Question about EliteGroup K7S5A Pro Motherboard
Elite Group K7S5A Pro Monitor Not Responding
Ive had it 5 years with only 1 256 DDR in, and last night I changed it out and it wont come back on. at all. ive tried a few different rams as well, going lower and lower in speed
  • 104 Answers
You need to take every ram, board and cable out of place... then clean it all perfectly... (isopropilic alcohol is the best to use in cleaning hardware) then reconnect it all and just try powering on with just motherboard, cpu and ram, NOTHING ELSE... if the system starts... you must connect all pieces, one by one, booting the system after includding each thing to isolate the problem if there is one... after all peaces are back togeter, test the system normally.
IF MOTHER does not boot only with cpu and ram... you have hardware problems either in mother, ram or cpu or power supply and you will need to replace hard... good luck
Posted on Mar 22, 2008
Going to be a bad circuit board and most likely none are available for a set of this age---Average life span on these and all Plasma sets is 3-5 years.
May 05, 2012 | Pioneer Televison & Video
I'm running dual Princton Monitors.This morning in booting up my computer one screen stayed completely blank with the message"For best picture quality change resolution to 1280x1024. This monitor...
possible that the video card has packed it in and is not responding for duel monitors
you could always try going to control panel , display section and check the settings of both monitors and the drivers for both monitors
to check the problem monitor change the setting from main display from the good unit to make the other monitor the main display
it should change over and the first monitor will then go bad
Apr 23, 2017 | Princeton Digital VL1514 Monitor
Would A 1GB PC3200 run in the K7s5a alone.
According to the specs the max amount of ram is 1 GB and max speed is pc2100 so a pc3200 would not run on it unless the board was able to clock the speed down of that single stick of ram.
I was not able to find the max amount of ram per slot on a quick search but most likely it would be 512 mb per slot for a max of 1 GB between the two DDR slots.
at Newegg you can find DDR 266 1 GB kits (2 x 512mb) which would get you the 1 GB of ram.
Jan 08, 2010 | EliteGroup K7S5A Pro Motherboard
Wont boot after disconnect CD Rom
1. Power off your computer
2. Open the case
3. Remove the RAM from the slots.
4. Wipe the ram pins with cloth or best is eraser to maximize contact
5. Interchange the RAMs if you have 2
Now turn ON the computer.
Jan 05, 2010 | EliteGroup K7S5A Pro Motherboard
Elite Group K7S5A Boot Problem
Try this... Remove all cards, hard drive(s) and cables, such as cdrom and floppy, except the video connection so that you can see what is going on. Go to the bios setup. Set all of the bios settings to default as you exit to reboot. Then try again. By setting the bios, that should take care of it. Then replace the other items, cards one by one and watch the reactions.
Hope it works.
Nov 06, 2009 | EliteGroup K7S5A Pro Motherboard
Want to improve speed of p.c
if ur motherboard has 2 extra RAM slots...den u can add 2 more ddr rams...They come in 512,1gb,2gb catagories...
May 08, 2009 | EliteGroup K7S5A Pro Motherboard
Elite group P4M800-M7 Can i use 2GB 667 / 800 ddr2????
I have p4m800-m7 also and i cant seem to get both sticks to work.....I still have only 1 gig with both sticks i have 2 DDR-2 1Gig sticks PC2-5300 533 mhz
Mar 12, 2009 | EliteGroup P4M800-M7 Motherboard
Need drivers
To download drivers for the EliteGroup 7S5A Pro , click on the link below.
Most common issue's for not being able to boot PC system.
1. Swap power cord/replace. Check video connection cable,
Check monitor power cable. (Check wall outlet is good).
2. Reset cmos/bios. (Need to use manual for board to reset)
3. (No display on monitor, can hear fan's running & LED's on case light/flash). Remove & re-seat video card, same for memory. (While in PC check all power connections & data cables to devices.
4. Fans not running & no LEDs do not light/flash. Power supply may be bad.
May 01, 2008 | EliteGroup K7S5A Pro Motherboard
EliteGroup K7S5A (does not say pro on the board)
According to their website, the board can take:
AMD Athlon XP (Throughbred up to XP2600+)
AMD Athlon (including Thunderbird)
AMD Duron (including Morgan)
You can then overclock the processor with a BIOS upgrade available at
It has one 4X AGP slot so it can take any AGP video card, assuming the card is backwards compatible (8x -> 4x).
Jan 13, 2008 | EliteGroup K7S5A Pro Motherboard
EliteGroup K7S5A Pro Motherboard Logo
60 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
