Question about Cybernet Systems CyberPower 625AVR (cp625avr) UPS System
944 the ligth no turn on
    Genius:
  • 1,198 Answers
I got lucky with my cyberpower 1000. Found that the black wire from the outlets to the board was not tight enough. Squeezed it a little with my pliers, and it works now. Don't worry about the on-plug falling out, you can push it in from the outside when you're done.
Posted on Mar 27, 2008
How do I fix the brake ligths?
Did you check to see if there is a fuse on the brake lights circuit?
If you changed the lamps and the brake switch it is obvious that they are not being energized.
Aug 31, 2015 | Cars & Trucks
Am rebuilding the engine on my Porsche 944s 16v and cannot find details of the Cylinder Head Torque settings.
The torque angle tightening method is now valid for all engines of types 924S, 944, 944S and 944 Turbo including all earlier engines from start of 944 production. When making repairs, the following parts must be used:
Cylinder Head Gaskets
Part Number 944 104 374 14 - 924S, 944, 944S Part Number 951 104 374 01 - 944 Turbo only
Cylinder Head Nuts (12 mm high)
Part Number 999 076 028 02 - all types
Washers
Part Number 944 104 229 00 - all types
Tightening Specifications to Torque Angle Method
Tightening is done in 3 steps:
Step 1: 20 N-m (15 ft. lbs.) Step 2: 90 degrees (114 turn) Step 3: 90 degrees(1/4 turn) Important:
Sequencing must be kept for each step. Threads and bearing surfaces of nuts must be lightly lubricated with oil prior to installation. Washers must not turn while tightening. Create a reference mark if necessary.
Note:
The 12 mm high cylinder head nuts might protrude above the studs slightly on engines produced prior to Feb. 1986. In addition, new head nuts must be used at each repair.
May 23, 2011 | Porsche 944 Cars & Trucks
I change the turn signal lever I took apart unplunged everything carefully put everyhing back together carefully but as I was workig on it I heard my horn honk twice I look no bear wires anywhere finish...
your security system is activated. try turning the key on let set for 10 minutes turn it off then start. on some models it has to be done 3 times on off on off on off start. 10 minutes each time
Jun 22, 2010 | 2000 Chevrolet Tahoe
My brake ligths and blinkers does not turn on. why? but, if i turn on my ligths , yes the rear ligths they are on just the brake and blinkers not
Defective Hazard Switch or Turn Signal Switch will most generally cause this problem on GM vehicles!
Mar 08, 2010 | 1999 GMC Yukon
The brigth of the rigth head ligth is dimished
you mat have a shorted bulb try changing the bulb if that doesnt work you probably have a bad ground
Feb 06, 2010 | 2003 Suzuki Grand Vitara
No turn ligth and no stops ligt
gmc had a recall for that problem. It is the switch under the break pedel was installed wrong during manufacturing. Took mine in and they replaced switch.
Aug 09, 2009 | 1994 GMC Sierra
At%t 944 4 line intercom voicemail set up?
There is no included voicemail with that phone. You could order voicemail through the phone company, and I beleive it will turn on the "Voice Mail" light.
Nov 20, 2008 | AT&T 944 Four Line Intercom Phone
1984 PORSCHE 944
check for spark, fuel and cam belt
Jun 23, 2008 | 1983 Porsche 944
Cybernet Systems CyberPower 625AVR (cp625avr) UPS System Logo
83 people viewed this question
Top Cybernet Systems Computers & Internet Experts
Greg Cann
Greg Cann
Jax Planet
Jax Planet
amisset
Are you a Cybernet Systems Computer and Internet Expert? Answer questions, earn points and help others
