Question about Lands Phones
The screen on my sony ericsson z310i phone has gone blank. The phone still works but I cannot read messages.
  • Anonymous May 22, 2009
    how can you master reset if the screen is blank
  • 5 Answers
Remove phone battery for 5 minutes or longer (this resets the phone, nothing will be lost), if this does not work, a master reset (which is an option in one of your phones menues) or contacting your service provider is needed. ( master reset will make you loose ringtones and in some phones cases you will lose phone book and all downloads. I KNOW THIS SOUNDS HORRIBLE, but at least your screen will work. ringtones you downloaded in the last 30 days, can be re-downloded for FREE)
Posted on Mar 21, 2008
SOURCE:
Hi, Sony Ericsson z310i mobile, screen is showing blank, other lights on, cannot access message or make a call, pls advice
there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Read the tips on this link for more info about phone screen problems; http://www.fixya.com/support/r6382458-screen_problems_phones
Take care.
Mar 31, 2011 | Sony Ericsson Z310i Cellular Phone
Switches on but has blank screen sony
change ribbon and if problem continues change lcd
Jul 31, 2010 | Sony Ericsson Z310i Cellular Phone
Need help with my sony ericsson Z310i mobile. Screen not working
Since you know you cannot transfer your contact from the phone to the sim because of the blank screen, it means you have to replace the screen of the phone in other to access the menu. I will advice you to take your phone to a technician to fix the screen.
Jan 13, 2010 | Sony Ericsson Z310i Cellular Phone
My sony ericsson Z310i cellphone has now a blank grey screen
I fixed my daughters phone last night by doing this.
This is a simple connection problem, that occures at either end of the ribbon connection at the top right (looking from the back of the phone)
you need to take the phone apart the screen side and the kepad side.
pull the connector ribbon out of both ends and then ease the screen out of the casing.
re connect the screen ,making sure to push it in firmly.
then connect the other end of the ribbon.
Now connect the battery terminals and turn the phone on.
The screen should light up and resume normal function.
Nov 03, 2009 | Sony Ericsson Z310i Cellular Phone
Sony ericcson z310i blank screen
display ic is out so change the the display contact sony ericsion customercare
Sep 11, 2009 | Sony Ericsson Z310i Cellular Phone
My sony ericsson f305 has a blank screen it dosent turn on or off it just stays blank can you help me?
Try popping ur battery out then pop ur sim out the put them bak in and when u turn it on, DONT SHUT IT!!!!!!
Jun 15, 2009 | Sony Ericsson Z310i Cellular Phone
Sony ericsson Z310i blank screen
This just happened to me, the solution is to wiggle the top half a bit (like you wanna break it, but don't break it.) The root of the problem is a loose wire that connects the two phone parts. Mine still goes blank on me but then i wiggle it... just a little bit...
Apr 27, 2009 | Sony Ericsson Z310i Cellular Phone
External screen Issue
hi, my sony ricsson z310i was rigestered to vodafone ,spain but i moved back to africa and i cant use it , how do i unlock it
Sep 06, 2008 | Sony Ericsson Z310i Cellular Phone
Question in unLocking Sony Ericsson Z310i
i have sony ericsson z310i which is locked by t mobile. imei of set is 357560016775670
kindly let me know the solution... my email id is [email protected]
regards...
Jun 12, 2008 | Sony Ericsson Z310i Cellular Phone
Lands Phones Logo
250 people viewed this question
Top Lands Phones Experts
Ekse
Marvin
Marvin
Are you a Lands Phone Expert? Answer questions, earn points and help others
