Question about Dryers
Amana dryer LEA10AW
I have an Amana electric dryer manuf. model PLEA10AW. It is about 8 years old and does not completely dry the clothes anymore. It gets hot and tumbles but quits early - sometimes after only 5 mins. It doesn't matter if I put it on a timed cycle or the automatic. I have removed the vent hose and cleaned it (no excess build up). The external vent is also clear. I have even washed the lint trap in soapy water.
  • flinn617 Sep 15, 2008
    My dryer does the same thing. I ran it on more dry for 70 min and clothes were still damp. Whats up?
  • 465300 Mar 10, 2009
    The motor will run and it will turn the tumbler but the clothes never dry.... is there a heating element that can be replaced????
  • 706 Answers
SOURCE: Frigidaire dryer, lots of lint getting past screen.
Here is a link to an exploded view and parts list for your dryer.
If you are certain that the filter is not compromised or damaged and is properly seated into the housing , you may have a problem with the housing itself whereby lint is getting into the blower thru a break in that housing.. I would examine that area for damage.. and make sure when you reinsert the filter, it is seated all the way down.. Hope this helps you... BTW: over time, it is not unusual for lint to build up in the duct since some of that lint is smaller than the filter media and will work its way thru.. If you are getting that degree of lint build up very quickly then you may have a problem as mentioned above..
Posted on Dec 04, 2008
  • 986 Answers
SOURCE: Amana LGA30AW Gas Dryer won't produce heat
The heating element have got old and brittle over time and finally gave up the ghost. But it is not always the element. It could be one of the safety Hi-limits have blown. All parts of the dryer will have continuity if its working properly. Test for continuity by using a meter set on Ohms,or use a poor man's meter. You can make your own poor man's meter by using an ordinary flashlight . Break the circuit in the flashlight and add a couple of wires to it so that you can make the light come on in the flashlight, that's right hot wire that flashlight. When the bulb lights up you have a circuit! You now have a poor man's meter. The next step is to check each little gizmo on the dryer that the wires attach to. All the limits attached to the side of the heat element, the door switch (when door is closed) etc.should have continuity (closed circuit)(the light should come on in the poor man's meter) If you come across an thing near the blower housing with 2 wires attached to it, that is a thermal limit, a safety or a control thermostat (So as not to get a false circuit you need to remove one of the wires to each thing you check) Look for lint buildup or blocked vent going out the house. If everything is good and you have paid the electric bill, then the timer could be bad.
Posted on Sep 12, 2009
  • 5911 Answers
SOURCE: dryer takes more than one cycle to dry clothes
Did you clean the entire length of the vent ducting? Or, did you only clean the lint trap on the dryer and the exhaust vent outside? If you didn't clean the ducting as well, you may still have a clog somewhere causing your dryer to be "starved" for air. A dryer needs proper air flow to dry properly. One way to check is to turn the dryer on and go outside to the exhaust vent opening. Feel to see if you have sufficient air flow. If the air flow is weak, you have a clog. If not, you may have a high limit thermostat cutting off prematurely, not allowing the heating element to heat long enough. Check your ducting first and let me know if this helps.
Posted on Jul 28, 2007
  • 686 Answers
SOURCE: GE gas dryer gets hot but doesn't dry clothes like it used to
rule number one take everything off of it and never store clothes or anything that can insulate the top it overheats them. It kind of fools all your sensors when you store stuff on top
Posted on Feb 27, 2009
SOURCE: dryer does not dry
Problem is likely:
- heating element, or
- one of several thermal limit switches in the electrical circuitry
If you want to further pursue, let me know.
Posted on Apr 28, 2009
Amana electric dryer timer doesn't advance during
If this is one of the electronic models: Clean the sensor strips located inside the drying area. As wet clothes rub against these the control monitors the resistance changes and knows the clothes are still wet therefore it continues to operate. When buildup from dryer sheets and fab softener get on them strips a barrier is formed that repels dampness. Therefore the control does not know the clothes are wet and goes to the end thinking all is Kosher. Clean them sensor strips with Windex and party on!
Jun 18, 2012 | Dryers
My amana dryer smells like something's burning
You will need to open the dryer ans clean the internal duct work.
May 22, 2012 | Amana NED7200TW Electric Dryer
Dryer is not heating enough to dry the clothes. It is 9 years old, is it better to just invest in a new dryer?
After 9 years you are going to need to replace some parts. If the ignitor works and the flame sensor is shutting down the gas but the flame stops after a while or not at all then them cols need to be replaced. themobilian_2331.jpgthemobilian_2332.jpgthemobilian_2333.jpg
Amana Dryer Service Manual Gas and electric models (printable)
May 09, 2011 | Amana ALG230RAW Gas Dryer
Dryer is not heating up to dry clothes
The spark ignitor maybe at fault. Listen for the clicking noise upon starting it up the first 30 seconds it runs. If not heard it is in need of a replacement
May 01, 2010 | Amana NED7200TW Electric Dryer
Amana dry wont dry
partially bad heat element. some models have a double element maybe half of it is burned out
Nov 17, 2008 | Amana NDE2335AY Electric Dryer
Dryer heats up but clothes won't dry
Sounds like to me, that you need to check the vent going outside from the dryer. I had the same problem, and found a birds nest in the dryer vent on the outside of my house restricing air flow. If that doesn't fix the problem, look into a new heating element and or thermostats for the dryers. The old ones could just not be getting hot enough anymore. Good luck.
Apr 08, 2008 | Whirlpool LER5636P Electric Dryer
Dryer not drying
try taking a flashlight and look over the back of the drier see if the vent got mashed or is all coled up and stuff let me know also you can remove the vent from the back of the drier and run 1 load to see if it works normal if so then you know the vents the culprit.
Jan 16, 2008 | Amana NDE2335AY Electric Dryer
Dryers Logo
235 people viewed this question
Top Dryers Experts
