Acer pd110z projector lamp starts then stops
When the lamp first fires no problem for 10 12 seconds then comes back lamp error and powers down.
  • Shea Kelley
    Shea Kelley May 31, 2008
    my optoma hd 70 runs for about 10 minutes and flickers different colors all of a sudden and then powers down.
  • Anonymous Mar 03, 2009
    same problem, after powering the projector it works fine for 15 minutes then colors get really distorted like rainbows and stuff then the red diode starts on the projector, signifying the lamp. it has 1500 hours on it though. however this only happens when connected to the pc, if i play xbox on it it can go for hours without problems. i just unplug the cable to the projector and let it cool for a min, then plug in xbox and its good to go. strange no?
    Problem Solver:
  • 12 Answers
Probably a dying lamp. How many hours does it have on it?
You might try carefully removing the lamp and then putting it back in. Perhaps it has a slightly bad connection that is causing it to consume too much power and it shuts down.
Posted on Mar 24, 2008
Shut down after 30 seconds
Many projectors shut down if they cannot find anything attached to them.
Make sure you have a computer attached and sending an image out to it before you hit the projector reset button again.
It's a bit like the chicken and the egg since some laptops won't send an image out the cable unless it senses a projector, and the projector shuts down if it does not detect an incoming signal fast enough.
Apr 23, 2014 | Acer PD528W Bulb
Red power, blinking red temp
if the Lamp error and Temperature error lights are flashing red this means that there are two separate errors.
  • A flashing lamp light means the lamp failed to ignite. It could be a lamp driver problem or lamp failure. Replace the lamp to resolve the issue. If the issue is not resolved, then service the projector.
  • A flashing Temperature light signals a fan error. Turn the projector off and allow it to cool down. If the light is still flashing after the projector is turned back on, service the projector.
Goodluck..
Feb 25, 2008 | Hitachi CP-X250 Multimedia Projector
Acer x110 projector fan problems
you need a new fan
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: lampdeng@hotmail.com
http://www.lampdeng.com
any questions, feel free to contact me
have a nice day!
Feb 17, 2013 | Acer Projector Lamp for PD110, PD110z
Replace the 2 bulbs. Unit powered up correctly and turned on like normal. Then Lamp1 and Lamp 2 indicator lights blinked (Indicating Start UP). After some period of time, it switched to Red 6 times blink...
1 red blink every 2.5 seconds indicates a cover error-- for this check the lamp cover
2 times red blinks very 2 seconds indicates temperature error. for this let the projector cool off check filters and fans that there is no blockage of air for proper cool down
3 red blinks every every 2 seconds Power error. incorrect voltage input or internal malfunction.
4 red blinks every 2 seconds indicates Fan Error check the fans make sure they are working and not blocked or need replacing.
i have nothing on 6 ligths go ahead reconect and check for proper count. hope this information helps.
Best of Luck.
Ray.
Jun 05, 2011 | Sanyo PDG-DXT10L Projector
Projector posted error, "replace bulb" Projector
Your projector need replacement of lamp unit if you don't want yet you just reset the lamp counter
procedure:
Power on projector
press MENU key
Press right arrow key to select Option
Press down arrow key to select lamp Hours
Press and hold down the ENTER key 5 second (lamp hour counter show red)
press POWER button to turns off the projector
now you power on your projector and no error displaed and no itself turn off after 15 minutes
Apr 13, 2011 | Panasonic PT-L785U Multimedia Projector
Light on my sharp xg-nv4su projector comes on for a few seconds then goes off. how do i reset the lamp timer?
To reset the lamp timer you:
1. Turn off the main power button on the back of the projector.
2. Hold down the down, right, and enter buttons on the projector.
3. Turn the main power button on the back back on.
4. The projector should come on, hold down the buttons for at least 3 seconds after it comes on. If it doesn't come on, repeat the steps.
5. Turn the projector back off using the sleep button on the top of the projector. Then turn it back on. If it comes on and is functional, you have successfuly reset the lamp timer.
Jul 25, 2009 | Sharp BQC-XGNV4SU/1 Projector Lamp for...
Vertical line white, regular, blinking.
I don't think it's the bulb. Sounds like an LCD panel issue. Maybe one or more of the 3 LCD panels is either not working right or the unit has been dropped/jarred and the panels have moved (All three have to line up right optically to give the right colours). You need to take the projector to a qualified service centre.
I hope that solves your Problem, If so kindly accept it.
Thank You, Arjun.
Apr 01, 2009 | Acer Projector Lamp for PD110, PD110z
Lamp will not come on
try pressing and holding the enter button on the projector for about 30 seconds - this resets it. It worked for me!!
Feb 10, 2008 | NEC VT460 Multimedia Projector
Sony HS10 error lights
you could try a new lamp, some lamps fire, but do not stay on
Nov 09, 2007 | Sony VPL HS10 Multimedia Projector
615 people viewed this question
jasbo
jasbo
