Question about Samsung TXH1970 TV
Duaghter ran a magnet over the TV
There is a green section. i dont want to run over it again. (see http://www.fixya.com/support/t102902-magnet_touched_screen ) does it really work?
    President:
  • 2,992 Answers
The TV requires a manual degaussing. Degaussing is the operation that neutralizes a magnetic field on the face of the tube that causes the color distortion. There is a coil inside the set that does this each time you turn the set on, but it's not strong enough to counter the field the magnet left behind. An external degaussing coil would clear this up, unless the magnet used was so strong it caused phyical damage to the picture tube (but that's unlikely). You could purchase a coil from any of several internet vendors, or call a TV shop in your area to see what they would charge.
(There are some techniques described using a small motor appliance like a hair dryer as a degaussing coil, but generally they don't work reliably. If you are really curious, a quick search using Google or another search site will get you links you can check out.)
Posted on Jan 23, 2009
SOURCE:
My tv has no power, when plugged in the green light flashes constantly about once per second, pressing the power button has no effect. The only voltage coming from the power supply is 5v. Unplugging the...
It sounds like the standby 5vdc is working but the main board is not sending the PS_ON signal to turn on the 12vdc/24vdc power supply section and the BL_ON for the inverter board. I would look at the sch. to see if you have the PS_ON (3.3~5VDC) to turn on the power supply section first. I have a feeling you are having the main board problem.
All the LCD TV's operate just about the same as explain in my guide.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: www.interliquidparts.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Aug 12, 2011 | Sharp Aquos LC37D44U 37 in. LCD HDTV
I cant install my A4tech pk-635m webcam because i cant find the cd installer.how can i install my webcam even without the cd?
In your web browser, go to
http://www.a4tech.com/downloads.asp
Select 'PK' in left box and 635M in right box in the downloads section. I have shown it in green in the following screen capture.
Click 'GO' button. The Orange color GO button within green area.
Now click 'Driver for PC' button on left to download the driver.
Give me four thumbs if you succeed!
Jul 19, 2011 | Computers & Internet
My question is that my toshiba tv 37inch tv, stop working the tv went blank but the power light is still blinking with no picture. Light still blink green
It may be in safety down mode due to shorted circuits or failed power supply. I would start at the power supply section first by looking for any caps with domed/leaky tops, burnt components, etc.
Please read my guides first;
Jun 26, 2011 | Toshiba Televison & Video
The Stand By led is red, after become green for 5 seconds and after red again. The power board do not have 24V and 12 V. The 5 VCC is present.
All the caps look good (bad cap can look normal but can have high ESR)?
Are you getting PS_ON from the main board to turn on the 12/24vdc power supply section?
It may have sensed shorted or over current draw so it tsays it shutdown mode. Try disconnecting the power cables to the inverter board to see if the 12/24v will come back.
Parts: http://interliquidparts.com/
Jun 22, 2011 | Jwin JV-DTV37 37 in. HDTV-Ready LCD...
I own a Westinghouse L1975NW, Power light Green, Image on screen just very dark, It fit the bill for the common backlight issues that this monitor seems to have. So I did the repairs, (Bought the kit-...
Did you recheck the MOSFETs? You will need a set of test lamps to test the inverter to see if it is the inverter or the lamp assemblies. I am surprised that the kit only contains 2 caps, it should have at least 4 caps, 2 each for the 5v and the 18vdc power supply section. Take the DC reading on the caps to see what you have, take the reading WITHOUT turn on the monitor (the power supply is running al the time), then turn on the montior to see if it maintains the output voltages.
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Apr 05, 2011 | Westinghouse L1975NW Monitor
My picture has a green circular section and a purple one what is wrong please?
That happens with magnets and could be caused by the magnets on the speakers, some green or purple stay forever, but some disappear when you unplug and unplug the tv repeatedly or with other magnets.
Mar 15, 2011 | Bush 2871NTX 28" TV
How to degauss viewsonic vp201b lcd
You do not degauss LCD monitor, it does not use electron beams (affected by magnetic field, if the showdow mask is magnetized, it can mees up color display) for making pictures like LCD.
You only degauss CRT type monitor.
http://en.wikipedia.org/wiki/Degaussing
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Jan 04, 2011 | ViewSonic VP201b 20.1" LCD Monitor
I need to get the red and green lines to match up again. how do i do it?
ok you need to "comverge the set" try go into setup in customer menu and use the convergence options. DO you have the convergence option? if you dont you might have the fl231 problem. if you do not have that option read fl231 problem in tips and howto section....http://www.fixya.com/support/r1062030-fl231_problem_convergence_not_in
Oct 13, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Samsung TXH1970 TV Logo
220 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
