Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
Printing I try to print something from off the computer, go to file, click print the print page comes up, click print and nothing happens ??????
    Problem Solver:
  • 14 Answers
Normal to some computer, but apparently, if you still experience this time from time to time,.. if you have windows xp or vista
-go to printers and faxes on control panel
-open printer icon, delete the file, turn printer on and off and that should do it.
goodluck
Posted on Apr 11, 2008
Linux O/S, driver installed. Reports data sending to Printer, then says printing complete. Nothings comes out of the printer; test pages won't print.
Is this a new problem or did it once work and now something's changed, please?
If it prints from your other computer, what happens if you delete then reinstall the drivers on the suspect computer?
May 07, 2016 | Office Equipment & Supplies
Printing problem with pdf files
Open the pdf document.
Click on File-> print-> click on Advanced tab on the print dialog box.
Click on checknext to "print as Image" and click on Ok.
Then click on Ok.
Then try to print.
May 26, 2010 | HP LaserJet M1120 MFP All-In-One Printer
My printer will not print jobs from computer , it will make copies and it will fax but when I click on the icon to print nothing happens. I just put a new ink cartage in. I tried the test page and it...
Right click on the printer icon in the Printer and Faxes menu. Make sure in the pop up box it says USE PRINTER OFFLINE. If it says USE PRINTER ONLINE, click on it and then try printing again. You may also want to double click on the printer icon and make sure there is nothing scheduled for printing. If there is, cancel it and try printing again. If that doesn't work, make sure you have the correct driver selected and it is connected to the right port.
Oct 08, 2009 | Brother Multi-Function Center MFC-240C...
Wont print Printer is not responding when I try printing something out, I try printing something and it does nothing, I know it's plugged in to the computer, and I know that it should be running...but...
If you are using a Windows system:
1. Turn the printer off then back on.
2. Go to Start > Printers and Faxes (in the Control Panel)
3. Right click on your printer and select Properties.
4. Click on the Print Test Page button
5. Does it print? If not, go back to the printers and faxes window and double click on your printer. This will display your print queue.
6. Do you see your test page in the queue? You should and if it is stuck, there's a column for status. This will often tell you what's wrong.
7. If your printer was working before, we know that it is not a driver issue. Worse comes to worse, reinstall your printer based on the instructions provided by the manufacturer.
Apr 08, 2009 | Brother HL-2030 Laser Printer
Dell AIO 942 printing problem
Hi Lei,
You may try to check on the printing settings. You may need to check also if it is defaulting to all. You may try printing it by pages. If the issue persist then there is something wrong with the settings. You may also try to uninstall and reinstall the printer software if the issue persist.
Keep me posted.
Thanks,
Jeff
Oct 11, 2008 | Dell 942 All-In-One InkJet Printer
My hp laserjet 4 plus printer cannot print excel files
wherer are you printing this, A4 is european, north america would use letter, etc..
if you go to control panel, open the printers and faxes folder, right click the printer in question, a window will pop up, click on properties.. a new window should open. click on "Printing Defaults" or "Printing Preferences" then click on "Advanced" ( I believe it should be to the lower left) that will open another window, in paper size make it Letter if your in N America, A4 for Euro.. this will set the deafult print..
Click ok, then print a test page from the general tab..
The reason you getting this LOAD LETTER message. your excel page setup is set to print to letter, your machine is set to print top A4
If you open Excel then go to Print then a window should pop up where you select the printer you want to use, click on Properties, then Lay out, then Advanced, and input the correct paper size before you print.
does this happen with all excels files, or one particular?
Create a new Excel file, and try printing it.. possibly could be in that particular file. I have seen this happen alott particulary with PDF files.. Where the incorrect paper size is in the file..
Sep 23, 2008 | HP LaserJet 4 plus Printer
HP 3330 Printing Problem
1)right click the my computer icon
2)click properties and then click hardware n go to device manager.
3)uninstall all usb ports and then scan for hardware changes
4)ur pc will detect your printer and ask for printer drivers
5)re load drivers and your pc will communicate with your printer
6)for reloding install the cd follow the instructions on the screen and click next
7)restart when the printer is loded.connect the wires and cords properly.
Aug 29, 2008 | HP LaserJet 3330 All-In-One Printer
Trouble with duplex printing
I think your problem is that the 5550 supports manual duplex printing. Print every other page then feed them through again. Never tried it though. Dave Reed
May 23, 2008 | HP LaserJet 5550 Printer
Printing from e-mail
The problem you are having is caused because you are printing from a web based email and just clicking print prints the email, the frame and all the advertising on the page.
to avoid this try the following:
1. Doubleclick the email to open it, not just use a preview pane.
2. Highlight just the text that you want to print. (You can click the cursor at the beginning of the text, hold down the CNTL Key and then press down arrow till all lines of text you want are highlighted)
3. Click FILE, PRINT on the browser menu (DO NOT CLICK THE PRINT ICON)
4. A Print window should appear, in the PRINT RANGE section, click SELECTION, then click OK. At this time, only the text you selected should print.
May 16, 2008 | HP Computers & Internet
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
