloth to clean shims and both the tube they sit on and the inside of the tube they slide into.
-once both sides of the tubes and both male & female threads of the locking mechanism are cleaned..., place a light coating of a light oil into the threads (sewing machine oil, bike chain oil, etc)...., do not get oil on the shims!!!!!
-replace locking shims back into position and carefully slide leg tube back into place..., then screw locking collar on (this should not take any force..., if while threading lock collar back on..., it seems tight..., back off collar and check positioning of shims). Repeat procedure!!!
TEST RESULTS!!!
Note: in most cases with rotary locks, problem is purely a maintenance issue, cleaning usually fixes the issue!!!
Peter
Nov 08, 2013 | Giottos (BL1150) Tripod
Customer service for giottos
To order service parts contact the importer:
Canada-JCL Sales (Richmond B.C.)
USA-HP Marketing (Pine Brook NJ)
-Inform them of the tripod model and possibly provide them with photos of where the spreader arms attach to both the legs & the center column...., you may require additional parts.
Mar 31, 2013 | Giottos Vt-809 3-section Compact Tripod...
I have a Giottos (VT806) Tripod and one of the centre stays has broken. Where can I get a replacement?
If you are in the USA call 800 735-4373. You will probably have to send the tripod in but they will direct you. The VT 806 is being discontinued and replaced by the HD444
Dec 25, 2010 | Giottos (VT806) Tripod
How to fit canon s5is on a tripod stand (fotomate)?
I'm not sure what you're asking. There is a threaded tripod socket on the bottom of the camera. You just screw the tripod into this socket. Is that what you were asking?
Nov 07, 2008 | Canon PowerShot S5 IS Digital Camera
Tripod
If you have not found the part for your tripod you are looking for, I have the whole assembly complete, still in the original box.$50 and it's yours.
Jan 01, 2008 | Photography
Giottos (VT806) Tripod Logo
400 people viewed this question
Top Giottos Photography Experts
Steve
Alcolu John
Alcolu John
Tony Parsons
Tony Parsons
Are you a Giottos Photography Expert? Answer questions, earn points and help others
