Question about LG WD-14124RD Front Load Washer / Dryer
LG WD12311RD FRONT LOADING WASHER DRYER.
I HAVE JUST PURCHASED THE ABOVE MENTIONED WASHER DRYER. UNFORTUNATELY THE STORE HAS NOT GIVEN US THE INSTRUCTIONS AS IT WAS A DISCONTINUED LINE. WHEN THE WASHER SWITCHES TO DRYER IT TAKES 3 OR 4 ATTEMPTS TO DRY THE WASHING. THE LOAD IS NOT BIG! IS THERE SOMETHING IM DOING WRONG? THERE IS A SMALL BLACK PIPE AT THE FRONT OF THE DRYER, THIS HAS A SMALL WHITE PLUG WHICH WHEN YOU REMOVE DRAINS WATER. IS THIS FROM THE DRYER AND SURELY I SHOULDNT HAVE TO DO THIS EVERYTIME? ALSO ON THE REVERSE OF THE MACHINE THERE ARE 4 NUTS, ARE THESE A STABILITY DEVICE WHICH NEED TO BE REMOVED AFTER TRANSPORT OR DO THEY HOLD THE MOTOR ON? PLEASE HELP!
  • jfdough Oct 06, 2008
    I have exactly the same problem. And was also not given a manual although I was promised one with the delivery. Someone somewhere out there surely should have a solution to this or where we can get hold of a manual!
  • 489 Answers
Those bolts have to be removed prior to use or you will damage the machine.  The drying issue has to be addressed by a qualified LG technician.
Posted on Apr 28, 2008
E3 and be error on maytag washer
E3 error code is indicating that the motor should be running but the hall sensor for the motor is not sensing the turning of the motor.
If the error code comes up all the time as soon as you press the power on button, then it means your control board is bad and reading incorrectly. If it only happens during a cycle, then you need a new motor unfortunately.
Note - You could disconnect the power supply for few minutes, say 15 minutes and see if that resets the control board and solve the problem unless follow what was mentioned above.
For replacement instructions you can download this repair manual for your front load and follow the steps given in the manual and here the search parts.
Hope helps.
May 17, 2011 | Maytag MAH9700AWM Neptune Front Load...
Can I change the side the door opens?
Unfortunately you cannot reverse the doors on this model. There have only been two front load washers that I know of that had reversible doors, the maytag neptune and amana front loaders. Your matching dryer for this model, I believe has a reversible door, but you'll have to purchase a kit to do it. IF needed maybe you can switch the dryer and washer locations to make them more accessible?
Sorry, and good luck to you!
Jul 03, 2010 | Whirlpool GHW9100L Front Load Washer
Gives message...oe
On pg 18 of the service manual for this combo, front-load LG washer/dryer, it basically says if the drain's not working and you see an OE error code, clean the drain pump filter and retry. So first do that.
http://www.retrevo.com/support/LG-WM2277H-Washers-manual/id/438ag213/t/2/
Manual above.Below is a great DIY self help washer site, use with manual to sort your problem out.
http://www.washerhelp.co.uk/diy-repair-help.html
Jun 18, 2010 | LG WM-2277HW Front Load Washer
De1 error message on Samsung front load washer
Hello,De error refers to "Door Error".
You do not need to buy a new machine. You can fix this.
Look at the below mentioned link
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=799
No doubt the above page is for "LG", However it's the basic and would remain the same for all models and machines whether that's GE, LG, Samsung etc....
Thanks
May 30, 2010 | Samsung WF419AA Front Load Washer / Dryer
Where can i find a free service manual for LG WM3431HW?
Unfortunately you won't find one.
LG only supply their servicing manuals to their repair centres and strictly enforce their copyright, so the manuals are not available to the public and when they do occasionally appear the material has been stolen.
Usually I'd recommend a generic repair manual such as the one by Haynes, but LG's direct drive system and a number of other unique technical features mean that the Haynes book isn't as useful as it could be. The WM3431HW is a large capacity and technically advanced washer dryer so it's certainly not as straightforward to service as a traditional front loading washer or dryer. Many LG spare parts can also be difficult to source outside of their own approved servicing organisation.
I respectfully suggest that you either get LG to fix your machine or post a question on this site describing the problem to see if we can assist you.
Mar 26, 2010 | LG WM3431 Front Load Washer / Dryer
Odor from front load washer.
I had the same problem. I did all of the above. What worked for me was to spray the tub itself with a mixed solution of bleach and water. Let it sit for a while and run it on a quick cycle unloaded. Also I changed to powder det. with fabric softner in it. I found the outer tub had the mildew and this solved by problem.
Dec 30, 2009 | LG WM2688H Front Load Washer
I need pedsteal brackets for my Lg washer
the side brackets/screws/manual should've been included. some of the new pedistals no longer use side brackets though. contact lg with pedistal model# located in drawer and research further.
May 07, 2009 | LG WM-2277HW Front Load Washer
Front Load LG Washer and Dryer Pedestals
If the pedestals are properly installed they pretty much become part of the washer and dryer and if those are installed correctly you will have no more vibration then if the units are sitting on the floor. If possible get the washer as close to an outside wall as possible since the floor is stronger there.
Jan 28, 2008 | Washing Machines
"CD" ERROR ON LG WM-3677HW Front Load All-in-One Washer / Dryer
CD means cool down, press the pause start button, the door lock will open. It is an anti crease cycle. It mentions it in the owners manual, but it is hidden deep in the drying section.
Sgt 48
Sep 01, 2007 | LG WM-3677HW Front Load Washer / Dryer
LG WD-14124RD Front Load Washer / Dryer Logo
179 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
