Question about RCA S2001 MP3 Player
Need help with MP3 palyer
My RCA MP3 player won't show up on my computer it has a yellow ! showing because the hardware won't add correctly. I talked to Dell and they said I need a CD to download the hardware but when I purchased the player it didn't come with one. Thanks
Ok this is wat u gotta do first go to my computer then click on jet below then u gotta click media and then music and delete anything u want
Posted on Mar 24, 2008
6ya staff
SOURCE:
I cannot see any sub folder
Dear Sir,
I have samsungYP-U5 2gb mp3 palyer when i connecting to computer its not showing some folders..but when i remove from computer its showing which is not showing in computer .....how can i get that missed folders in computer pleas give advice
Thanking you Govardhan chellem
Aug 08, 2011 | Samsung YP-U5 MP3 Player
I put a song on my rca opal mp3 and it shows up on the computer but not on the player help
first things first, you have to ensure that the song you are putting is encoded into a compatible format.e.g. mp3,wma etc. it is possible that the song you are talking about is not compatible with the player.hope this helped you?
Oct 21, 2010 | RCA OPAL M4001 MP3 Player
Computer not reading
check to see if the media player has syncronization functions working and update drivers for MTP device as well as the media player. Check to make sure the hardware add indicates proper detection and not a yellow ? because it is only recognizing its usb.
Aug 24, 2009 | SanDisk Sansa m250 MP3 Player
Syncing files from Media Player to Rca Th1100a
You can view your playlist by opening the device in windows explorer. Start/My Computer/double click corresponding drive letter to your device.
For a copy of the user guide .pdf e-mail a request to
[email protected] & I'll e-mail you a copy.
Feb 02, 2009 | RCA TH1101 MP3 Player
RCA TH1602 MP3 Player
As you plug the device into the computer, hold down the Play button. Leave it held until you see that it is installing new hardware (something like ROM initializing). If this doesn't work, you may need to add devmgr_show_nonpresent_devices=1 to your environment variables (search that variable to find how if you don't know) and then in the device manager go to view and show hidden. Make sure the device is not plugged in and then remove all references to it in the device manager (any grey USB MSD or HID is what I removed). Now plug in the device while holding in the play button. I had to reboot to complete this part. Now you should be able to load the firmware (this was required here, it will format the device so there will be no files on it, including the ones that it shipped with).
Oct 15, 2008 | RCA TH1602 MP3 Player
I have downloaded videos from YouTube using real player, and when I try to add them to my RCA Opal, the video converter won't read the file.(possibly since its from real player) When I go to its internal...
Make sure you have copied the file to the correct folder in your Mp3 player. Sometimes if it is copied under a different folder, you will have the issue you have just described..
May 15, 2008 | RCA Audio Players & Recorders
My mp3 files have corupted
thats awful. i suggest that your should reformat your mp3 player. it was corrupt by certain viruses.
pls rate me up.
Jan 22, 2008 | RCA TH1101 MP3 Player
RCA OPal M4002 MP3 Player Problem
after pluggin it on to ur computer,go to device manager and scaan for new hardware changes..this should detect your player
Jan 01, 2008 | RCA OPAL M4001 MP3 Player
Rca mp3 player wont connect to computer
were can i find the software for this mp3
Sep 13, 2007 | Audio Players & Recorders
RCA TH1101 MP3 Player Problems
Remove and reinsert batteries - if that fails, go to RCA website for firmware upgrade - if that fails:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If that fails, it's dead.
-Tha Mp3 Doctor
Jul 04, 2007 | RCA TH1101 MP3 Player
RCA S2001 MP3 Player Logo
107 people viewed this question
Top RCA Audio Players & Recorders Experts
Ekse
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
