Question about Philips GoGear HDD1830 MP3 Player
My media player 11 won't show up on my computer? it was working fine but now it wont show up
  • 8,596 Answers
Read the warning about this device and Windows Media Player 11 at www.usasupport.philips.com
You will need to reformat the GoGear in Windows Media Player, but do a firmware upgrade first - open the Philips Device Manager and click on the Update tab. Then click the update button. After the firmware upgrade is done, open windows Media Player.
REFORMAT FOR WINDOWS MEDIA PLAYER - Erases Everything: Connect your GoGear to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Philips Go Gear SAXXX" (wording may vary slightly), and then select "Format." - this should erase everything, and make your player properly read in Windows Media Player.
-Tha Mp3 Doctor
Posted on Apr 08, 2008
My usb does not recognize the mp3. My computer does not show it....
What kind of MP3 player do you have? Also most players are detected as MTP device,,, you need to make sure you have windows Media player 11 installed on your PC or it wont detect it!
For windows XP/Visa u need media player 11
http://www.microsoft.com/windows/windowsmedia/player/download/download.aspx
Jan 20, 2010 | Audio Players & Recorders
Removing Windows Media Player on my Desktop
Method 1: Uninstall Windows Media Player in safe mode loadTOCNode(2, 'moreinformation');
  1. Start the computer in safe mode. To do this, follow these steps:
    1. Restart the computer.
    2. Press F8 while the computer is restarting.
    3. Click Safe Mode, and the press ENTER.
  2. Click Start, click Run, type appwiz.cpl, and then click OK.
  3. Click Windows Media Player 11, and then click Remove.
  4. Follow the prompts to uninstall Windows Media Player 11, and then restart the computer when you are prompted.
  5. If Windows Media Player 11 is not removed, try Method 2.
uparrow.gifBack to the top Method 2: Run a program to remove Windows Media Player loadTOCNode(2, 'moreinformation'); If Method 1 does not work, you can use this procedure to uninstall the core of Windows Media Player.
  1. Click Start, click Run, type %windir%\$ntUninstallwmp11$\spuninst\spuninst.exe, and then click OK.
  2. Click Next, and then click Finish.
uparrow.gifBack to the topTo prevent Windows Update from downloading Windows Media Player 11, follow these steps:
  1. Click Start, point to All Programs, and then click Windows Update.
  2. Click Custom, and then click Software, Optional in the Microsoft Update Home pane.
  3. Expand Windows Media Player 11.
  4. Click to select the Don't show this update again check box.
    Note If the Don't show this update again check box is unavailable or dimmed, click to clear the Windows Media Player 11 check box, and then click to select the Don't show this update again check box.
  5. Click Review and Install updates to save the setting.
Jan 17, 2010 | Intel Cpu Pentium Dual-Core E2180 2.0Ghz...
I plugged my Creative Zen into my computer and it wont show up on my media player
found this hope it works
posted on Feb 25, 2009 abeales
If you have windows set to do automatic updates, you most likely had a windows update installed that caused this conflict with Win Media Player 11. No fix has been posted by Microsoft yet, so the only workaround is to Uninstall/Rollback Windows Media Player 11. Goto <Control Panel<Add/Remove Programs and remove Windows Media Player 11. Follow prompts, restart computer when prompted to. Also uninstall Windows Media Player 11 Runtime application following same procedure above.
This will roll your Windows Media Player back to version 10 or 9, whichever you had installed prior to version 11. You will need to re-configure Windows Media Player again.
Your Zen should now be recognized by WMP and Creative software. You probably need to upgrade your firmware at this point, follow the instructions on upgrading your firmware, and you should be good to go.
This is a windows problem, not a creative problem. Dont blame Creative for the screwed up hotfixes that Microsoft puts out on a regular basi
May 09, 2009 | Creative Labs ZEN V Plus MP3 Player
Samsung YP-K3 won't show up on Windows
Hey,
you need media player 11 or newer
http://www.microsoft.com/windows/windowsmedia/player/11/default.aspx
it should work fine instantly with media player 11 installed, just plug it in ones the media player is properly installed (you may need to restart, I don't remember for sure)
and it should work right away with wm11.
Let me know if you need anything else.
Thanks,
Ekse
Feb 21, 2009 | Samsung YP-K3 MP3 Player
No longer seen by any computer
For me, having upgraded Windows Media Player to version 11 caused the problem you are experiencing. Find a computer with Windows Media Player Version 10, then use iRiver's firmware update tool to install new firmware (version 1.77), then your T10 will work fine even with Media Player Version 11.
May 12, 2008 | iRiver T10 MP3 Player
Scandisk 1gb
There could be several issues here.
Is the computer showing the Sansa as plugged in?
Does Windows Media Player show the Sansa as plugged in, or does WMP say "Please Connect a Device"?
Are you running Windows Vista or windows Media Player 11? If so, grab the Firmware update from Sansa's website at: http://www.sandisk.com/Retail/DriverDownloads.aspx
If the player keeps freezing while plugged into the computer, you may need to Format the player in Windows Media Player 11 after performing the firmware upgrade. This will erase all of your songs off the player, so you will have to reload them. But your player will work fine after that.
Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
-Tha Mp3 Doctor
Jan 15, 2008 | SanDisk Sansa c200 MP3 Player
Not detected by computer - cannot recharge battery
yay I found a solution! so I kept getting the error about an MTP device, so I did a big search. I am running vista on a 32 bit processor. what you need to download is the MTP installation programme from windows. so click on http://support.microsoft.com/kb/939211
and then just select what processor speed you need. should do the trick! I also downloaded http://www.microsoft.com/downloads/details.aspx?FamilyId=A2E73160-E862-4F19-BB26-C0CAFE798955&displaylang=en initially, but it didn't appear to work. hope that you all get to the bottom of this frustrating problem :)
Dec 18, 2007 | Samsung YP-U3 MP3 Player
Samsung yp-k3
Do you have media player 10 or 11 installed?
Media Player 11 causes serious problems. You will need to remove media player 11 and re-install 10 or rollback 11 to 10.
Make sure you have removed ALL traces of media player 11.
Nov 16, 2007 | Samsung YP-K3 MP3 Player
Cant detect player
Do you have media player 11 installed? It wont work with media player 11.
Also make sure you have no traces of media player 11. When you roll back from 11 to 10 it still leaves a trace of media player 11. Check your add/remove programme setttings carefully to make sure there is no reference to media player 11. If there was and you have removed it, restart your computer.
Nov 10, 2007 | Samsung YP-K3 MP3 Player
Zen vision M wont dock
Zen Vision:M Not Responding SOLUTION! to No Charge, Device Not Connected or Recognize
http://www.anythingbutipod.com/forum/showthread.php?t=10960
Oct 08, 2007 | Creative Labs ZEN Vision:M Digital Media...
Philips GoGear HDD1830 MP3 Player Logo
123 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
