Question about Matsonic MS9317E Motherboard
Ms9317e does not boot
I've changed power supply and CMOS battery, still no boot, nothing except the power light flashes on then off.
  • mwwbutler Mar 21, 2008
    I've
    I've reset the BIOS also.
    Novelist:
  • 104 Answers
You better go to last resource directly:
1. disassemble the system completely and take the mother out the case... Give it a perfect cleaning.
2. place the mother over a wood table or something like that (mother without anything but the cpu).
NOTE: if you are running onboardvideo do not connect external video board... if you are using external videoboard and do not have onboard video, you might have problems on the board... so you could need another one).
3. just connect RAM and power supply (the power supply must be out of case, placed over the table too and well connected to mother and to power line.
4. power on the system by jumping the pins on the motherboard... you can find them under the identification front pannel or something like that deppending on the model... just the pins that normally you attach to the cables that leads to the buttons on the front of the case. (use a screwdriver and do not touch anything on the motherboard with your hand if its connected to powerline).
then, and after trying vga adapter if you have one and trying rams one by one in different socks... you will know that if the system never boots up, you have hardware problems, either on mother, ram and less probably, power supply or very rarely cpu...
g luck, in this cases... better go live chat...
Posted on Mar 22, 2008
Mysteriously stopped booting up
I hate when people just guess what is wrong at sites like this, but I'm "guessing" your power supply needs to be replaced. I've seen similar symptoms before. They're cheap and easy to replace. I'm 80% sure that will fix your problem. Just make sure it has the correct standard or SATA power connectors for your hard drive(s) and CD drive.
Oct 07, 2012 | Asrock K8NF6G-VSTA Motherboard
Help! Computer will not boot-up to bios check,
I would look for the CMOS reset jumper on the motherboard, if there is one, and while PC is off take of the jumper, then put it back in place. But the more easier option is to just simply remove the CMOS battery from the motherboard, unplug PC completely first, leave it out for a few seconds, then replace it. If that works, you may come across some operating system start options to start the os, depending of what version you have make sure you select the Delete sleep mode data/hibernation data(something along those line), and start OS normally. By the looks of it you've tried everything possible, but last resort would be to try the resetting CMOS/removing CMOS battery. If all fails, try testing using a different power supply.
Jan 26, 2010 | ASUS P5ND2-SLI Deluxe Motherboard
Hello I have a thinkpad x31 and it won't boot. When I push the power button the lights go on and then they go off except for the power light.Nothing happens after that . I tried booting from other sources....
exacly from the motherboard, i think u can not prepaire because much know electromagnetic to change the chipset so difficult 2 u. u can take to brand for prepair
Jan 16, 2010 | IBM ThinkPad X31 2672 Notebook
I have an HP Pavillion a1250n which has a MS-7184 V1.0 that will not boot. When turned on the HP Invent logo screen appears with thw following at the bottom:(Esc=Boot Menu)(F1=Setup)(F10=System...
It sounds as though you might have a problem with BIOS.
You should remove your motherboard battery (little round silver disc) and if you can find (or Google motherboard model#) the CMOS reset jumper, you can remove the battery for 30 seconds and put it back in and reset the CMOS, then see if it boots. If it doesn't, you might need to flash the BIOS, which is not recommended unless you know what you are doing.
Nov 16, 2009 | Intel Motherboard
MY PC HAS BOOTING PROBLEM
Hi bridey28, when you replaced the cmos battery & the bios did not maintain the correct time than the cmos is not at fault. More likely its your power supply. The cmos receives its power (Recharge) from the power supply. An average cmos battery should last for 5 years. The fact that you attempt to power up the PC & you have to wait, points to a power supply problem. Not a bios problem.
Bios corruption is rare, unless you have tried to flash the bios & it failed. Replace the power supply before attempting flashing the bios. Every manufacture warns against flashing the bios. Only flash the bios if your 100% sure that it will correct a bios malfunction. If the issue presist after replacing the power supply, Intel has instructions of (How to flash the bios) on their site.
Here are the instruction from Intel for your MB model number.
http://downloadmirror.intel.com/5519/ENG/BIOS%20Update%20Readme.pdf
You'll need this link to download the bios file;
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=899&OSFullName=Windows*+XP+Home+Edition&lang=eng&strOSs=45&submit=Go%21#SAP
Good luck bridey28!
Need more info, post here.
Mike
Jan 14, 2009 | Computers & Internet
My gateway 700 xl doesnt boot
Unplug the power from you 700xl and from you monitor. Try removing the cmos battery and reinstalling it. Then, plug everything back in and try restarting. If it continues to give you the yellow light, you may need to replace the CMOS battery, especially if it is more than two years old.
Another thing to consider is if your power supply is underpowered for the number of external devices you have plugged into it (i.e., cd, dvd, external hard drives, printers, pci cards, etc). Gateway installed very low powered power supplies in their 700xl desktop computers. Usually only around 250 watts maximum.
If you are replacing the power supply with another 250 watt maximum power supply, and you have a lot of external devices plugged in, you may need at least a 350 watt power supply....if your CMOS battery is not the problem.
Nov 06, 2008 | Gateway 700 XL PC Desktop
Hp 1270n power problems
Sounds as if your power pack might have a problem.blown fuse ect.I whould remove the cmos battery and or change jumper pin setting to start fresh in the bios settings.after removng the cmos battery,Make sure to put it back in before you re boot your computer. Good Luck garydalel
Dec 29, 2007 | Gateway (4000811) Motherboard
Matsonic MS9317E Motherboard Logo
376 people viewed this question
Top Matsonic Computers & Internet Experts
David
David
Computer Links
Are you a Matsonic Computer and Internet Expert? Answer questions, earn points and help others
