Gateway c140 beeps
C140, occasionally while running I get 3 short beeps. Some startup after everthing is booted and windows is almost loaded I get 1long and 3-4 short beeps, most of the beeps were 1-3 whats up?
    Scholar:
  • 101 Answers
If you have an AMI bios (you can tell when you boot and the black screen has writing on it at startup - the bios type and version is the first thing at the top of the screen)
1 long and 3 short beeps indicates that the memory is not seated properly. You should check that it is secure on your motherboard. If it is seated securely, your memory is maybe faulty.
Posted on Mar 21, 2008
SOURCE:
Hp 310 touchsmart has black screen at startup
310 dash what? 310-1000? it really and all-in-one PC.
what is the full model name and number.
no text? screen never ever shows any thing?
is the fan running inside, and blowing air.? it must.
the steps are here at hp.com
https://support.hp.com/us-en/product/hp-touchsmart-310-1000-desktop-pc-series/4273627/manuals
PC boot in serial progression.
power on
fan blows.
BIOS POST's with errors if found. (3 ways) beep ,text or flashing keyboard led codes.
bios text mesages, logos
windows boots.
windows login, screen
last desktop and (startup files load)
where do you land here.?
see no power? there?
Aug 10, 2018 | HP Computers & Internet
Tip
How to make computer to fast or fast boot ?
Do the following to make your PC Fast
Do 1
1. Turn on your computer, and hold down delete.
2. In the BIOS window, look for the Boot Menu option.
3. Choose the QUICK BOOT to turn off memory test
.4. Make sure the hard drive comes first in the BOOT ORDER.
5. Turn off any logo displays.
6. Restart
Do 2
1. Open your Start menu.
2. Click Run
3. In the command screen type msconfig
4. In the system configuration utility,click either BOOT tab.
5.In the boot menu, change the default setting for Time Out from 30 to 5 seconds.
Do 3
1. Click the Start button.
2. In the Start Search bar, type control userpasswords2
3. Load the User Accounts window
4. Uncheck User must enter user name passwords...
5. Click Apply
Do 4
1.Click Start button and load the Control Panel
2. Under the Control Panel menu, click Programs.
3. Under the Windows Defender heading choose View currently running programs
4. Choose Startup Programs from the Category option
5. Remove Programs that you feel unnecessary for startup
Do 5
How to disable this indexing service
1. Click on Start
2. Click Run
3. Type services.msc
4. Select Indexing Service and Double click on it.
Select Manual under Startup Type.
5. Click Stop
6. Click OK
on Jan 03, 2010 | Computers & Internet
I have Samsung laptop N150 plus Model no NP N150 JP0AJO Bios version -02KY I already says my bios has been beeping countinue I try everthing changed the window and defreg the8 hard disk but result is...
First thing we need to know is what beeps are being heard? Each computer sounds 'beeps code' to tell you where the problem is; like 3 short beeps, or 1 long 1 short. The more you run it at present the more harm you can be doing
Feb 10, 2014 | Computers & Internet
Gateway wont startup. One beep followed by two short
Not sure where you got your information on the error codes but it is partly correct, it is video related, but it isn't the video card but rather the memory location in the ram that is used by the video card. You could try to remove the ram memory clean and re-seat it on the mother board and see if that fixes it, or if your motherboard has two or more ram memory modules, remove the memory and switch which sockets you replace them in (make sure you keep track of the original position of the modules because on some rare motherboards you have to use the memory in a picky order) after mixing up the memory modules check for a boot again, if this corrects the booting then one of the memory modules is defective and may need replacing. Note when you take your memory into a computer shop be sure to use a static bag and proper static precautions.
Nov 12, 2013 | Gateway GT5678 Desktop PC
I would suspect the power supply or a power connection. The only other issue might be a motherboard, which is a bit more involved. Try another power supply if you have one around.
I cant log in to my computer Windows Vista (due to a failed system restore). Now when I go to the login it has a blank user named "other user". That happens in safemode, repair system, and...
You need to access the BIOS - press F1 or F2 (depending on the version)during the start of the desktop - and in there you must modify the boot order: put the cd first then the had disk second. Save the change, reboot, insert the Vista disk and reboot once more - the disk will be loaded.
Jan 03, 2011 | Gateway GT5622 PC Desktop
Ok so I'm fixing this Gateway M-6843 for a friend... When I turn it on it will try to boot but then it goes to a bios looking screen and says Windows Error Recovery at the top and it gives the options of...
It smees your windows having some problem. It might crash.
try to boot the PC from CD, repair the windows. if it cannot repair, then better do fresh loading.
Aug 21, 2010 | Gateway M-6843 Notebook
Beeping upon startup and nothing else.
You need to check the RAM that is the first causes of beeping your system unit. Try to remove the RAM and clean the dust and re insert it. Try to use the other memory slot. You can try it 3 times. Thank you!
Jan 23, 2010 | HP Compaq Presario S5200NX (DM173A#ABA) PC...
Everything was fine then computer froze so I manually shut it down. Now I hear and see the computer boot-up with the Windows Insignia & Gateway logo and the mouse pointer but then it's black, except...
Restart the computer and press F8 key after you hear a beep or before it gives you the Windows logo on Startup. It will give you then the Advanced Startup Options.
You could try the option 'Last Known Good Configuration'.
You may also try Safe Mode option and do a System Restore. On Safe Mode, System Restore will automatically loads up at startup. You can then choose the date and time where you had it last working before.
If those can't be done, you may want to run scan file checker and fix system errors for you. Do this from Start> All Programs> Accessories> right click on Command Prompt. Then select Run as Administrator.
On the Command Prompt, enter sfc /scannow
That will automatically repair system files. However, it may ask for Windows Setup CD.
Oct 14, 2009 | Samsung SyncMaster 2253LW Monitor
Asus Mother Boards - Beeps, Boots, Windows Login Sound, No Image
Yaa you are right. try to boot in Safe Mode and check out driver for display, otherwise you have to change your display card.......
thanks
iqbal
Apr 02, 2008 | ASUS A8N-SLI Deluxe Motherboard
Open Questions:
PC MATIC tech support phone +$&{[email protected]*1O69} NuMbEr USA .Anita This PC MATIC USA phone number +1:8OO:,:8O31069 is ranked #2 out of 2 because 7,728 PC MATIC USA techs tried our tools and information and gave us feedback after they called. The reason techs call # I:8OO:,:8O31069 is to reach the PC MATIC USA tech support department for problems like Where to buy, Complaint, tech support, Repairs, Returns. As far as we can tell, PC MATIC USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. PC MATIC USA has 2 phone numbers and 4 different ways to get tech help. We've compiled information about I8OO8O31O69 and ways to call or contact PC MATIC USA with help from techs like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling PC MATIC USA Calling PC MATIC USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our support call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from PC MATIC USA tech support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with PC MATIC USA's tech support department, you may need to provide them with information that identifies you as a tech, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare PC MATIC USA's phone numbers against each other. Contacting PC MATIC USA in General While I8OO8O31O69 is PC MATIC USA's #2 most popular phone number, it's not the only way to get a hold of their tech care team. You already know from reading above that I8OO8O31O69 is their best tech phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach PC MATIC USA help by calling them, is that other techs give their tech support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact PC MATIC USA.Anita
Oct 17, 2019 | Best Computers & Internet
QUICKHEAL tech support phone +$&{[email protected]*1O69} NuMbEr USA .Anita This QUICKHEAL USA phone number +1:8OO:,:8O31069 is ranked #2 out of 2 because 7,728 QUICKHEAL USA techs tried our tools and information and gave us feedback after they called. The reason techs call # I:8OO:,:8O31069 is to reach the QUICKHEAL USA tech support department for problems like Where to buy, Complaint, tech support, Repairs, Returns. As far as we can tell, QUICKHEAL USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. QUICKHEAL USA has 2 phone numbers and 4 different ways to get tech help. We've compiled information about I8OO8O31O69 and ways to call or contact QUICKHEAL USA with help from techs like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling QUICKHEAL USA Calling QUICKHEAL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our support call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from QUICKHEAL USA tech support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with QUICKHEAL USA's tech support department, you may need to provide them with information that identifies you as a tech, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare QUICKHEAL USA's phone numbers against each other. Contacting QUICKHEAL USA in General While I8OO8O31O69 is QUICKHEAL USA's #2 most popular phone number, it's not the only way to get a hold of their tech care team. You already know from reading above that I8OO8O31O69 is their best tech phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach QUICKHEAL USA help by calling them, is that other techs give their tech support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact QUICKHEAL USA.Anita
Computers & Internet Logo
207 people viewed this question
Ekse
Alun Cox
