Question about Dell Wireless Keyboard Optical Mouse w0147
Wireless Dell mouse, wheel in middle, 2 buttons, black and silver.
Crazy mouse.
Wheel will not roll properly. I roll, roll, roll the wheel, and it rolls the page after ten or so rolls; does not want to roll. New batteries, and a reset of keyboard together with the mouse did not help. Do I need a new mouse; it's appx. four years old.
    President:
  • 2,712 Answers
First try to reinstall the updated driver for your mouse. If this does not work, it could be that the mouse is worn out and you may need to replace it...
Posted on Apr 18, 2008
  • 1 more comment
  • Swilin Sampson
    Swilin Sampson May 03, 2008
    Just wanted to inquire if your issue is resolved, or if there is anything
    further I can do to assist you…
    If you find that the solution/answer I provided led you
    to, or resulted in a fix, please take a moment to close the ticket with a FixYa!
    rating under my solution.
    I would be very grateful for your show of appreciation.
    Should you have any further questions, please feel free to
    post them here.
    Thank you for using FIXYA!
    Cheers!
    IrishDruid
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    P.S. -You can rate this solution with one of
    four votes, if you feel your issue is resolved.
    • "FixYa!"
      - The solution provides great advice on how to solve the problem.
      (Positive Rating)
    • "Helpful"
      - The solution provides useful leads that helps solve the problem.
      (Positive Rating)
    • "Thanks
      for Trying
      " - The solution does not solve the problem but the
      effort is appreciated. (Negative Rating)
    • "Inappropriate"
      - The solution has absolutely nothing to do with the problem.
      (Negative
      Rating)
    If your issue is not still not resolved, do not
    assign a rating just yet. Please post back as to what steps you took, results,
    etc, and I will try to assist you further as best I can.
    IrishDruid
  • Swilin Sampson
    Swilin Sampson Jun 28, 2008
    Kindly close this thread with a “Fixya” rating if you have been able to
    fix the problem, so that I can remove it from my work queue.
    If the issue is not resolved, please post back with latest developments, what
    steps you took, etc. and I will assist you further as best I can.
    Thank you for understanding,
    IrishDruid
SOURCE:
Why is my youtube page shrunk down so i can barely read it. what did i do?
Do you have a mouse with a scroll wheel in the middle?
If so, open your internet browser. Press and hold the CTRL button and roll the mouse wheel up or down to get the proper zoom factor you want on your internet browser
Mar 02, 2015 | YouTube Computers & Internet
I have an HP N3 optical mouse that was doing well until the other day when the middle little scrolling wheel stopped working. Can I fix it or do I have to buy something else? Thank you.
If the entire mouse stopped it probably time for new batteries. If it is just the wheel then it could be a driver issue or setting. If those are ok ie the middle button wasn't disabled somehow or your computer figured it only has a 2 button mouse then its hardware. That means its replacement time. It's possible the switch or the sensor for the wheel are dirty so if you want to you can take it apart and try cleaning.
Aug 11, 2010 | HP Wireless Optical Mouse Sl/Blk With...
The middle wheel does not work as a pan option in my AutoCAD 2002 program . Run in vista. Dell mouse SN-H100009B
In your control panel in windows under your mouse options. Make sure that you have the middle options button selected. It could be windows vista has not select it.
Dec 04, 2009 | Dell U0636 Mouse
Cannot use centerscroll wheel to click and pan
Your scroll mouse may not have a button built into the wheel.
Do try to push down on the wheel, though. Most (quality) modern mice have a button built in below the wheel that just takes a little extra pressure to use.
Sep 29, 2009 | Dynex Wireless Optical Mouse
MOUSE CAME APART INCLUDING SPRINGS HOW DO I PUT IT BACK TOGETHER
The Spring goes on the right side of the mouse wheel as it would be pointing at your computer. It supports the wheel to make it spring back when preasure is applied. Place the spring on the axle with the spring forming an spread out "A" (not a "V"). You will see that it falls nicely into the 2 little tower mounts. my real problem was with the other little piece of bent wire that fell out. This is the part that makes the snaping fealing as you scroll the wheel. This connects directly on the plastic part that is mounted on the scroll wheel. If you look at that plastic part you will see a small hole. One end goes in that hole & the other rounded end goes to the splines on the wheel itself. I hope this helps, it better that just saying go buy another.
Allen
Sep 19, 2009 | Dell OPTICAL MOUSE SILVER BLACK WITH...
The exact same problem
Roll back the mouse driver:
1. Right-click [My Computer]
2. Select [Manage]
3. Select [Device Manager]
4. Locate your mouse on the right windows and press the +Mice ...
5. Right-click HID - Compliant mouse ( or whatever)
6. click [Properties]
7. In the "Driver" tab, Select [Roll Back Driver]
Mouse is now free from Microsoft trap....
Sep 19, 2009 | Microsoft Wheel Mouse Optical PS/2 USB...
Change batteries
This is a deceptive little beastie. As you look at the mouse, you will see that the front approximately 1/3 consists of the left and right mouse buttons and the scroll wheel. The rest appears to be a one piece cover with the black area with the GE logo in the middle. There's the tricky part. The black part with the Logo is the housing for the USB plug in part (so you can keep it with the mouse when transporting it). The rest of that (silver on my mouse) is the battery cover. You open it up by gripping the little raised line on each side of the cover and pull backwards while holding the front by the black area under the mouse buttons. The cover (only the silver part, the black is attached to the rest of the mouse) will slide backwards and Voila! There are your batteries.
Jan 12, 2009 | GE Optical Mini Mouse ho98094
Where's the battery????
If you consider the button and wheel side to be the front -
There is a silver oval button at the back of the mouse. Press it and the top of the mouse just behind the mouse buttons will pop open.
It takes 1 AA battery with the negative side going to the front.
Jan 12, 2009 | Microsoft Wireless Notebook Optical Mouse...
Microsoft Wireless Optical mouse 2.0 Sticky central wheel
I just took mine apart to fix same problem, works much better but not sure for how long.
Quite simple to dismantle the unit.
Take the battery cover off, remove batteries.
There is a small screw in the middle of the battery cavity, you will need a very small Phillips head screwdriver.
Gently ease the base (holding circuit board) from the top shell
The wheel unit can be gently eased out of its cradle, use the small screwdriver to pop it out, watch out for the small spring between base and wheel unit, don't lose it
You can disconnect the wheel unit from the circuit board by unhooking the small plug connector
Now defluff, then clean the wheel - I used a tiny amount of turps on a cloth, anything similar should work. If you look closely the reason the wheel won't roll smoothly is that the gel ring on the wheel is too close and rubs at the front and back of the cradle. Once grime builds up, this problem makes the wheel unusable. Roll the wheel back and forth along a clean surface once cleaned, should start rolling freely again.
I also unscrewed the top shell from the mouse buttons (all one piece, pinch the plastic pegs in the centre of the shell together to release) and cleaned the whole unit up before putting it back together
Don't forget the spring when putting the wheel unit back. When screwing the base to the top shell make sure there is no play between the two parts before you put the batteries back in, mine was a bit tricky to get tight again but worked fine second attempt
Sep 07, 2008 | Microsoft Standard Wireless Optical Mouse
Dell Wireless Keyboard Optical Mouse w0147 Logo
110 people viewed this question
Ekse
Clive
Clive
