Question about SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive
Describe your SimpleTech 500GB is not a 250GB
We moved the computer and now the plug and play feature does not work for this external drive. My Windows XP cannot find the driver and it is not available on the company website. Please HELP!
    Problem Solver:
  • 16 Answers
You should not have to install and extra drivers for this device as Windows XP should find this device when you plug it in to the USB port. Try plugging it in to another USB port on your computer. Plug another device in to the USB and see if it works.
When you say the plug and play feature does not work, do you mean that Wndows does not see the device or the backup program is not working?
Posted on Mar 22, 2008
Im trying to access my firelite external hard drive (model USBFLB80) that has been sitting around unused for a while. I have a new computer, which is a mac, now and only used it with a windows pc before. I...
Hi
A USBFLB80 is not a hard disk controller, it's an external USB hard drive and does not require any driver when used in Windows ME/2000/XP. This device is plug and play in Windows XP providing you have a working usb port to plug it into.
May 29, 2011 | FireLite (USBFLB80) Hard Drive
I have a Memorex Ultra Drive connected via USB to a Windows XP machine. It shows up in My Computer as a folder but then disappears again. It does this repeatedly. The drive is formated as a FAT32. How...
As you have described that your Memorex Ultra Traveldrive re-appears repeatedly, indicates that the communication between your computer and your external hard drive is intermittent. The FAT32 format does not produce these types of issues. What we can do first is identify what causes the problem.
Assuming that the hard drive in your Memorex Ultra Traveldrive is in good shape:
Troubleshooting Method #1. Try connecting your Memorex Ultra Traveldrive into another USB port. If the problem persists, use another USB cable for your external hard drive. If the problem still persists, you will have to replace the external casing of your external hard drive. If your external hard drive works with the other USB port perfectly, most likely, the USB port where you originally plug into of your Windows XP machine needs to be checked. That USB port might need some repairing.
Troubleshooting Method #2. Try connecting the external hard drive into another computer and perform the same troubleshooting as Method #1. If your external hard drive works with other computers perfectly, most likely, the USB port where you originally plug into of your Windows XP machine needs to be checked. The USB port might need some repairing.
If the problem only occurs with your Windows XP machine, assuming all USB ports are in good shape, your Windows XP needs to be checked for some software issues.
I hope this works for you. Kindly reply/comment for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
DELL Tech ID #456563
TIPS: Is your computer slow? This might help
http://www.fixya.com/support/r8158906-diy_manual_pc_tune_up
(for Windows only)
Apr 06, 2011 | Memorex Ultra Traveldrive - 160GB USB Hard...
How can I install the driver for My Passport WD External HDD 500GB online?
It is a "plug-and-play" device, and Windows XP/Vista/7 are "plug-and-play-aware" systems.
So, just connect it, and Windows should recognize it.
Are you getting any error-messages?
What is happening?
What is not happening?
Nov 11, 2010 | Western Digital My Passport Essential SE...
REQUIRE WINDOWS 7 DRIVER FOR IOMEGA SILVER SERIES 250GB EXTERNAL HARD DISC DRIVE. THANK YOU
The external hard-drive is "plug-and-play", and Windows XP/Vista/7 all support "plug-and-play".
Thus, it should automatically be detected by Windows.
So, what's your "real" problem? Symptoms? Error-messages? What happens? What does not happen?
Nov 05, 2010 | Iomega Silver Series External 250GB...
I need the GP08LU10 XP driver
USB optical drives never require a driver when used in Windows XP. This device is 100% Plug 'n Play in Windows XP providing it's a good drive and plugged into a working USB port. The OS will detect and install a USB drive automatically without user intervention within 4-7 seconds normally. When it does so, you will get notification that the install was successful and that the drive is now ready to use.
If it has never been prepped, ie: partitioned and formatted, then that task will need to be performed using drive prep software usually provided by the vendor/manufacturer or by using the built-in partitioning and formatting feature that Microsoft included with the OS.
Feb 19, 2010 | LG SecurDisc 8x External Double-Layer DVD...
Driver does not install atomatically
With the computer off, plug the unit in to the computer and turn it on.
Now start the computer, there is no driver to install manually, windows
uses generic drivers to detect plug n play devise's.
Out of hundreds of computers, the only time I have not seen a hard
drive detected was because the hard drive was bad, and the others
where hacked versions of windows, called lite xp, or the chipset drivers
where not loaded because someone just installed windows but nothing else.
You can look through your bios for plug n play, but its probably set to auto.
Most external HD's take a while to be detected from 10 seconds up to a few minutes.
If the driver does not install automatically, what driver are you installing
that you get it to work ??????????????????????????
Feb 08, 2010 | Maxtor OneTouch 4 Mini 160GB External USB...
I need driver software for my external hard drive. I have the 320GB Simple tech.
drivers should be on the drive! on desktop- click on my computer, click on drive letter (right click)- click on properties- or click on 'open' - if it shows driver files, double click and install drivers, or you may need to format it!
good luck!
Oct 11, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
Hard drive is not recognize by the computer
Both XP and Vista have this feature that requires that new installs of hardware be certified by Microsoft within anywhere from 30 to 60 days from installation.
Run an install (not a clean install which will wipe your data, mind you, but an install accomplished by installation disks, where you will be asked which kind of install you wish to accomplish, and you will be asked to register your software using your product key)
If you need additional information, I will be more than happy to assist you.
Apr 07, 2009 | Toshiba MK8026GAX (hdd2191) 80 GB Hard...
I require a driver for our Beyond micro external hard drive.
It looks as though there is no driver support for beyond micro although the specs state that the drive is plug and play. which means you just plug it in and windows sets it up. other than that there are no software or drivers for it.
best of luck.
hope this helped.
please remember to rate me.
Mar 02, 2009 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
Need driver
Hello maris12345
You shouldn't need drivers for your USB mass storage device on Windows XP. It should be "plug-n-play".
Is yours an older computer? If the computer's USB interface (hardware) is not at least USB ver 1.1 then that may be the problem. (I assume your external hard drive isn't being detected, yes?)
Can you run other USB devices on the same port(s) OK?
BJ
Apr 03, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive Logo
101 people viewed this question
Top SimpleTech Computers & Internet Experts
Lyle Siemens
Lyle Siemens
Arora Singh
Arora Singh
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
